Old 02-24-2013, 02:10 PM
NSBMW04 NSBMW04 is offline
Mein Auto: 530i
Head light restoral
I have tried 3M and Diamondite head light restoral treatment on my vehicle with the results ending up with them very clean on the out side and I know that is what those products are designed to do but my headlights seem to have a film of grime on the inside of them . I was wonderng is there an way to clean the inside ?
Ride
Old 02-24-2013, 02:54 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
I think the only way to clean the inside is to open them up which is virtually impossible on the E60. If it's really bad it may be time (unfortunately) for new headlights. I wouldn't do that if you just 3M'ed the outside though.
That picture looks like a Camaro that was modified to look like a BMW...
by the way.
Old 02-24-2013, 03:37 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
I had great results by using the $10 kit from Harbor Freight, simple sandpaper pad that attaches to a drill, some elbow grease and then the polishing compound and my headlights looked new for over a year (until a carsh meant new headlights were in order anyway)
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 02-24-2013, 03:49 PM
Mein Auto: 530i
That picture was of a Camero but I placed a picture of the front of my vehicle to show the headlights after the treatments.
Ride
Old 02-24-2013, 03:53 PM
Boramkiv is right, the only way to clean the inside is to open the headlights, but they are VERY difficult to close up again afterward. You will most likely end up with moisture inside the headlights and short circuits later on as the moisture corrodes things.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 02-25-2013, 04:34 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z4 3.0, 535i
I have an 04 and cleaned mine up again this past weekend. I wet sanded with 2000 grit, then I polished with rubbing compound (Turtle Wax brand) then I buffed with plasti clear plastic polish. Turned out quite nice.
You say you have something on the inside though. I would remove each head light, remove all the electronics from the lamps and try washing out, then let dry real good and re-assemble.
You must have a bad seal or a missing bulb cap at the rear for stuff to get inside???
Old 02-25-2013, 07:23 PM
Mike Swing's Avatar
Mike Swing Mike Swing is offline
Mike Swing
Send a message via AIM to Mike Swing
Mein Auto: 2000 Z3M 2007 530i
I had mine done at the BMW dealership. Very pricey ($200) but I wanted to be able to hold them accountable if it didn't work. Complete night and day difference. They look almost new now.
Mike Swing
Old 02-26-2013, 06:51 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
you either lives close to the ocean (area like Florida) or have a broken moisture barrier on the headlamps, the latter is unlikely if happens on both headlamps. I am talking about a rubber flapper that allows moisture to escape but not in.
You can always buf the outside, that usually improve the condition of the headlamps. I don;t have guts to open it, I heard older headlamps like prior to 2004 can be baked and opened. but my concern is how are you going to regulate the temp(even if you know the exact temp to soften the seal/glue) in home oven, it can be off as much as 10% then cycle up-down, too risky.
How about just remove the headlamp, use micro-fiber sprayed with glass cleaner around a tongue and buff it slowly, insert the tongue through the H7/DS1 xenon bulb opening.
Old 02-26-2013, 08:44 AM
osbimmerfest osbimmerfest is offline
Mein Auto: 2011 535i
have you guys tried cleaning the headlight cover with plain toothpaste? i have just viewed 2 vieos on you tube showing how to do it and it looked real easy and with good result. i will try it oon my '004 530i today.
Old 02-26-2013, 11:55 AM
Never tried toothpaste, but I guess it would leave the headlights "minty fresh" and prevent gingivitis.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 02-27-2013, 01:25 PM
KLR4LIFE KLR4LIFE is offline
Mein Auto: 2008 550i Manual
This pic just looks like you didnt sand the lends down enough to get all of it out. I had mine done by a shop and they used power tools to do the job and my headlights came out brand new. I tried the Turtle wax restore kit on my fog lights and it only took off a little, it looks better but the power tool way works best.
2008 BMW 550i Carbon Schwartz Metallic, 6 Speed Manual, Sport Package, Cold Weather Package, Logic 7, Comfort Access, Active Steering, Sat and HD Radio, Navigation, Comfort Seats and custom coding. Mods - 20 Watt AE, LED License plate lights and HID Fogs, StopTech drilled rotors.
