F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
#26
Just an FYI, in my 2011 manual, Amoco is the recommended gasoline by BMW. In my 2008 manual, Shell was BMW's recommended fuel.
Not to insult anyone, but why would one buy or lease a BMW and purchase cheap gas? If you pull into a gas station and the cars filling up are 10 year old beaters with dragging tail pipes, scraping brakes, dents on every quarter panel, and I guy digging deep in his pockets for change, you're not in a quality fuel station.
BMWCCA Member #458528 www.bmwcca.org "If Things Seem Under Control, You're Not Going Fast Enough" Mario Andretti |
#27
My former high performance car, Mercedes CL600 V12, got about 12 mpg city. I used Costco premium for about a year. That's a lot of gas. I had some misfires. MB told me to stop going to the station I was going to. They said the had never seen a filter so dirty on one of their cars. so I stopped going their. I switched to Shell and Cheveron and my mpg actually went up a bit
#28
A bit of backstory to the gasoline distribution system in the US
Folks:
If I have a refinery in Houston making gasoline, I can put in on any number of pipelines (Colonial to NY, Longhorn (now Kinder Morgan) to El Paso and others). And so will the other refineries in the area. When the product is taken off the pipeline in Atlanta or New York, the molecules made by my plant are NOT the molecules i have in storage in one of those cities. It is mine and everybody else's who sent gasoline up Colonial during that cycle. So the gasoline you get at a my station in Atlanta, may not be made by me. So, if that's the case, why shouldn't I buy anybody's gas and have the F10 be happy. As several other posters have mentioned, the Major oil companies have quality control standards, proprietary additives and a reputation to protect. If you buy from someone else, you run the risk of not getting decent gasoline. I always buy Exxon, Shell or Chevron for my Porsche and F10. And I haven't even begun to explain exchanges! And don't get me started on E15! Hope this helps, folks |
#29
Additives are really the only difference. To be more cost effective, many brands actually share the same transportation tubes for gas delivery, meaning individually branded stations within a certain area will use gas from the same terminal their competition uses. So it all starts out as the same product. But, it’s what happens after the gas gets to any brand that makes the difference. And the difference is each brand's gasoline detergent additives. This established the difference between the branded gasoline products.
The additives can be described as detergents and other chemicals that are designed to keep gasoline from evaporating, keep engines from corroding, help engines perform well in different climates, and keep engines clean. Their goal is forming less deposits when the gasoline burns, for better mileage, performance and exhaust emissions. The distinctive additives go in as tank trucks are filled; the brands acquire their differences just before the gasoline is taken to stations. Before that they are all the same. All gasoline has additives. For unbranded gasolines, like those sold at low-cost outlets, the additive is a generic version that meets minimum federal standards, and the ratio is about a third of a gallon of additive to every 1,000 gallons of gasoline. Major brands claim that their own additives are the most efficient ones while others' are not. Chevron, whose additive is acknowledged as the most expensive, says it keeps combustion chambers free of deposits while 'some of'' its competitors' additives will actually increase these deposits. Citgo claims that their additives include a corrosion inhibitor and a de-emulsifier that others don't have. Sunoco says its additives perform above the minimum levels in cleaning up intake valves and fuel injectors. Shell claims its formula keeps intake valves clean while cheap gas damages them. Ethanol carries less energy than gasoline, but is cleaner, therefore it is better for the environment but means less fuel economy for us. Even Top Tier brands like Chevron and Exxon use some amount of ethanol (according to the EPA, E10 gasoline is used by over 90% of the US gas market). Gasoline is graded by octane number, which rates its resistance to premature ignition, or engine knocking. Regular gas has an octane rating of 87, a medium grade is 89, and premium gasolines begin at 91 and go up. Higher-performance cars generally need higher octane. Racecars use a grade of over 100, which you won't find at your local station. The differences in octane number on the other hand originate in chemical mixtures created at the refinery and different grades of gas are kept in separate containers during the distribution process. The right grade to buy is the one your particular car was engineered for. I have worked a long time as a regional director for one of the World's top 4 oil companies and believe me, there is very little difference between the gasoline brands. I would go with any premium brand like Exxon, Shell, BP, Chevron, etc. but most importantly with the highest possible octane rating while not paying a huge extra for any brand as the effect is not worth paying that extra for.
13 BMW F10 535i RWD - 3.0 L 221 kW (300 hp) Bone stock except NAVI, PDC, Camera, Tint, Coded, HID Kit, Debadged 2007 BMW E64 630i - 3.0 L 200 kW (272 hp) 03 BMW E65 745i - 4.4 L V8, 242 kW (325 hp) 98 BMW E39 535i - 3.5 L 183 kW (245 hp) 95 BMW E34 540i - 4.0 L V8 210 kW (282 hp) 89 BMW E30 M3 non-cat 147 kW (200 hp) 12 MB W221 S550 4-Matic 10 Infiniti G37x Sedan 2009 Mercedes C 350 08 Infiniti G35x Sedan 04 Mercedes CLK 350 01 Mercedes C 230 98 Ford Crown Vic Police Interceptor |
#30
SHELL V-Power in all my cars for years!
