Old 02-26-2013, 05:55 PM
lovett9565 lovett9565 is online now
Mein Auto: e39 530i 300td
Purge control valve vac hose help!
Hi all thanks for all you do and all the info on this site. I'm in the process of restoring my 2003 e39 530i. I bought it in 2006 with 33k and now it has 225K. A new house and a layoff has forced me to put maitnence on the back burner for a while. Little by little i'm working on getting her back to tip top shape.
So i just did ccv from bav auto and new valve cover gasket and coils, icv clean etc. I'm getting the po444 so i got the PCV and thats where the problem lies.
While wrestling out the older valve the vac tube that goes to the intake maniford or throttle body came out. I can't for the life of me find where it goes. I've searched the board and I even called bav auto and they got me the picture; it the same pic that I found on realoem.com. Still no luck!
Any help is appreicated; trying to get her back together; so its the end that allows the vapor to be burned by the engine when the valve opens up. I appreciate any help.
Chad
Old 02-26-2013, 07:31 PM
cn90 cn90 is offline
Mein Auto: 1998 528i 5-sp 103K miles
Search forum (or Google) looking for CCV threads by "Fudman" and "Jason5driver".
Old 02-26-2013, 07:32 PM
here's the exact same issue that i'm having
http://www.justanswer.com/bmw/4yjbz-...ct-intake.html
Old 02-26-2013, 07:33 PM
where does the number 3 hose connect at?
Old 02-26-2013, 07:34 PM
http://ww2.justanswer.com/uploads/GE...155427_220.png
where does number 3 connect?
Old 02-26-2013, 07:43 PM
thanks cn90 i'm onit
Old 02-26-2013, 07:45 PM
Fudman CCV:
http://www.bimmerfest.com/forums/sho...d.php?t=409240
Jason5driver DIY:
http://forums.bimmerforums.com/forum....php?t=1376457
Old 02-26-2013, 08:06 PM
cn90 i'm good with the ccv, oil seperator. I need to know about the purge control valve or evap sensor hose routing right behind the power steering holding tank
I didn't see anything in fudman i'm checking jason5driver
Old 02-26-2013, 08:19 PM
okay cn90 i see where your going with this. Thanks alot I found in the picture with the intake manifold removed from jason 5 driver. I'm off to try to reconnect it. Thank you sir!
Old 02-26-2013, 08:27 PM
EVAP system in all cars is very similar.
Hose #3 simply connects to the intake, either upstream or downstream of the throttle plate.
Use a mirror to look for the nipple in the intake throttle housing.
Or run engine and listen for hissing (sucking) noise, you will be able to locate the nipple.
Old 02-26-2013, 08:36 PM
Maybe the "F connector" in Step #5 here:
http://blog.bavauto.com/5434/bmw-m54...30i-525i-530i/
Old 02-26-2013, 08:40 PM
page 3 of jason5driver 4 picture down is what I was looking for! Once i get this back together The last thing i need to figure out is why my care is cutting out at high rpm on full throttle but thats for another day!
Old 02-26-2013, 08:46 PM
Cutting out at full throttle: the car tells you to slow down otherwise you get a ticket.
J/k....
OK, replace the fuel filter if you have not done so. Info in forum.
Old 02-26-2013, 09:26 PM
J/k....
lol....i did i was hoping that was the case. I'm thinking crank position sensor. It was right around 4 k....<3k if power is lacking i understand its the vanos seals. It would die and I'd get a misfire cylinder one.
Old 02-26-2013, 10:09 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
We traced out all the vacuum hoses in the M54 engine.
