Old 02-26-2013, 07:10 AM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Walnut shell blasting before and after
Just wanted to show you guys a couple of pictures.
I've had some problems with drivability and the dealership replaced all plugs, coil #2 (cylinder #2 misfire codes + half-engine symbol) and eventually a BMW Corporate good-will replacement of all 6 injectors. Made the problem much better, but didn't go away completely.
Car was in the shop for other reasons, so I had them do a walnut shell blasting.
I should get the car back tomorrow or Thursday, so we'll see how it drives differently.
In any case, I think I'll simply have this done every 3 years (~36k miles) as preventative maintenance.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 02-26-2013, 07:14 AM
///M-Furby's Avatar
///M-Furby ///M-Furby is offline
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
So they blast the inside of the car with walnut shells? Wow, in all my years never heard of that. But it would be a great way to clear out hard to get sludge/debrii.
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 02-26-2013, 07:51 AM
SuperTerp SuperTerp is offline
Mein Auto: m4now M5M3 550 760 335RIP
It'll help, trust me. I'd get some weird rumblings/grumblings and now perfect.
Yours do look bad.
Old 02-26-2013, 08:00 AM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
My car just hit 32k miles. I guess I'll be doing it some time this year.
The SES light came on in my car a a few weeks ago with a cylinder #1 misfire code, and after several days at the dealership, they determined it was a bad injector, and a bad coil, so they replaced 3 injectors, 3 coils and 3 spark plugs (everything on bank 1). So far, after about a thousand miles, everything is OK.
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 02-26-2013, 08:09 AM
jbyron jbyron is offline
Mein Auto: 08 335ix Sport
How much does the dealer charge for that service?
jbyron
St. Louis, MO
2008 335xi Sport
50,xxx mi
1999 540i Sport - Retired w/202,xxx
1997 540i - Retired w/162,xxx
Old 02-26-2013, 08:40 AM
galahad05's Avatar
Better with Butter
Mine was about $750.
-- Irish Proverb
Old 02-26-2013, 08:41 AM
$700 - $800, but a reputable indie shop that has the equipment will *probably* do it for less.
Previous BMWs:
Old 02-26-2013, 08:47 AM
napoleon's Avatar
napoleon napoleon is offline
Cloud Climber
Mein Auto: 328I conv montego blue
Walnut shells were used to clean th inside of a jet engine years ago.
l
Old 02-26-2013, 10:31 AM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
Apparently there is a design flaw with these engines. It is not acceptable that the intake ports should accumulate deposits to that degree in the amount of time listed. I have only been reading the posts here for the last month or so but I have seen this issue come up too many times.
Is this restricted to the 335i model? I have only seen it mentioned by 335i owners.
This would be especially strange since the 335i has direct injection and the only thing that should be flowing through those ports is air.
It could be a crankcase ventilation issue. Oil vapor from the crankcase is recirculated through the intake system in most engines for emissions purposes (PCV Positive Crankcase Ventilation). Perhaps this vapor is condensing in the ports to form this crud.
Also since the 335i is a turbocharged engine it is possible that the elevated pressures and temperatures of the air charge are causing the oil vapor to form these deposits.
I recently rebuilt a 4.2 liter V6 from a 2002 F-150 with 108,000 tough miles. The engine had been badly neglected by the previous owner to the point that the engine spun a rod bearing.
While the lack of oil changes had caused severe oil sludging of the areas of the engine that see oil, the intake manifold and intake ports were MUCH cleaner than the intake ports of these BMW 335i engines with one third the mileage.
Something is very wrong with that picture!
Old 02-26-2013, 11:18 AM
This is not a BMW issue this is a direct injection issue. You can see gross intakes on lexus forums, mazda, exc.
Old 02-26-2013, 11:23 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Smart.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 02-26-2013, 11:32 AM
I wonder what it is about DI that is causing this issue? Maybe since port injected engines have fuel flowing through the ports it keeps the intake ports cleaner?
Old 02-26-2013, 11:36 AM
Maybe they could develop a crankcase ventilation system that didn't send oil vapor through the intake ports. Perhaps some sort of filtration system to clean it first.
In the old days (pre-emission era) these oil vapors were just vented to the atmosphere.
Old 02-26-2013, 11:46 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Good write up here:
http://www.edmunds.com/autoobserver-...-adopters.html
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 02-26-2013, 11:52 AM
thekurgan's Avatar
Bad Lieutenant
Bingo... and over the valves.
Ilse
Bruna
BMWCCA #453648
Old 02-26-2013, 12:56 PM
Originally Posted by laser View Post
Great article Laser.
It sounds like the newer DI engines have solved the issue with designs that optimize injection timing events and different combustion chambers designed to prevent carbon build up.
Bummer for the folks that have the older DI engines though. I wonder if some retro-fit can be implemented to solve the problem?
Old 02-26-2013, 01:24 PM
galahad05's Avatar
Better with Butter
I've heard about people using a new class of higher-flashpoint motor oils to minimize (eliminate?) this problem. This would be a good start on these older-style motors.
-- Irish Proverb
Old 02-26-2013, 02:04 PM
unrealii unrealii is offline
Mein Auto: 2009 335 6MT 'vert
The best I have seen is adding an oil catch can. That will reduce the carbon, but not eliminate it.
2009 335i 6MT M-Sport AW/CR Convertible
2002 Toyota 4Runner 4wd
Old 02-26-2013, 03:00 PM
F32Fleet F32Fleet is offline
Account closed at users request
Mein Auto: 435i, 335d sold.
Lubrizol released a presentation on LowSAPs oils a few years ago and one of the benefits was lower intake deposits. Lubrizol is an additive company.
Sent from my MB525 using Bimmer App
Old 02-26-2013, 05:47 PM
Kilgore Trout's Avatar
Kilgore Trout Kilgore Trout is offline
Chicks dig Wagons!
Mein Auto: E91
What do they do with the actual walnuts afterwards? I like walnuts.
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons
Old 02-26-2013, 07:35 PM
My Indy says they can get two uses out of the shells so he sucks them up with a vac and uses them one more time. The nuts get a burial ceremony.
Old 02-26-2013, 07:36 PM
Hehe, I'm pretty sure that the shells come pre-crushed without the walnuts. But if you find out that some of these repair places are husking walnuts themselves and discarding the walnuts...
...let me know.
I like walnuts too.
Old 02-26-2013, 07:56 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Thanks for reminding me Galahad - have a customer, major mfg of engine oil. Gotta ask 'em about this.
Can't hardly believe all the questions here....ya'll would benefit from a bit o'hunt 'n' peck....massive info available on this issue, just for 335i.
HERE is a walnut shell DIY, an old favorite. Have the equip myself, just itchin' to take mine apart!
Old 02-26-2013, 07:58 PM
My hands are too silky smooth for manual labor
Old 02-26-2013, 08:02 PM
An impingement filter, should remove nearly all of the liquid phase.
But! There is a gas phase the may be coking on hot valves. Call me nuts, or call me crazy, but shouldn't that be condensable?
How boutcha Texas chemists?
