Old 02-26-2013, 05:27 PM
tjc1324 tjc1324 is offline
Mein Auto: 1995 540i Msport
Compatibility of Nav system
Anyone know if the nav system and radio/monitor from a 2003 X5 would fit and work in a 2001 E38? I think the nav is MKIV but not sure if the monitor portion is compatible. Thanks in advance!
Old 02-27-2013, 02:58 AM
BMWFatherFigure's Avatar
Old School
If screen aspect ratio is the same and they are both the same colour type then probably yes. Problem could be differently wired plugs - same functions but on different pin numbers. Check out those B 4 you risk plugging it in.
Current:
E38 Parts Car
Previous:
Old 02-27-2013, 07:03 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
+1 the monitor. These are often advertised as fitting a variety of vehicles, but UK X5 monitors do not fit UK E38! Other market monitors are all left hand drive so will physcially fit L/H e38. The Mk IV nav will work fine-simple plug n play, nothing else needed.
Old 02-27-2013, 07:20 AM
speedkingrc speedkingrc is offline
Mein Auto: 88 BMW 735i
Depends on where you at.. over here the x5 and 5 series radios and navs well fit in a e38... also a range rovers too.. check 5 series is 95-01 and x5 its 97-01 and range is 95-01. i think **** i got it written down. i called a bmw dealer here.. they told me plug in plug. but u will have to go to them to get the codes put in so it will all work right... im going aftermarket
Old 02-27-2013, 12:33 PM
Mein Auto: 750iL
Exchange of monitor and/or nav does not require re-coding
Old 02-27-2013, 02:44 PM
QSilver7's Avatar
QSilver7 QSilver7 is online now
the amp is what needs to be coded...the e38/e39/e53 all use the same amp, but it is coded based on the equipped options & parameters of each vehicle. A used amp from an e39 put into an e38 or e53 will work, but the sound will be muddled because it is set-up for the interior dynamics of the 5 series...not the 7 or X5.
Q {BMW CCA Member #191509}
(SOLD)
Old 02-28-2013, 09:06 PM
yep
Old 03-01-2013, 12:07 PM
Thanks to everyone for the input
Old 03-02-2013, 05:44 AM
welcome
HTML code is Off