Typing /vacuum hose F3 in the best links nets these, for example:
- How to locate all problematic (between 1/8" & 9/32" ID) 3.5x1.8mm, 3.3x1.8mm & (between 17/64" & 9/32" ID) 7mm ID vacuum tubing (single material), vacuum hoses (multiple material), 3.3mm OD curved vacuum pipes (rigid tubes), 3.5mm & 7mm ID vacuum endcaps (closed end) & 7x3mm manifold o-rings (1) & 7.52X3.52mm and 9.2X2.8mm fuel injection o-rings (1) & gaskets (1) on the M54 engine & where in the USA to get new vacuum tubing & vacuum caps (1) & what SAE sizes to get for all the metric M54 engine vacuum tubes, hoses, pipes, and caps (1) & correcting the F-connector errors in the realoem diagrams (1) & finding the ends of hard-to-locate vacuum tubes (1) & sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1) & how to make, borrow, or buy lean-condition misfire test tools to test for vacuum leaks & lean conditions (1) (2)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 02-27-2013, 01:55 AM
Steve530 Steve530 is online now
Mein Auto: 2001 530i
Did you get that purge valve hose back on the intake manifold? It's hard to reach with the manifold in place.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 02-27-2013, 04:56 AM
bluebee thanks a million...steve not yet. I was preparing for some meetings i have today; i took a minute to go out and feel around but sure enough I couldn't put my hand on it. I'm thinking I need to undo the CCV/oil seperator again. I plan on making it happen tonight! Is it possible to reattach with the manifold in place? or am i better off removing it?
Thanks a million guys! As i'm still gaining some bmw knowledge if anyone has 1978-85 240d/300d mercedes diesel questions/dodge cummins questions/ questions on making biodiesel please hit me up! I know this is a BMW forum but thats what I can bring to the table. As we all know the bmw straight six is one of the best motors built along with that the cummins straight six and the mercedes straight 5 3.0.
I'll keep ya'll posted on my progress!
Old 02-27-2013, 04:59 AM
Any chance this PCV going bad could cause a vapor lock with my fuel tank/prohibiting max fuel flow at high rpms?
Old 02-27-2013, 08:58 AM
poolman poolman is offline
Mein Auto: 525i station wagon
That hose is the only one I have never changed on my car--it's hooke to the intake in a place that I can't get my hands on--and there is a clamp that would need to be dislodged before you could remove it--are you sure that the hose that your wanting to remove is leaking air--you could remove the purge valve and then plug that hose on that end and crank the car and then go under the hood and check and see if it's leaking by removing the plug and then reinserting it--you would hear the difference in the sound--the charcol cannister is in the back driverside under the wheel well--there might be an air leak back there causing your problem
Old 02-27-2013, 02:44 PM
I helped a person replace the CCV and some vacuum hoses on his 330i with a M54 engine. When he removed the purge valve from the bracket, the hose was dislodged from the back of the intake manifold. It did not have a clamp, but that may just be the case with his car.
I did manage to get the hose back on the vacuum port on the backside of the manifold. It was not easy, but it is possible. IIRC, I positioned the hose as best I could and just managed to get two fingers on it to slip it on the port by reaching under the manifold.
Steve
OSRAM CBI
Old 02-27-2013, 06:56 PM
Okay thanks. Yeah i'm sure its leaking it came out of intake manifold when i was wrestling with pcv.
Old 02-27-2013, 07:00 PM
Originally Posted by Steve530 View Post
I helped a person replace the CCV and some vacuum hoses on his 330i with a M54 engine. When he removed the ICV from the bracket, the hose was dislodged from the back of the intake manifold. It did not have a clamp, but that may just be the case with his car.
thanks steve I'm currently doing some stuff for work but i plan on venturing out there in an hour or so to tackle it!
Old 02-27-2013, 07:55 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/5SC 97-528/5
Here's a picture of it from under the IM.
Name:	M54 Intake back.jpg
Old 02-28-2013, 08:49 AM
Nothings easy for me story of my life lol. Steve do you remember what all you removed to access it?
Thanks a ton!
Old 02-28-2013, 11:23 AM
The CCV was in place. The intake boot was out, and I think the wiring box was still unmounted.
Note I changed my other post. It was the purge valve, not the ICV.
Sent from my XT907 using Bimmer App
Steve
OSRAM CBI
