Where are you learning how to use Rheingold? - Bimmerfest - BMW Forums
Old 02-09-2017, 02:35 PM
n8s 330xi n8s 330xi is online now
Ridin' the wingless plane
Mein Auto: 2010 550i GT
I'm going to need to program my idrive controller to the correct car first, but I'd really like to know of common good things to do as well. Is there a recommended site or anything to check out?
2001 330xi
2001 540iA Nav/DSP/Cold Weather/Sport
2008 550i Cold Weather/Sport/Auto/Comfort/Sunshades/Heated Rear Seats/High Beam Assist/Lane Departure/Nav/HUD
2009 335i x-drive
2010 550i GT - Cold/Lane Departure/Nav/HUD/Power seats, back and trunk
Old 02-10-2017, 02:53 PM
vini_079 vini_079 is offline
Mein Auto: '05 BMW 525i
I got Rheingold couple months ago and the more you use it, the more you get the grips of it. It's definitely not your usual piece of software GUI.
There are few basic functions on the internet like registering the battery, etc, but based on my experience you'll have to play with it yourself.
Comes very useful when car throws a fault, you click that and the software gives directions on what exactly you need to check.
Sent from my iPhone using Bimmerfest mobile app
Old 02-10-2017, 02:59 PM
Thanks. I'm having a hard time even getting the damn thing to connect in the first place. Really frustrating. I'm no slouch when it comes to general IT stuff, but I'm a half step away from telling them to take this **** back.
I keep getting an error when the system is reading my car's config:
94201: Technical service initialization failed
-2 Global.Unknown
55054 Global.Unknown
63014: (CASTOR) - Fault when executing a PSdZ function
Ever run into this?
2001 330xi
2009 335i x-drive
Old 02-10-2017, 08:05 PM
Google is your friend
Old 02-10-2017, 08:09 PM
A friend that isn't much help. I've reset the car, tried a different computer, verified I'm getting an IP and everything. Just no dice.
I'm gonna keep working on it, but I suspect it's because of the used idrive controller I put in. BMW said I'd need to get it programmed, but it worked as soon as I attached it. That may be because it was already programmed for a 750. It's hard for me to believe it's much more than a glorified joystick, but maybe so.
2001 330xi
2009 335i x-drive
Old 02-11-2017, 06:03 AM
fmfm fmfm is offline
Mein Auto: 2011 523i
Make sure that you move the files with .sqlite extension to this directory
C:\Program Files\BMW\ISPI\TRIC\ISTA\SQLiteDBs
And ISTA-D is for diagnostics only, coding can be done through e-sys
Old 02-11-2017, 07:00 AM
Thanks! I'll give that a try.
I got ista/p, which I thought could code as well?
**Update: Not finding any SQLite files when I do a search. I found another thread that seems to be suggesting a static IP and to update the timeouts on ediabas.ini, so I'll give that a try.
2001 330xi
2009 335i x-drive
Old 02-11-2017, 05:58 PM
daders's Avatar
daders daders is offline
There is no spoon
Mein Auto: 2010 F07 550i, 2009 B8 A4
I'd suggest PM'ing Reclaimer, he seems to know a lot on this topic.
There's no need to panic until it is time to panic.
Old 02-11-2017, 07:38 PM
Will do. Thanks! Interestingly enough, turns out I can't ping the IP it seems to think the car is at. I'm trying to think back on my server admin days to a way to discover all IPs connected, because I definitely don't want to try a ping sweep or something on a /16 subnet. It makes me think if it's not the IP, there's something wrong with the emulation.
2001 330xi
2009 335i x-drive
Old 02-12-2017, 02:01 AM
The car has static IP so i guess no need for sweep, ista/p is tricky to work with, add to that early versions of ZGW have issues communicating through e-net cable and needs ICOM.
