Old 03-13-2013, 12:35 PM
Space grau 550i Space grau 550i is offline
Mein Auto: E60 550i sport
Car feels jittery and floaty at speeds above 70 mph
As the tittle states, my car feels jittery above 70 mph. The car does not feel planted as it should at higher speeds. It feels very unsettled when pushing it above the said speed, does not feel buckled down, very twitchy. Feels floaty in a straight line at times. I feel every major road imperfection mainly in the rear end. The rear end also twitches when hitting significant road imperfections at higher speeds.
I need some help to figure out the possible cause(s) myself before going the stealership route. I don't intend to deal with their BS nor do I want to get raped by them.
Car info:
58k miles on the clock.
Tires: 7K miles on General G max All Seasons on stock 19 inch wheels. Purchased last April.
Wheel alignment and high speed balancing done last April. Not road force though.
Tire currently running:32 PSI up fronts 37 PSI Rears
Thanks in advance
Old 03-13-2013, 12:48 PM
H F H F is online now
Mein Auto: 2005 545i
Car info:
Thanks in advance
have u checked ur shocks for possible leaks ?
Old 03-13-2013, 01:04 PM
Bad Debt's Avatar
Bad Debt Bad Debt is offline
Mein Auto: 2005 BMW 545i
My experience with General tires is: THEY SUCK!
'05 545i, Auto, Orient Blue, Beige Dakota,Bamboo Anthracite, Logic 7, Xenon, PDC, Premium Package, Mtec V2 AE, 19" E92 M3 Rep. Wheels, M5TEC Bumper , MTEC rear bumper, 70k miles as of 1/13.
Old 03-13-2013, 01:24 PM
Car info:
Thanks in advance
No, have not check yet. Just trying to get some feedback from you knowledgeable fellas, then run down the list of things suggested.
This model is actually not that bad. They have allowed me to get around in the recent snow fall. They grip like crazy in the rain and dry, but I feel the sidewall can't handle the weight of this car. A lot of body roll in hard corning. Steering input is somewhat slow and somewhat disconnected.
Old 03-13-2013, 01:46 PM
patrick_y patrick_y is offline
Mein Auto: 2004 BMW 545iA
Really hard to say without seeing/feeling the car.
1. Worn shocks, NYC roads are bad.
2. Bad alignment, but this would be unusually bad
3. poor tires would make it worse, but driving 70mph in a straight line wouldn't feel "jittery"
You're going to have to go to a dealer and get this diagnosed if you want it fixed properly.
Old 03-13-2013, 06:39 PM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
A good set of tires and a precision alignment will go a long way. Just because you had an alignment done a year ago doesn't necessarily mean something couldn't have happened during that time.
Do you have active steering? Where do you get the alignment done?
I never heard of general tires so I can't say if they are good or bad - I have Conti DWS's on mine and they are pretty good for an all season tire.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 03-13-2013, 07:19 PM
amit1947 amit1947 is offline
Mein Auto: 2014 BMW M5
Your tire pressure is too low. Try 36 or 38 psi on the fronts and 40 on the rears. These are cold tire pressures.
Old 03-13-2013, 07:59 PM
mostroad mostroad is offline
Mein Auto: 535xit
Have you ever replaced your control arm bushings? -- I had to replace mine at about 50k miles, and the car is much more stable at speed, and tracks better, as well.
Old 03-14-2013, 03:16 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
When you do check the tire pressure make sure tires are stone cold.I don't know on your year but BMW door tire pressure was very confusing at one time.There are some large threads on the subject and your very symptoms.My tire installer had used the over 100mph setting and at 70 I couldn't hold it on the road.I have sport and now not run flats so saying that probably toss out factory recommended pressure.You need to play with and start with tire manufactures range.
Old 03-14-2013, 08:24 AM
Thanks for all the insight fellas. I'm going to start with adjusting my tire pressure first, then check all the list of items mentioned.
Old 03-14-2013, 09:20 AM
colin007 colin007 is offline
Mein Auto: 2007 530i
factory recommends 32 and 36
Old 03-14-2013, 11:02 AM
If my memory serves me right, I believe my door sill say 35 and 39 for the factory 19inch summer tires. Although these numbers may vary and require some playing around with due to that I'm on all season tires.
Old 03-14-2013, 11:34 AM
they probably are different for a 550.
amit1947 and i have 530s.
