E90/E91/E92/E93 (2006 - 2013)
Old 03-02-2013, 10:15 AM
jertronic jertronic is offline
jertronic
Mein Auto: 2008 328 xi sedan
Oil consumption
Typically I wait until this warning trips before adding oil. The interval is ~5,000 miles. After adding an entire quart the oil change is done about 2,000 miles later.
Question- should I add oil earlier, say when the level is down 1/2 quart? And does this level of oil consumption act as an indication that the engine is wearing faster than normal?
2008 328xi E90|N51|monaco blue|premium|sports|cold weather|logic 7|ipod|BMW Assist|xenon|sunshade|HD radio
Old 03-02-2013, 10:25 AM
laser's Avatar
laser laser is offline
Mein Auto: 2007 S2000
Seems a little excessive but not necessarily unheard of.
Are you leaking or burning the oil? May have to look under the motor when its on a lift and see any leaks.
Waiting til the light comes on you still have a margin for error so probably no big deal.
Laser
___________________________
2011 535i Black Sapphire Metallic, Sport, Euro Del (ret)
2009 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
Old 03-02-2013, 07:57 PM
Klamalama Klamalama is offline
Mein Auto: 330i, C230K, 3.2CLS-6
I think you're waiting too long. I keep mine at max level. Oil is cheap insurance.
[SIGPIC]
Capo di tutti capi.
Old 03-02-2013, 08:48 PM
galahad05's Avatar
galahad05 galahad05 is online now
Better with Butter
Mein Auto: 335i sedan 6MT
One quart over 5000 miles is nothing to be concerned about.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 03-02-2013, 08:59 PM
Pilgrim Pilgrim is offline
Mein Auto: 2009 328iX Coupe
One quart over 5K isn't a problem. And there's no need to worry about filling a half-quart. Just wait till it's down a quart.
1983 Datsun 280ZX Turbo
2009 BMW 328iX Coupe
2007 Nissan Murano
Old 03-02-2013, 11:49 PM
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Overfilling oil is more of a concern than being down a little so you should be fine. Losing a quart of oil without leaks is probably a headgasket going bad. I hope you have a leak.
Old 03-03-2013, 02:51 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Mein Auto: 2009 335i xDrive coupe
A quart over 5000 miles is pretty common, and not a sign of a significant problem.
Overfilling is worst than underfilling, but being a 1/2 quart over wouldn't be significant. You can, of course, only add 1/2 the bottle and save the rest for later.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3.
ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009
Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion
Old 03-03-2013, 03:54 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW E90 2007
Wait for the signal. The engine pan is large and receive almost 7quart. Being 1quart low is nowhere close to an issue.
2007 E90 AW 323i Step | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels & rear 15mm spacers
Old 03-03-2013, 05:30 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by jertronic View Post
Attachment 364495
Not a problem to add when a quart low, but modern BMW engines commonly go much longer without need for oil addition.
Typically, for a N54, before the ECU says it's time for that first ever oil change, the car might ask for a quart. Then, rarely before 10-15k oil change intervals determined by degree of engine use and the 3 sensor oil level/condition system.
Have no experience w/N52 but have to assume performance is no different. So....is needing oil every 5k mi an issue? Looks like!
You've excessive oil consumption. Where? Could be internal or, Laser has it right, could be an external leak. Recommend you bring the issue up w/your mech.
HERE's interesting info....
Old 03-03-2013, 06:59 AM
DSXMachina's Avatar
Automaticallyparsinglinks
Which brand of oil are you using and which viscosity?
Just fyi, the "full" point* is the point at which the light is activated to top off the oil level. Everything you add (usually a litre/quart) after that is extra to ensure a margin of safety.
*if you could ensure that your oil never went below this level, the engine would never suffer from a lack of oil
Old 03-03-2013, 07:08 AM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: E90 335i xDrive
I guess it depends on driving conditions, my car takes a quart every 4k miles since new with my 90% city driving.
BMW CCA Member 454031
2011 BMW 335i xDrive 6-speed manual thrills and whistles courtesy of the N55
Save the manuals
Old 03-03-2013, 07:10 AM
That's high for any late model car - what's BMW have to say?
Old 03-03-2013, 07:11 AM
lqaddict's Avatar
Salz und Pfeffer
The same tune repeated here - it's normal.
Save the manuals
Old 03-03-2013, 07:29 AM
Zooks527's Avatar
BMW will tell you that any oil usage up to 1 qt / 1000 miles is "normal".
No one here thinks that, but most people here wouldn't have a problem with a quart every 5000 miles, either.
