Old 02-26-2013, 01:14 PM
shinkamui shinkamui is offline
Mein Auto: 2009 335i
335i glovebox usb, but not in center storage?
I just bought a 335i 2009 which appears to have i-drive v2 (single dvd drive in console, music RIP option in navi which has split screen). After some research i discovered i have a usb port in the glove box, but none in the center console. How costly would adding the center usb port be? Is there a diy or am i looking at heafty stealership pricing? Any tips/advice/links would be very most appreciated.
On a side note, I find voice command doesn't understand what im saying most of the time. I have no accent and speak clear english, so if anyone has some tips there as well, i'd love to hear them.
Old 02-26-2013, 01:32 PM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
All those things you mentioned I have too single disk drive, rip, and split screen mine is in the center console.
Old 02-26-2013, 01:37 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
I have never seen a center console USB addition if it didn't come that way from the factory. I expect it would be pricy. I have one in my (non-IDrive) 2009. It was a specific option that had to be added to allow playing MP3s from a USB stick (it was option 6FL, the "iPod and USB adapter", $365).
I have voice command on mine. Used it for the first 6 month to a year, then got so tired of having to repeat myself at a full shout that I haven't used it in the last 2.5 years.
Old 02-26-2013, 02:10 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Originally Posted by Zooks527 View Post
It [the console USB port] was a specific option that had to be added to allow playing MP3s from a USB stick (it was option 6FL, the "iPod and USB adapter", $365).
This.
Originally Posted by shinkamui View Post
I just bought a 335i 2009 which appears to have i-drive v2 ... How costly would adding the center usb port be? Is there a diy or am i looking at heafty stealership pricing?
It's actually the 4th generation iDrive but who's counting?
Search this forum and on E90Post for "combox retrofit." That should get you started. It is neither easy nor cheap and a dealer typically cannot help you. (In general, any kind of electronics retrofit on a modern US-spec BMW requires a good supply of ingenuity, bravery and ready cash. It's easier in Europe, for all the good that does you. )
Use good, clear diction. Speak at a normal, moderate pace; avoid slurring words but do not over-enunciate. If you have a high error rate and your normal speaking voice is somewhat high- or low-pitched, try changing your pitch a bit. By "no accent" do you mean no foreign accent (i.e., that of a non-native English speaker) or no regional accent (e.g., deep South, New England, Chicagoland, etc.)? Both can be problematic--the system works best with a truly neutral accent. Try to sound like a Nebraskan. Irregularities in vowel sounds and syllabic stress can trip it up (often with comic effect).
Also important: Minimize background noise (close sunroof & windows, avoid max fan speed on HVAC blower, etc.) and avoid stray sounds (such as coughing/sniffling, throat clearing) while voice command is active.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 02-26-2013, 05:16 PM
Kilgore Trout's Avatar
Kilgore Trout Kilgore Trout is offline
Chicks dig Wagons!
Mein Auto: E91
I've never had anything to do with retrofits. I have USB installed from the factory. But, a quick google search revealed the attachment.
Good luck.
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons
Last edited by Kilgore Trout; 02-26-2013 at 05:44 PM. Reason: Reason? I don't need no stinking reason. I'll edit whatever I want! And, you can't stop me!
Old 02-26-2013, 05:22 PM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Hey, you are from League City .... she speaka de German ..... maybe if you were from New Braunfels ......
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 02-26-2013, 08:06 PM
Thanks for all the replies. Im bummed out that its gonna be something unnecessarily hard. Ill keep looking at options, but at this point, i think the DVD mp3 disks + leaving my phone in the glove box for long trips will have to suffice. As far as the accent, you raise a good point, however, i have no "colloquial" american accents, if that makes sense. Anyway, i've already pretty much resigned myself to using voice command for nothing more than switching modes. Appreciate all your answers guys, what a great forum!
-Sean-
Old 02-26-2013, 10:21 PM
sptt144's Avatar
sptt144 sptt144 is offline
Don't worry! Soon you'll start having all the other repair issues that the USB thing won't even come to mind!
2009 335i
Old 02-27-2013, 05:20 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Anyone with a hobbyist's knowledge of electronics can knock this together for a dollar or two in parts. Not an understatement.
But....do your want a thumb drive stickin' out, ready for damage? 'Course there are button USB drives, now 15 gb+ -- yeah, there's a solution. Nice li'l LED to feed ya back, too.
If you START HERE, you may open the doors of perception to a diff reality! Good luck to ya!
