E36 (1991 - 1999)
Old 02-27-2013, 12:13 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Why do you need such crazy spacers? What kind of suspension are you on? Those are the exact same wheel specs as the OEM M3 wheels. Should fit perfectly on a non-coilover suspension, and if you are on coilovers, you should only need a very thin spacer on the front, if at all.
1998 BMW 328is
1966 Pontiac GTO
Old 02-27-2013, 12:14 PM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
15mm in front 25mm in the rear I double triple checked the math
It's all Franklyn's fault Ze ask him.
I used this too just to check http://www.1010tires.com/WheelOffsetCalculator.asp
You guys positive? Because I still am clueless as to how the offset works....I thought the offset means the rim is back set into the tire well more.... Also since the style 5's are et20 I figured I'd want to come closer to that? Please shed some light on this guys
Lots of junk.
Old 02-27-2013, 12:45 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
I use 12 or 15mm up front...can't remember, but thats with my dsII's at et40 I believe.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 02-27-2013, 12:51 PM
Santa
Mein Auto: 95 M3
How about in the back?
Lots of junk.
Old 02-27-2013, 12:53 PM
B1MM3R's Avatar
Jesse Moon Bayne
I have no spacer in the rear. If I did my fender would be sitting on the tire.
Jesse
2001 330i DD
Old 02-27-2013, 01:11 PM
ZeGerman's Avatar
Warm Leatherette
All of the stock wheels for '96-99 E36 M3s (contour, DSII, LTW) were 17x7.5" et41 (front) and 17x8.5" et41 (rear). If your wheels match those specs as you previously stated, you will not need spacers of any sort unless you are lowered on coilovers. If on coilovers, the only place they will potentially rub will be the front c/o lower spring perch. The rears will not rub no matter what if you use normal (i.e. not over-sized) tires. BTW, OEM tire fitment for the wheel dimensions I mentioned are 225/45 (front) and 245/40 (rear). If you go with that setup, you'll be running the exact same wheel/tire dimensions as a stock '96-99 M3.
Style 5s are et20, so they stick out a lot more than et41 wheels. In the case of Style 5s, fender rolling becomes the main issue due to rubbing on the outside, not inside. Don't know why you would reference Style 5s though, since they have a totally different offset than what you have on your hands. They aren't' something you should be basing your calculations on.
And just for reference, my wheels are all 17x8.5" et40 (so they stick out 1mm further than stock M3 wheels) and I run 245/40s at all four corners with no spacers, and no rubbing.
1998 BMW 328is
1966 Pontiac GTO
Old 02-27-2013, 01:22 PM
Santa
Mein Auto: 95 M3
215's up front 235's in the rear for me then? Trying to get everything together and this is why I ask so i don't spend 180 bucks on stuff that i don't need...Rather ask then loose money Or whats your opinion on what I should run in front and back Ze?
Lots of junk.
Old 02-27-2013, 01:28 PM
ZeGerman's Avatar
Warm Leatherette
No. If your wheels actually are 17x7.5" et41 (front) and 17x8.5" et41 (rear), just run the OEM M3 tire specs (225/45 (front) and 245/40 (rear)).
1998 BMW 328is
1966 Pontiac GTO
Old 02-27-2013, 01:45 PM
Santa
Mein Auto: 95 M3
Stock at the moment soon to be coil-overs. Why the change in sidewall height for the fronts? 45-40
Lots of junk.
Old 02-27-2013, 02:05 PM
B1MM3R's Avatar
Jesse Moon Bayne
larger fender well, height wise.
Jesse
2001 330i DD
Old 02-27-2013, 02:16 PM
ZeGerman's Avatar
Warm Leatherette
And because if you went to a 225/40 and kept the rears at 245/40, you get a speed discrepancy of 2.6%. Alternatively, if you kept the fronts at the OEM size of 225/45, but then went to 245/45 in the rear, you'd get a speed discrepancy of 2.8%. The 225/45 & 245/40 combo yields the smallest speed discrepancy possible (1%) given the tire dimensions available.