Old 03-14-2013, 12:34 PM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Yep, tires is the biggest factor on top of:
- dead/bend strut
- bad alignment, need a slight toe-in back and front just a tad, this makes a world on how car track true
- suspension issue, control arms worn, or bend (from pot-holes)
- some BMW like E46 3-series is known to have broken spring due to winter salt, this change the pring rate from left to right, have not heard this on E60 though
- worn/dis-integrating sub-frame bushing, I know my 11 yr-old X5 has this problem but @90k miles not like yours which only 60k
Old 03-14-2013, 12:38 PM
Think about going with nitrogen.. It doesnt fluctuate with hot and cold temps,, like air does. nitrogen molicules are bigger than air.. So it doesnt disipiate as fast as air does and holds the psi steady and longer...Also dont have to check ur tires as often ...as u do with air
Old 03-16-2013, 04:34 PM
Lethalphoenix Lethalphoenix is offline
Mein Auto: 2005 BMW 545i sport
I have a 2005 545i with 80k and had the same feeling in the car. Changed out my control arms and BAM that solved the problem. Its worth a shot.
Old 03-16-2013, 04:51 PM
What is a BAM?
Old 03-16-2013, 07:40 PM
Originally Posted by patrick_y View Post
What is a BAM?
lol, no i was using BAM as slang. Like, BAM there it is.
Old 03-17-2013, 01:09 AM
10550i 10550i is offline
Mein Auto: 2010 550i M Sport
I would do the following in order.
1. For the 550i M my recommends running at 36 front and 44 rear. Check your door sill sticker.
2. Redo the alignment. I did my at -0.5 camber 0.1 toe in 7.0 caster for front. -1.6 camber 0.1-0.15 toe in for rear. (If the rear happens to have toe out would result being unstable at higher speeds)
3. Check suspension bushings and components. (This can be done while you are having the alignment done)
Hope you can resolve your issue.
Current Cars:
2010 550i M Sport
2003 Porsche C4S
2008 328i
2007 530i
2004 M3
2001 330i
Old 03-18-2013, 10:06 AM
You guys always provide a wealth of information, thank you.
I bumped up my tire pressure to 36 fronts and 41 rears. Doing so, I noticed the car handles much better, but started riding the bumps a little harsher in
the rear. So I dropped the rear air pressure to 39 and it rides a little better. I also noticed the steering feels much more quicker than before with the increased PSI.
I'm going to take it in and have the suspension and alignment checked anyway. I have the CPO coverage, but I know the shocks are not covered, as it is a wear and tear item. I do believe bushings and control arms are covered though from the coverage list brochure.
Brochure list of suspension items covered:
Ball joints
Wheel bearings
Coil Springs
Stabilizer bar
Links and bushings
MacPherson Struts (Housing only)
Control arms
Trailing arms
Lateral links
Shafts and bushings
Wheel
Bearings
Coil Springs
Hydraulic leveling system
Height sensor
Pump
Stabilizer
Bar
Old 03-18-2013, 10:47 AM
Ball joints
Wheel bearings
Coil Springs
Stabilizer bar
Links and bushings
Control arms
Trailing arms
Lateral links
Shafts and bushings
Wheel
Bearings
Coil Springs
Height sensor
Pump
Stabilizer
Bar
My car also recommends the same tire pressure. However, many members here have stated that such a tire pressure would cause premature wear on the tires. Thus, I lowered it a few PSI from the factory recommended.
Old 03-19-2013, 08:15 AM
racooper3 racooper3 is offline
BMW Master Wannabe
Ditto. Control arm/tension strut bushing can cause the front tires to wander. I just had min replaced and a world of difference at 100mph.
Old 03-19-2013, 11:02 AM
champaign777's Avatar
check for 550i suspension recalls
believe me or not i found loose front control arm bolt on 2010 550i
Old 03-21-2013, 05:57 PM
bfeng bfeng is offline
Mein Auto: 540iT
I have under 60kmiles on my 2008 and the dealer tells my front control arm bushings are shot. It definitely makes the car loose at speed and clunk over pot holes. My E39 front bushings were also shot around 60k miles, causing the car to wander a bit. Also, I find the E60 suspension (535ix) to be quite soft and floating compared to the E39 sport suspension. Try the shock absorber bounce test.