DallasBimmer: Current vehicles: 2013 BMW 535i M-SPORT 2009 Infiniti G37 2005 Honda Accord LX 2005 Ford F150 FX2 SuperCrew 2004 Toyota Sequoia SR5 1996 Toyota Camry LE Wish I had a six car garage...
#31
Well said, Dallas.
+1 |
#32
My manual recommends BP fuels. I've been going on that recommendation. But I'll certainly look at the options on the top tier list.
PCD on 9/6/2011: 2011 550i, DSB, black/oyster. Prem 2, Conv, Ventilated, HUD, Sport, DHP, SAT |
#33
Also, I've heard that you want to go to the busiest Gas Station that you can, because it means you're getting the freshest gas possible, i.e not something that just sits around under ground for a long time.
'13 F10 BMW 535i ///M Sport : Jet Black/Black-Anthracite : Premium & Technology Packages/Sport Auto Trans/Camera/Park Distance Control/Heated Seats/Tinted Windows/Blacked Out Markers/Performance Spoiler. Ex M-B's: '11/'10/'06 E350's w/ AMG Sport Package, '02 S500 w/ Every Option.
#34
I never heard that it "looses" its octane though. Gasoline can be stored for a very long period without deterioration when the storage conditions are good (a tightly closed container and moderate temperatures). Gasoline containing ethanol is especially subject to absorbing moisture from the air, which ends up forming gums and solids. In the gas stations, gasoline storage tanks have floating membranes that act as a barrier preventing evaporation and mixing with atmospheric moisture.
#35
![]() Have used Sunoco Ultra ever since, but see Sunoco's not listed as a 'top tier' supplier; is it not a 'top tier' gas? Last edited by dbs600; 02-24-2013 at 11:30 PM. |
#36
What do you think of Costco Signature Premium fuel? The station near me in Atlanta is very busy, and the fuel flow rates are good. For those interested, every other car in line is a BMW or a Merc lol, but that's Atlanta for you. |
#37
I personally don't think that Costco gasoline is bad (or any other non-top tier brand such as Hess, Sunoco (USA), etc.), but you may see an increase of mileage with top tier gasoline and better power output. Most modern cars have injection systems that are very susceptible to impurities. On the long run, the engine would be cleaner with top tier gasoline products. I'd not take a calculated risk of ruining my engine over time in order to save 10-15 cents a gallon, which may be offset by lower mileage.
13 BMW F10 535i RWD - 3.0 L 221 kW (300 hp) Bone stock except NAVI, PDC, Camera, Tint, Coded, HID Kit, Debadged 2007 BMW E64 630i - 3.0 L 200 kW (272 hp) 03 BMW E65 745i - 4.4 L V8, 242 kW (325 hp) 98 BMW E39 535i - 3.5 L 183 kW (245 hp) 95 BMW E34 540i - 4.0 L V8 210 kW (282 hp) 89 BMW E30 M3 non-cat 147 kW (200 hp) 12 MB W221 S550 4-Matic 10 Infiniti G37x Sedan 2009 Mercedes C 350 08 Infiniti G35x Sedan 04 Mercedes CLK 350 01 Mercedes C 230 98 Ford Crown Vic Police Interceptor Last edited by hufington; 02-25-2013 at 07:18 AM. |
#39
Since we're all 2012 or 2013 F10 owners, has anybody looked into our manual to see what the BMW recommended brand is?
#41
#42
I haven't checked my paper manual but BP is not in my area at all. I've always used Shell V-Power, 91 octane, added winter additives, no ethanol.
2012 BMW 535i X-drive; Space Grey/Black Dakota, Fineline; Executive (Auto trunk, NAV, HiFi Prof, Lumbar, Rear Cam, SIRIUS, Voice), Technology (Blind Spot, Hi-Beam Assist, Lane Departure, Surround View), APPS, Rear heated seats, Tint. Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i |
#43
This is true. Good practice is to use same fuel for a couple thousand miles then switch to another for same mileage then switch back. I rotate Shell/Chevron/BP.
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) |
#44
Costco gas has made an effort to improve the additives. Stop by a Costco gas pump and read the additives. They seem to have their act together. The amusing part of this discussion is that virtually all the gasoline delivered to the stations come from the same depot. The difference is what the driver puts into the tanker after they fill up from the refinery. Lets think about it. The additives that everyone believes is in their favorite gas is dependent on the driver who delivers the gas to the gas station. Does this make you a bit uncomfortable. To be safe, every few months put a pint of the Techron additive and all will be good. |
#45
I own a 2011 and the owners manual states BP, as I mentioned 10 or so posts ago.
#47
The BMW "recommendation" is obviously a marketing thing done by who's sponsoring/lining their pockets, hence how it changes without any components changing, i.e nothing to do with engineers. If anything it should go to show how little it matters what exclusive station you use.
#48
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) Last edited by Alpine300ZHP; 02-26-2013 at 06:58 AM. |
#49
#50
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
