Old 03-02-2013, 10:04 AM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2008 Z4MR
Z4M - Hickups
Well I have hit my first hard wall with the car. Last weekend's trip to PCB and Ft Walton Beach resulted in the car getting the hick ups. Started rough idel and would not stay running at stop signs and after getting started unless I kept the RPS above the 1000 mark. After a week at the shop the mechanic still does not know what is wrong with it. He says it does not appear to be the VANOS since he killed the silinode some how and the car still ran. He has replaced the IAC and that did not do anything, he has run a compression test and all the heads came back to 205 psi. He is supposed to do a leak down test but did not have a assistant so he'll do that pretty soon. Anyone out there that might be able to thow me some pointers?
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 03-03-2013, 04:59 PM
Hoops432 Hoops432 is offline
Forever Fast
Mein Auto: '06 M Coupe, '08 K12S
Can you rule out dirty fuel?
2006 IBlue BMW Z4 MC (OZ spec) - ESS VT1 Supercharger, KKS gated exhaust, TMS camber kit, ST Trophy BBK with CL R6E pads, Ultimate pedals, PerformanceBox, Street Wheels/Tyres: Volk G2s and Potenza, Track Wheels/Tyres: Volk TE37SLs and BFG R1 slicks, Recaro Pole Position (driver), APR GT wing, OEM front brace, Carbon engine cover
Old 03-03-2013, 05:41 PM
That was one of my first thoughts, but mechanic said he checked both for octane, water, fuel pressure ect. Thought it was the IAC and swapped that out. Still doing the same thing. He's done a compression test, 205 on all 6 cylinders and was going to do a leak down test but his help left early so I guess that's coming on Monday.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 03-04-2013, 05:07 AM
tonywintn tonywintn is offline
Drivin' the dream
Mein Auto: 2005 BMW X5 & 2007 Z4 si
Sounds like a vacuum leak,but I'm sure he checked for that.
2007 3.0si w/Sport Pkg, Navi, Leather, Strut brace, garage door opener and delete airbag warnings on sun visors
Old 03-04-2013, 06:04 AM
That's what he was looking for, a medium size vacuum leak. But I just got the call, he worked it this weekend something broke in the hubs in the Vanos. He is going to scope the motor to see if any parts got into it.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 03-04-2013, 03:57 PM
Bearing on the intake side gave way. It's a little hard to see, but if you look straight across from the hex bolt on the left and see a black piece of cable tie holding the bearing out, you will notice it's tilted. It don't come that way.
Dr. Vanos replacement has been ordered for a swap out. The tabs did not break and I was lucky that no parts went into the motor.
More pictures to follow later.
So even if you check on the tabs and bolts when you do your valve adjustment I don't know of any way to see if the bearing has gone bad.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 03-04-2013, 04:31 PM
Forever Fast
Thanks for the info. Glad it's on the way to being fixed.
Old 03-07-2013, 06:27 PM
sinbad4 sinbad4 is offline
Mein Auto: Z4M
Sorry to hear about the trouble, Stihlbolts.
Would you tell us how many miles on the car? Would you say you baby the engine or drive more spirited?
Old 03-08-2013, 06:49 AM
45K Miles - It's never seen the track. I don't think it's something you can protect against, it was a bearing, you can never really tell when a sealed bearing is going to go. It just sucks. But it should be fixed to day.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 03-13-2013, 03:37 PM
https://www.facebook.com/media/set/?...2794429&type=1
The car is back on the road, and running great. $3800 dollars lighter in the wallet but much improved over what it had been. I just did not understand it was already in trouble I guess. Anyway I posted pictures of the Vanos after it came off and other issues, what happed is that when it was installed someone left a washer out, that washer was running around in there loose. So time to get it cleaned up and on the road for some me time.
Regards.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 03-14-2013, 05:15 AM
Drivin' the dream
Glad to hear you are back on the road and sorry to hear a out the cost. Is there any chance that BMW will pick up the tab since it was a manufacturing defect?
Old 03-14-2013, 06:41 AM
Its a nice thought. But I doubt they would step up. Warranty ran out back in November.
2008 Z4M Roadster
BMWCCA/ZSCCA Member
