E90/E91/E92/E93 (2006 - 2013)
Thinking about getting an E9X xdrive to replace my E46 and Jeep
I drive an 01 Jeep Wrangler that I ordered and purchased new in 2001. Since then I have added quite a few after market modifications to make it a better off road vehicle. I rarely go off road though so its mostly a winter vehicle. I also have an 02 E46 330i with about 40,000 miles on it. I love driving it but the rwd won't make it up the hill leading into our development. We've been think about selling them and getting one vehicle to replace them. My wife also has an AWD Ford Flex and we really don't need 3 vehicles. Finding something to replace both of them that fills all my wants and needs seems to be difficult though. I want something that will be fun, for me that means it has to be a standard. That probably also means a 335i. I also want something that will get me up and down the hill so Xdrive is also a must. But reliability and practicality are also important so I'm thinking a 328it or what ever they call the wagons these days may be the most reasonable choice. I'll probably also want to keep the price under $25K used.
I guess my questions are, how good is Xdrive? How do the 335 and 328 compare in terms or reliability? Can you even get an AWD wagon with a stick? |
The e91 does come in AWD with a stick (see View My Garage).
g/l
Ordered: March 7, 2008 Built: March 17, 2008 At port: March 19, 2008 Shipped on Graceful Leader: March 21, 2008 Arrived Port Hueneme: April 11, 2008 At dealer's: April 19, 2008 Delivered: April 21, 2008
328xiTs are available with manual transmission... We own one and are quite pleased with it. This year, we put dedicated snow tires and I was amazed how well it drove in a recent snowfall... Not much of a snowfall, but cars were sliding around and i was driving up hills without issue. The hard part will be finding one... I read somewhere that only 10% of the BMWs in the US are now manual, and since so few wagons are imported, they are like a needle in a haystack... good luck!
I found 2 out on www.BMWUSA.com ... Unfortunately, they are outside your price range... One is a 2011 for 36k, and the other is a 2009 for 29k...
Past the HPFP (which seems to have been resolved), the 335's have an issue with intake valve coking due to the direct injection system. From a long term perspective, the turbos will be a repair item that a 328 won't have.
That being said, I do love my 335i xDrive. Does very well in the snow with a set of Blizzaks all around, albeit with a tendency to tramline in slush, likely due to the width of the tires.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion Last edited by Zooks527; 04-12-2013 at 03:02 AM. |
There haven't been a ton of reports on out-of-warranty turbo failures that I've seen. Seems to be the same as other cars with turbos.
The intake valve issue has a simple (but a bit costly) fix of using ground walnut shells in an air cleaning system to clean the valves off. Costs seem to be in the $400 - $800 range, seems to start to be an issue in the 50,000 - 100,000 mile range. It can also be done manually using brushes if you are handy with a set of tools and want to dedicate a Saturday to the task. I've had mine since it left the factory (I drove it down the ramp in Munich), and I'll cross 90,000 miles this week. I've got a big maintenance update at that point. The two things I'm still deciding if I should do or not are:
Even with that and a short ton of age or mileage based fluid changes (differentials, transfer case, PS, coolant, brake fluid, etc.), I still love this car.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion Last edited by Zooks527; 02-25-2013 at 04:59 AM. |
Turbo reliability surprises! Coming up on 450k mi, pickup, no issues ever. BMW's early issues with wastegate rattle seem resolved. Intake valve coking fixed by walnut shell blast may as well be considered routine maint every 60k mi. |
Yes but they seem pretty hard to find...
Can any of you tell me how the E9X 325, 330 and 328 compare to the E46 330i?
the turbos are warrantied for 100K miles or 10 years, I think I read somewhere. I would more be worried about the transmission fluid not being changed until 100K
walnut blasting the intake valves is cheap to do every 50K miles. I could probably do mine since I have a compressor, would have to purchase the tool and the walnut media, just a tedious job. Hondo |
How much is the walnut blast? |
How concerned should I be about this ticking problem I've been reading about. I'm finding good prices on 330xi's but I wonder if they are selling for so cheap because of the ticking noise. Does the 335 have this issue?
There is no need to be concerned. It is benign. Much like the VANOS rattle on the E46 ZHP. It has zero effect on the market value of the E90 330.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! Last edited by tturedraider; 04-11-2013 at 04:17 PM. |
We had a 330i e46. It was a great car, but it had all kinds of annoying reliability issues (five, yeah count 'em, five window motor failures, gazillions of water pumps,etc) that I have not had with my E91.
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons |
Well, now. What about a $1100 Wavetrac Limited Slip Differential? Gets ya up a hill easy, with snows should be no problem at all. And you still have a car you love to drive....CraigsList/Ebay your Jeep and you're nicely ahead. Sure, lists $1295, but should be easy to find discounted - I did. Hey, tiny added weight, less maint 'n' x-drive, and handles much better! . Last edited by CALWATERBOY; 04-11-2013 at 07:41 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
