Old 02-24-2013, 05:57 AM
z0lt3c's Avatar
z0lt3c z0lt3c is offline
what does this button do?
Mein Auto: 08 535xit
balllast or bulb- xenon headlight turned pink
In our 08 535xit we have the adaptive xenon headlights. Lights have been working fine for some time, other then an occasional blown AE bulb, but yesterday we go to start-up the car, in the evening, turn on the head lights and find that one headlight is outputting in a pinkish color. It almost looks like somebody swapped the bulb with a different temperature output. The other head light works fine and outputs light correctly.
I've never had a problem like this, wondering if you guys think it's the bulb or the ballast? I'm leaning toward ballast since usually when a bulb goes, it stops work, not changes temperature. Has anybody had this problem before? The car is CPO, I am hoping it will be covered.
Thanks,
z0lt3c
Current:
2013 Ford Edge SEL AWD
2012 Jeep Grand Cherokee Laredo 4x4
Retired:
95 e36 M3/5spd, 96 328is/5spd, 97 540iA, 98 528iA, 01 X5 4.4iA, 03 325xiA, 04 530iA, 02 330Cic/5spd, 08 535xit
Old 02-24-2013, 06:40 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
More likely a bulb. You will need to replace pair, otherwise will be different color.
BMW CCA Member, Capital Chapter
Old 02-24-2013, 07:19 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
No, it's not covered under CPO. BMW calls the bulb a wear and tear item:
http://www.bmwusa.com/Standard/Conte...otCovered.aspx
D1S Bulbs and change in pairs like phlfly said as the other one will "pink out" before the newer one. They usually go pink indicating they're dying.
Old 02-24-2013, 07:50 AM
z0lt3c's Avatar
Thanks guys, off to buy a pair of bulbs. I guess I can cancel the service appt.
Old 02-24-2013, 07:55 AM
boramkiv's Avatar
Propellers Up Front
Yeaaaa, I would do that too. The dealer would probably charge about $600 (conservative) to install both bulbs, when for around maybe $200 (depending on where you get them) you can get both. Then the install is not too difficult especially if you have a little bit of working hands, or an Indy would be way less expensive and there's no coding required.
Good luck.
Old 03-16-2013, 03:25 PM
z0lt3c's Avatar
Ordered the following D1S bulbs from Amazon -- They cost $38 shipped.
Used the following excellent DIY post from a bimmerfest search; http://www.bimmerfest.com/forums/sho...d.php?t=647366
Spent about 90 minutes working on the first headlight R&R and maybe 15 minutes on the second one. Didn't have to remove the bumper and the bulb fit perfectly.
Pretty happy I cancelled that $600 service appointment... Lights seems to be working as good as ever now.
Old 03-16-2013, 07:08 PM
The Nerd's Avatar
The Nerd The Nerd is offline
Mein Auto: f30 335i
I had exact same thing happen to one of my bulbs on my 05 right before my CPO warranty ran out....and it WAS covered. Furthermore, I only had the one replaced and they both looked the same color to me afterward
335i Sport Line with MPPK
Old 03-16-2013, 07:27 PM
boramkiv's Avatar
Propellers Up Front
Did your dealer do it as a "good will" because the CPO was going to run out and it was only one bulb? They will look the same afterwards because the one that wasn't changed was still good, but the one that wasn't changed may turn pink before the one that was changed as their life cycles are not matched. It's good practice to do both at once because they're not lifetime bulbs.
The OP saved $12 at best.
Old 03-23-2013, 11:37 AM
OSUBMWFAN OSUBMWFAN is offline
Mein Auto: 528i
I had the same issue and replaced both bulbs. They both light up but the lights aren't doing their initial side to side movement at initial start like they used to. Is this a programming issue? Thanks
Old 03-23-2013, 01:39 PM
MrTriad MrTriad is offline
Mein Auto: BMW 525i 2005
Means your bulb is almost out. Just change it. This happened to me too. My right bulb was pink and eventually went out.
Sent from my SGH-T999 using Bimmer App
Old 03-23-2013, 05:06 PM
BlackBlade BlackBlade is offline
Mein Auto: BMW E60 '06
Most likely the bulb. Theres a change on the gas contents inside the bulb making the colour shift.. It shouldnt be hard to replace by yourself and as far as I know no warranty covers bulbs unless you buy the bulb seperately then you get the bulb's manufacturer warranty.
It is also adviseable to change BOTH bulbs to acquire the same colour, xenon bulbs are known to shift in their colour after prolonged use. Hence a new one, despite with same colour and specifications, will result in a slightly different tone. Some people wouldnt mind, but I do lol..