Old 02-27-2013, 02:03 PM
H F H F is offline
Mein Auto: 2005 545i
When i was in Jr high school ( back in 1973 }we used to make projects out of plexy glass,, we used 1500 wet sand paper and then 2000 wet sand paper on the cut edges and it comes out lookin like glass after polishing ..
What Hogie said will work,,, and look like new...
Old 02-27-2013, 06:21 PM
This worked for me and it's soooooo cheap: http://www.harborfreight.com/12-minu...kit-65938.html
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 02-27-2013, 08:03 PM
Hogie's Avatar
Just a FYI..
The first time that I cleaned was about 3 years ago and I just taped round the lamps and buffed in place. This past weekend I actually took the head lamps out when I cleaned. For my 04 e60 it was very easy to take out. Just two torque screws on top and then just loosen two torque screws at bottom of lamp's backside.
I also had to change a burned out angel lamp.
Old 02-28-2013, 03:43 AM
jjp735i jjp735i is offline
Mein Auto: 05 545i
I have tried the toothpaste and it really does work. It also works for removing scratches on glasses, which even the eye doctor said they couldn't fix. I showed them after I did it and they were really surppised it was complety gone.
Don't think it matters, but I used AIM. lol After the toothpaste I used Plastix X cleaner/polish. They still look good after a year.
Old 02-28-2013, 07:23 AM
terrystu terrystu is offline
Its how I roll
Mein Auto: 1985 M635csi, 2008 535xit
I used Crest with flouride on mine, and in the two years since I did it, my headlights have not had one cavity. However, I have had a tough time geting the headlights to gargle.
"Voters will always choose the beautiful lie over the uncomfortable truth"
Old 02-28-2013, 07:35 AM
eWERK-E60's Avatar
eWERK-E60 eWERK-E60 is offline
Mein Auto: E60 550i Porsche 911SC
Novus Plastic Polish. Works extremely well, follow the direction's carefully with this product for outstanding results. I used this stuff on my 08 528 on headlights and interior wood trim.
www.novuspolish.com/
“Racing is life. Anything before or after is just waiting.”
Steve McQueen
Old 02-28-2013, 07:36 AM
boramkiv's Avatar
Propellers Up Front
What about tooth decay? Anything on tooth decay? That can be very serious!
Old 06-12-2014, 12:14 PM
Tweezer Tweezer is offline
Mein Auto: 530xi sport wagon
I'm having the same issue on my 2006 530xi wagon. Does anyone know a good source for replacement head lamp assemblies? Also, anyone have the part numbers handy?
thanks!
Old 06-12-2014, 05:54 PM
Mr. Orange 645 Mr. Orange 645 is offline
Mein Auto: Jet Black 2008 535i
thanks!
Just do a google search for 2006 530 headlight assemblies. Several places carry them, but everywhere I've seen them, they were $600-$900 EACH. So your looking at $1,200-$1800 to replace both assemblies.
Your best bet is to try some of the restoration methods mentioned here. There was a thread here with photos and step by step from another member who made his very oxidized headlights look brand new.
Old 06-13-2014, 08:18 AM
Thanks for the tip. Not sure the restoration will work in my case, as the corrosion is on the inside. Now to find the best deal possible on new assemblies...
Old 06-13-2014, 08:53 AM
DJtoad DJtoad is offline
Mein Auto: 2010 535i M Sport
I posted a DIY a couple of months back on how to clean the inside of E60 headlights. It's very easy.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
JB4 G5 ISO, BMS DCIs, ER Charge Pipe with Forge DVs, Proform Clear Bra, LUX H8 160 LED angel eyes
Old 06-13-2014, 10:57 AM
That is friggin' awesome, and i feel like i should paypal you the 700 bones (x2) instead the dude on ebay!
Doing this TODAY - Thanks!
Old 06-13-2014, 11:04 AM
Hey, toad, how is the cleaning holding up after a few months? And do you have the LCI or PRE-LCI lights?
Old 06-13-2014, 03:46 PM
LCI and they still look great.
