E36 (1991 - 1999)
Old 02-26-2013, 02:40 PM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
My BBS-RS723 Refinish
Well came home today and I was happy as can be four boxes
Here are a couple pictures of the staggered setup current condition etc.
( Yes my cat manages to find a way into almost every picture)
ID:	363993   Click image for larger version
ID:	363994   Click image for larger version
95 Avus M3- Now with Supercharger.
Old 02-26-2013, 02:41 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Sexy.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 02-26-2013, 02:42 PM
Santa
Mein Auto: 95 M3
Step Two- Tear down begins and required tools.
You need an 8mm Triple Square ( 12 point) Bit. I got mine at Carquest was right around 8 dollars.
Also I picked up a deadblow hammer from Lowes thing worked like a champ.
I wrapped most of the ratchet in electrical tape as well as the bit/socket to prevent any damage that might take place if I was to slip.
ID:	363996   Click image for larger version
Old 02-26-2013, 02:45 PM
Santa
Mein Auto: 95 M3
If you haven't figured it out yet I have absolutely no clue how to break up a single post pictures wise....
Step Three- Tear Down Bolts....The ones on mine came out easily and were powder-coated as well by the looks. All in all the rims are in awesome condition.
I'll attach some pics showing all the metal flake on the barrels.
EDIT- Couple of things I've figured out thus far.
1- If you are doing these by hand....it's tough.... I've had to pretty much center my body over the ratchet and do slow turns about 1 per swing on the hard ones. This paired with CRC Freeze off made it "fairly" easy. These titanium Studs/Bolts are pretty tough haven't stripped or snapped one yet.
2-CHECK YOUR BIT! I accidentally had my arms angled too much on two swings and rolled off the bolts by accident. To fix / ensure i wouldn't strip by accident I pulled out the diamond file and ground the head of the bit down a little bit to reshape the 12 points to a finer edge.
ID:	363998   Click image for larger version
ID:	363999   Click image for larger version
ID:	364000   Click image for larger version
ID:	364001   Click image for larger version
Old 02-26-2013, 02:48 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
Refinishing plans?
Old 02-26-2013, 02:49 PM
Santa
Mein Auto: 95 M3
Step Four- Popping out the centers....This was a PITA and actually took some good swinging to get them to pop...Turn the rim over so the center face is down. I used my dead-blow hammer wrapped the face in electrical tape ( added a little cushion) and started swinging. It took a good 6-7 swings.
And of course get a jar to stay organized
Edit- One thing on this step
1- Make sure to spin the rim and hit right on the edge of where the roundel is. One hit over each of the lug holes on the next two rims made the centers pop out much easier.
ID:	364004   Click image for larger version
ID:	364005   Click image for larger version
ID:	364006   Click image for larger version
ID:	364007   Click image for larger version
Old 02-26-2013, 02:50 PM
Santa
Mein Auto: 95 M3
Originally Posted by Shigeta View Post
Refinishing plans?
Changing that Gawdy white to Gold most likely..... I think gold and blue would be a nice contrast for my ride Possibly redo the bolts as well not sure....Open to suggestions!
And thanks Bimmer
Old 02-26-2013, 03:03 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Good for you. I don't like 2-piece wheels, but I'm not as cool as you.
You either have small wheels or a very large cat.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 02-26-2013, 03:26 PM
hornhospital's Avatar
D'oh, You Kids!
It's a huge cat. 25lb+ Maine Coon.
Loving the step by step
Quotes to live by:
Old 02-26-2013, 04:31 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
I'm working on a square set right now (17" x 8"). Found a triple square bit set (6,8,10,12mm) at Northern Tool for $4. this wheel set was a bargain set that has seen mucho salt. Two days of PB Blaster soak, a 24" breaker bar, and much prayer to not snap off the head of one of the bolts and I've got them all broken loose on the first wheel. I'm tempted to try the electric impact on wheel number two in the hopes of reducing the chance of snapping a bolt head off.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-26-2013, 05:11 PM
Santa
Mein Auto: 95 M3
He is an enormous cat...... more like a dog plays fetch and all
I'm doing all mine by hand rim 2 and 3 have taken almost two hours :/
Holy smokes 4 bucks! The set i saw at Carquest was like 36!
