Old 02-27-2013, 06:47 PM
wolf888 wolf888 is offline
Mein Auto: 528i /C240/M35
Need help with steering shakes
E39 528 1998 with 120K miles on drived by my wife and she complained about steering shakes between 70-80 and when slightly push brakes.
just try it myself and CONFIRM IT! and need little bit help!
What was done for last 6 months
all 4 wheel bearins[ ***]
front -both lower control and thrust arms
same with rear
all 4 rotors with new brake shoes
new DWS tires[ already put 7K miles on ] still in great shape
checked all 4 rims [ 17 size]
good alignment
good balance
checked by hands tie rods for steering-No play
What else can it be? and how check if calipers is stuck? already touch it with hands and feels like same temperature
Old 02-27-2013, 09:19 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Are you sure it was properly aligned? - Weighted
Either you are part of the solution, or you are part of the problem.
Old 02-27-2013, 10:21 PM
It's a looooong story. The short of it is that the way your wife brakes is what is likely causing the rotors to have uneven pad deposition, if it's what I think it is.
Of course, there are a zillion reasons for vibration - so I'm just talking about the most common (which fits your description.
The short term solution is free. So is the long term solution.
Details here:
- The main causes of vibration while highway driving (0) (1) (2) (3) (4) (5) & while highway braking (1) (2) (3) & why it's not rotor "warp" (1) & severe ABS shuddering while slow speed braking on bumps (1) & how fluid-filled thrust arm bushings crack and tear causing the BMW to vibrate at speed (0) (1) (1) (2) (3) (4) (5) (6) (7) (8) & a comprehensive TireRack vehicle vibration diagnosis chart (1) (jpg) with wheel match mounting hints (1) & how a worn drive shaft, flex disc, center bearing, or "giunti Boschi", aka giubo (it's not spelled guibo although it sounds like it is to some) can cause the vehicle to vibrate (1) (2) (3) (4) & how to repair the rear driveshaft seal by the differential (1) & how to repair the inner constant velocity (CV) half-drive shaft (1).
Old 02-28-2013, 12:35 PM
yes it was .. still have copy from dealer