1998 BMW 328is
1966 Pontiac GTO
Old 02-27-2013, 02:24 PM
Santa
Mein Auto: 95 M3
Awesome I'll stick with those sizes then. thanks Ze and Bimmer . I'll just get the tires and rims together and buy spacers after I test fit them. But still a lot of work before that ...Tire rack has a sale on Fuzion ZR1's Can get the tires I need for a mere 300 bucks
Lots of junk.
Old 02-27-2013, 02:48 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Direzza Star Spec Z2! But you live in Buffalo, so you get real weather. I would advice a different tire, then.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 02-27-2013, 02:57 PM
Santa
Mein Auto: 95 M3
I rock Firestone's in the winter full studded . Summer isn't to bad usually dry pavement and it probably rains about once a week or less (typically) .Those Fuzions have great reviews for the price either that or Sumitomo HTR Z II's they are a little more but seem to be in the same range.I bought ultra all seasons last year and regretted it a little they were not as aggressive as i would've liked.
Awesome you didn't have to do the math but i appreciate it lol. I'll stick with those more progress on the rims tomorrow night I hope.
Lots of junk.
Old 02-28-2013, 08:36 PM
Santa
Mein Auto: 95 M3
Cleaned the bolts for a solid few hours tonight still only 3/4 done
Did an epoxy and paint thinner bath overnight peeled the powder-coat right off. After my fingers started turning white and borderline bleeding from the chemicals I decided it would be a better idea to use some needle-nose to pull them out. Doing the final thread cleaning and getting the rest of the yellow off with cue tips at the moment.
ID:	364324   Click image for larger version
ID:	364325   Click image for larger version
ID:	364326   Click image for larger version
Lots of junk.
Old 02-28-2013, 08:53 PM
Hellawut??
Mein Auto: who knows?
You are going stances with your car arent you?
That is what ALL my basis for spacers were based on.....
-Franklyn
Old 02-28-2013, 08:55 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
I've got 3 of the 4 centers out. First one was the most corroded so it took the most work. Two nights of PB Blaster and whacking on it finally got it broken loose. The other two took about 20 minutes total. Go figure.....
Hope the 4th follows suit.
This is what I'm facing on the barrels.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-28-2013, 09:02 PM
Hellawut??
Wow those might actually be worse than mine dc!
-Franklyn
Old 02-28-2013, 09:06 PM
dc_wright's Avatar
Fortunately the centers are in pretty good shape so most of the work is on the barrels......
Old 03-01-2013, 12:30 AM
Hellawut??
Tis how mine is too
Sent from my Desire HD using Bimmer App
-Franklyn
Old 03-01-2013, 06:07 AM
Santa
Mein Auto: 95 M3
Yes Rokkors that's gonna be after the rims though... So spacers can wait till after
DC those look rough....hand polishing? Franklyn I still haven't seen your fives yet.
Lots of junk.
Old 03-01-2013, 09:36 AM
Hellawut??
Yeah. When you go to install your rokkers just put a few washers around the lower bolts. Then you should clear the lower perch.
-Franklyn
Old 03-01-2013, 09:44 AM
Santa
Mein Auto: 95 M3
Alright man I'll make sure i remember that
Ordered the paint.... Supposed to be as close to bbs gold as you can get without getting it straight from Germany. I've already got the clear as well going with a two part 2k clear.
Lots of junk.
Old 03-01-2013, 10:39 AM
dc_wright's Avatar
This is what I used when I painted my style 30s. The Eastwood looks pretty close to the same shade/texture gold.
Old 03-01-2013, 11:17 AM
Santa
Mein Auto: 95 M3
Yeah some people said Grimm was a little off Eastwood had great reviews...judging by that though it looks darn close. You clear coated?
Lots of junk.