Old 02-26-2013, 05:23 PM
dc_wright's Avatar
I'm not so much worried about the amount of time it's taking, more so the amount of torque I'm having to apply with the breaker bar to get the bolts to release. With the impact the high frequency vibration from the impacting makes loosening the bolts take less torque in theory.
Your wheels have a great finish to start with so they should come out looking really fine after you've finished them. I've got quite a bit of work to strip off peeling clear coat and sand/polish off the corrosion on the bare alloy.....
Whatever you decide on your color scheme don't do this......
Old 02-26-2013, 05:25 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
^What the what?
1998 BMW 328is
1966 Pontiac GTO
Old 02-26-2013, 05:27 PM
Santa
Mein Auto: 95 M3
Originally Posted by ZeGerman View Post
^What the what?
I don't know what that is .....are those the rims off that z3 that started on fire?
DC Soak the heck out of them in PB only thing that makes these harder then fives is the fact that you really cant get to the threading . You have to try and start them then crank some PB in there feel free to throw up pics of yours to DC
Old 02-26-2013, 05:30 PM
Shigeta's Avatar
Old Soul
Wait... Is that a granite finish?!
Old 02-26-2013, 07:29 PM
dc_wright's Avatar
Sort of like a faux granite with some orange spots mixed in that didn't show up in the cell phone shot. Ugliest a$$ wheels I've ever seen. Saw them at a rim repair shop while I was waiting on them to finish my wheels. Don't know how they got them but they've had them for a while....surprise, surprise.
Here's what I'm working with. One is representative of the set I bought and the 2nd photo is of the replacement wheel for the one FedEx lost.
ID:	364050   Click image for larger version
Name:	replacement wheel.jpg
Old 02-26-2013, 07:45 PM
Santa
Mein Auto: 95 M3
Thought about your bolts yet DC? I think I'm stripping all the paint off.....then polishing on the wire wheel, and then buying some clear engine enamel.Going to have to make a stand and spray them all quick so they don't oxidize. The results are supposed to be rock hard. Just have to be careful not to lay to heavy for fear of not being able to fit the triple square back in.
Old 02-26-2013, 08:01 PM
dc_wright's Avatar
I'm just hoping to get 'em all out intact, then I'll worry about how I'm going to refinish them.
Old 02-27-2013, 02:45 AM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Good luck bro, I did mine in about 2 weeks, but I didn't touch the lip at all.
These are easy wheels to work with though, I tried to take apart a style 5 but at the end didn't feel like it
Old 02-27-2013, 05:51 AM
Santa
Mein Auto: 95 M3
Good luck mine were tough and there not even beat
Attachment 364096
Interesting combo red bolts? what'd you do to paint them?
Old 02-27-2013, 07:06 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
I actually don't mind the white.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 02-27-2013, 07:12 AM
Santa
Mein Auto: 95 M3
Wouldn't go with my car at all though it has way too much black. I mean In general it's not bad but, gold is just better .
Also Looking into getting the Bolts Titanium Nitride coated ( would give that bright gold color to them.)
Old 02-27-2013, 11:31 AM
Hellawut??
Mein Auto: who knows?
whats the offset on these?
-Franklyn
Old 02-27-2013, 12:11 PM
Santa
Mein Auto: 95 M3
Et-41 ----17x7.5 and 17x8.5 Don't have to buy hubcentric rings but I do have to buy 1inch thick spacers
Old 02-27-2013, 12:12 PM
petriej's Avatar
Are you sure? 25mm spacers are HUGE.
GGC BMW CCA #443004
Join the BMW CCA!
