Old 02-24-2013, 12:31 AM
CharlesAFerg CharlesAFerg is offline
Any Portlanders?
Send a message via AIM to CharlesAFerg
Mein Auto: E34 ///M20 2.5i '89
Knock sound, odd starting.. Not VANOS.
All,
My '00 740i Sport is occasionally (not every start, and I can't nail down a common theme) making what sounds like a knock when starting. I know what the vanos noise sounds like, and this is not the same.
It's not as the engine is started, but as the starter is cranking. If I could explain it better, I would say that the engine stumbles when it starts, and sometimes makes a knocking sound, almost as if the wrong cylinder fires out of order before it would normally start. So, say I start the car and it starts normally after about 4 or 5 cranks of the starter. What is happening here, is that after maybe after 2 cranks, a cylinder fires and the starter seems to continue for another 2-ish cranks while the rest of the cylinders begin to fire in order, smoothly.
I was told the car was running lean, but would that cause this starting issue? I'm not entirely sure how that system works, and perhaps I'm missing something. I see no codes with either the BMW specific diagnostic tool or a generic OBDII scanner.
Other than that, the car runs great. I am replacing my aux evap pump due to failure, although I'm almost certain that it is unrelated.
Advice would be greatly appreciated!
Old 02-24-2013, 07:41 AM
Espresso Espresso is offline
Coffee Extraordinaire
Mein Auto: 2001 740i Sport
does it sound like this?
http://www.youtube.com/watch?feature...&v=EURgDRgE5lc
Old 02-24-2013, 05:10 PM
seamus2154 seamus2154 is offline
Mein Auto: 2001 740I Sport
My 01 sport does what is in expresso's video. Only for a second or two and first thing in the morning and a cold start. I was told it is my chain tensioner. I have read the same thing. The new tensioner is longer w/ a tighter spring I have read. It is not a hard job it's on the pass head and can be done externally. The part is about 75 bucks, so I will be doing this soon.
Old 02-24-2013, 08:37 PM
Any Portlanders?
Nope. Like I said, it's not a rattle after start-up, it's a sound during start-up.
Old 02-25-2013, 12:31 AM
Bigrobsbmw Bigrobsbmw is offline
Mein Auto: 2004 745i, 2001 740i
Seamus by all means upgrade your tensioner but the noise will not go away. I guarantee it is your VANOS gears. Most of these cars do it, and it will keep doiung it until you spend the 500 per side for the gears.
Old 02-25-2013, 12:36 AM
Any Portlanders?
Are you talking to Seamus or myself? The sound that my car is making does not sound like VANOS at all.
Old 02-25-2013, 12:37 AM
Charles the only thing I hear is the engine firing prematurely for lack of a better phrase, much like you described. That is not unusual or anything to worry about. Now I did hear something that sounded like a chicken or a dog barking, if that is coming from your engine then there may very well be a problem.
Old 02-25-2013, 12:38 AM
I started the replies with names for direction clarity I thought
Old 02-25-2013, 12:45 AM
Does it make the noise on every start ? You are right the air pump has noting to do with that. I think the air pump comes on after the car starts.
Old 02-25-2013, 08:20 PM
Any Portlanders?
Just a crow.
It does it less when the car is freshly driven hot, but it's not unheard of. It does happen when the car is warm, too. Perhaps even 1-2 hours after it's turned off.
HTML code is Off