Old 03-03-2013, 08:10 AM
bear-avhistory bear-avhistory is online now
335is Coupe JB4-G5 ISO
Mein Auto: 2011 335is 7DCT Coupe
Worse I did was 1/2 quart down @ 8K miles on the first change. Agree a quart down is no big deal as most cars only carry 5 quarts, the BMW has a bigger 7 quart pan. As others have said overfull will be more of a problem than running a quart down.
Kevin
2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO
2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star
2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash
Old 03-03-2013, 09:26 AM
jertronic
My indy uses Motul 8100 5W-40. When I add one quart after 5K between oil changes Mobil one 0W-40 goes in, or the same Motul 5-40 if I remember to buy one at the shop ahead of time.
He has my car over the weekend, in fact, for an oil change and other miscellaneous items.
-engine air filter and cabin air filter
-lubricate or replace chirping interior blower motor
-fluid change both differentials
-fluid change transfer box
-replace and register battery
Some of the maintenance items are straight forward DIY procedures. I don't currently have tools, however. How much of douche bag will I come across as being if I suggest to my fiancé to register for tools. Vera Wang china versus shop tools. Dumb question.... I know.
Old 03-03-2013, 09:47 AM
I can't imagine that consumption of 1/2 quart of oil in 5K miles is an issue. I disagree that the oil consumption is excessive.
IF there is a leak, that's an issue. And it's one that can be addressed. However, it must be the slowest leak in North America.
2007 Nissan Murano
Old 03-03-2013, 10:05 AM
2X, actually. Back in the day, a quart in 1k mi was a red flag. Today engines are much more efficient in oil use and service life, with synthetics and their better lubricity over time.
Some disagree, but I say for N54/N55 & N52, a quart in 5k mi is off target. Many of us go oil change to oil change with no additions, 10-15k mi. I certainly do, chipped & ripped.
So. Is a a quart every 5k mi, not an exception but typical, excessive? Maybe we have a dealer tech or two among us that can give perspective....??
Old 03-03-2013, 10:07 AM
galahad05's Avatar
Better with Butter
As it stands these days I think I'm seeing 1 quart down in 6k miles. This on a motor with 64k miles on it.
-- Irish Proverb
Old 03-03-2013, 10:51 AM
jertronic
I have an N51 if it makes any difference. Apparently the N51 runs a higher normal operating temperature than the N52. The higher temperature has something to do with the emissions make up of the SULEV pathway.
The milage is 88K. The 1 quart every 5,000 mile usage began at around 60K. FWIW my driving style has evolved over the 20K. I used to baby the heck out of the car. Now I drive spirited and push the rpms. Basically, it's as if I discovered DS mode at roughly the 60K mark.
Old 03-03-2013, 11:35 AM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
When I lived 2 miles from work, the car never really had a chance to warm up properly during my drive, I drove the car gently, and the engine used up about a half a quart between oil changes, about 5k miles.
Now I live about 15 miles from work and the car warms up properly during my drives, I drive the car in a much more spirited way, and oil consumption went down to ZERO between oil changes, the same 5k miles.
Go figure...
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Le Mans Blue | Black Dakota Leather | BMW Performance Kit Stage 1
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 03-03-2013, 11:52 AM
galahad05's Avatar
Better with Butter
Go figure...
I'm guessing with your previous commute your engine spent more actual running time "cold". Thus you had slightly higher blow-by the piston rings.
These engines run hypereutectic pistons, which means tight cylinder-to-piston tolerances when cold, but even hypereutectics expand with temperature....
-- Irish Proverb
Old 03-03-2013, 12:41 PM
May be a difference among engines but my 2004 330Ci ZHP with over 120K miles has only had oil added between factory changes once or twice since new.
Kevin
Old 03-03-2013, 12:53 PM
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
I haven't owned my 325i for 5,000 miles yet but it hasn't shown any loss of oil over the 1500 miles I've driven it, if the oil level monitor is to be believed.
But I agree with the folks that say one quart every 5,000 miles is not something to be worried about, so long as it isn't leaking it.
I have owned almost 20 cars over the last 25 years and have had new cars that used a quart every 5-6k miles and ran great and lasted nearly 200,000 miles before I sold them, so I wouldn't sweat one quart of oil every 5k miles unless there were other signs of engine problems (smoky exhaust, rough running, fouled plugs etc.).
Old 03-03-2013, 01:21 PM
laser's Avatar
Well at least it's better than my 66 MGB which got about 300 miles to the gallon of oil.
Had to buy used oil in gallon jugs and carry with me for a road trip
Laser
