Old 01-10-2017, 04:17 AM
demas demas is offline
Mein Auto: F10 550i M-Sport
Sport+
What's the point of this option - I mean BMW codes it to force the car into comfort mode?
Does anyone really use it?
/rant
Old 01-10-2017, 05:41 AM
hufington's Avatar
hufington hufington is offline
HUFINGTON
Mein Auto: '16 BMW 550xi F10
I use it everyday.
16 BMW F10 550xi - 4.4 L 330 kW (445 hp) Fully Loaded w/ ZLL,ZCW,ZDH,ZLP,XDB,ZEC,ZLS,2TB,0456,S6UKA,6NS[/COLOR]
13 BMW F10 535i RWD - 3.0 L 221 kW (300 hp)
07 BMW E64 630i - 3.0 L 200 kW (272 hp)
03 BMW E65 745i - 4.4 L V8, 242 kW (325 hp)
98 BMW E39 535i - 3.5 L 183 kW (245 hp)
95 BMW E34 540i - 4.0 L V8 210 kW (282 hp)
89 BMW E30 M3 147 kW (200 hp)
17 MB C217 S550 4MATIC Coupe
10 Infiniti G37x Sedan
09 Mercedes C 350
08 Infiniti G35x Sedan
04 Mercedes CLK 350
01 Mercedes C 230
Old 01-10-2017, 06:47 AM
jjrandorin jjrandorin is offline
Mein Auto: 435 Grand Coupe MSport
I dont understand the question, actually.
The sport+ mode allows the wheels to slip (burn out) if one desires to do that. Note, some people think it turns OFF the traction control and stuff, and I have it straight from BMW drivers at the Performance Center West that it does NOT do do that. What it does, is allow some wheel slippage etc, and more aggressive driving. Traction control is actually still ON just relaxed.
Turning traction control off requires pushing the dsc button for something like 10 seconds.
2016 435 Grand Coupe Estoril Blue MSport |Hex. EB Trim-Blk. Dakota | MSoort | Technology | Drivers Asst. | Drivers Assist+|Lighting |Track Pack W/ 442 Wheels |Heated Frnt Seats | Smartphone Integration | HK Stereo (His)
2016 X5 XDrive35d Space Grey |Blk Dakota W/ Fineline Oak | MSport | Lighting Pack | Premium Pack | Drivers Assist | Drivers Assist + | ACC W Stop N Go | 20" Wheels| Smartphone Integration | Multi Contour Seats | HK Stereo (hers)
BMW CCA #477341
Old 01-10-2017, 07:17 AM
Daniel535i Daniel535i is offline
Daniel T
Mein Auto: 2012 BMW 535i F10
I have the 535i F10 and using sport+ has a very noticeable throttle response and quicker gear change - it also allows me to use launch control but if you need to get out of a situation quick make sure manual mode in the gear selector is placed back to adaptive.
F10 535i BMW
Old 01-10-2017, 07:38 AM
MDesmond MDesmond is offline
Mein Auto: 2009 328i, 2014 535i Sdn
In the 14 535, I've got to push extra buttons to get to a Sport + mode
Bat outta' hell mode
2014 535i Luxury Line (Dinan Sports Performance Tune, MSport Pedal Set, ACS Springs, Koni FSD, Michelin A/S 3+, BavSound Stages 1 & 2)
Old 01-10-2017, 09:52 AM
When you follks are in Sport+, does that retain the Sport chassis and drivetrain settings? Mine seems to revert them back to Comfort. It feels softer and also the 'Sport' designation at the bottom of the speedometer reverts to blank ie, when it's in Comfort.
I've got Dynamic Damping, IAS, the works and it's a Euro spec so I wonder if that has anything to do with it.
I'll experiment a little more with it just never been impressed the few times I used it.
Old 01-10-2017, 09:57 AM
pkfinman pkfinman is offline
Mein Auto: 16 550i + 15 911 GTS
In my 16 550 M Sport it does not switch to comfort... mine keeps the Sport setting
Old 01-10-2017, 11:28 AM
Carbon Fiver Carbon Fiver is offline
Mein Auto: 2013 535i M-sport
Does your dashboard show "Sport+"?
Are you using the rocker switch (Comfort/Sport) two taps to Sport+, or are you pressing/holding the DSC button? Your description of the car behavior sounds like you're using the DSC button - which if you hold down WILL turn off both DSC (Stability Control) and DTC (Traction Control), AND revert the chassis settings to Comfort. Why BMW does that is a mystery. To get Sport+ you should be doing two taps of the Comfort/Sport rocker switch, which should then show in your dash as Sport, then Sport+ on the second tap.
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, Sport Auto, Driver Assistance Pkg, Premium Pkg, Multi-Contour Seats, Heated Seats, Navigation, H/K stereo. Michelin Pilot Super Sport non-runflats, M5 grille, Painted reflectors from IND.
Old 01-10-2017, 11:54 AM
BimmerLifer BimmerLifer is offline
Afficianado
Mein Auto: '13 335i Sport '12 535i M
Wow. I had never done sport+ because I thought it was just sport without traction control. Excited to try this.
Old 01-10-2017, 04:40 PM
Ok just checked on my way to the office. Weird my sport settings had chassis set to normal. But I think carbon fiver nailed it. It's the DSC disabling which I was thinking about. Will check again after work.
Yes I used the rocker settings with two taps up the other night.
Old 01-11-2017, 06:02 PM
anuts anuts is offline
Mein Auto: 2013 535i M Sport
Doing this action also seems to take car out of Sports mode altogether. Once the dash reads DSC Off you're back into Comfort mode. If you press Sports mode again it puts the DSC back on. At least in my car.
I cannot be both in Sports mode or Sports+ mode and have my DSC actually off.
Old 01-11-2017, 06:49 PM
Jamolay Jamolay is offline
Mein Auto: 2014 328xd Wagon
Isn't the difference between sport and sport + just that? In sport + DSC is off and TC on by default.
Old 01-11-2017, 06:59 PM
That's true, but it's not what he's trying to do. He wants to have both DSC and DTC off (no nannies at all - full manual control) along with the Sport chassis/drivetrain settings (suspension, throttle response, shift response). I went through this too when I got my 535i - it's not possible. It seems counterintuitive that BMW designs it that way. I'd think that someone who is turning DSC/DTC off is using it for track or similar where you want full control of the car for spirited driving, and you'd want to be able to have the Sportiest chassis/drivetrain settings. With DSC/DTC off the car reverts to Comfort settings - the only Sportier thing you can do is put the shifter to M/S.
Old 01-11-2017, 08:07 PM
Above is correct and I found a link that includes what is supposed to be a BMW response although they only address their rationale for the accelerator being reverted to comfort.
http://f30.bimmerpost.com/forums/sho...php?p=21023803
Old 01-11-2017, 08:12 PM
That's how I originally understood it. But while actually driving in one or the other if my tires start to slip it will activate and I'll get that same yellow car slide notification and the rpm's will subsequently drop until traction is regained.
There is no discernible difference in either mode. Maybe it's just my car though.
