Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread.
Old 03-02-2013, 10:50 AM
Taeksoo Taeksoo is offline
Mein Auto: 2013 335i Sedan
Turbo sound?
I got 335i and not sure if 328 makes the same sound or not. I think it's my turbo. It makes a pshhh type of sound at some point when I let go of my gas. Not complaining at all!! I love the sound. Just wondering if anyone know how to recreate it at will. I love hearing and tried to recreate but can't all the time. How or where is this sound coming from?
Also, is doing this bad for the car/turbo??
Sent from my SCH-I535 using Bimmer App
Old 03-02-2013, 11:41 AM
Jamesonsviggen Jamesonsviggen is offline
Mein Auto: '98 M Roadster/'09 VW CC
Its your bypass valve releasing the boost pressure.
Get on the gas, then back off of it.
The sound can be exaggerated if you like it by adding an aftermarket intake. Injen makes a nice one.
'98 M Roadster and '13 M-Sport 328i 6mt
E36/7: Dinan/RMS stage 2+ blower@13lbs of BOOST! 18" BBS LM's, too much more to list
F30: ForgeStar F14 19's summer-OZ Superleggera 17's winter/Rogue Catback/Integral Audio/AFE intake scoop/BMS stage 1
Old 03-02-2013, 02:15 PM
Cool, thanks, will look into it. Will that kind of aftermarket void any of the warranty?
Old 03-02-2013, 02:22 PM
Only if it's a proven failure relating to the part installed. If you blow a strut they can't deny the warranty due to your intake. If the intake has a screw shear off and go into the engine, well yes they could claim a causation with the intake.
Old 03-02-2013, 02:23 PM
The Tick's Avatar
The Tick The Tick is offline
The Annoying One
Mein Auto: 2 E36's
It's not bad for the turbo at all. That's what it's designed to do. If you just floor it and then let off the gas it should make that sound.
  • Cars
1993 BMW 325i 5-Speed Manual (Approximately 207,000 Miles) Daily Driver
1992 BMW 325i 5-Speed Manual (Approximately 270,000 Miles) Old Fixer Upper, and Eventually, a Track Monster
Old 03-02-2013, 03:14 PM
beden1's Avatar
beden1 beden1 is offline
Mein Auto: '11 335is Cab & '08 535xi
It's also called a blow-off valve. Greddy made the best for our Subaru (according to sources we researched) when we were doing some mods back in '04. I'm not sure what is best for a BMW.
You can adjust aftermarket blow-off valves for more back pressure and it sounds louder if you wish.
Current Stablemates:
'12 Porsche 911 GTS Cabriolet; '11 BMW 335is Convertible; '08 BMW 535xi
Favorite Cars Gone But Not Forgotten:
'09 Corvette ZO6; '01 BMW 740iL; '90 Nissan 300ZX 2+2; '89 Jeep Grand Wagoneer; '79 BMW 320i; '79 MB 300D; '67 MG Midget
Old 03-02-2013, 03:40 PM
Similar, but not the same.
A blow off valve releases pressure into the atmosphere, the bypass kind of recycles the air.
If you put a blow off valve on a car requiring a bypass valve you will get a check engine light as its similar to a vacuum leak.
Learned this with Saabs, as they moved from blow off to bypass. They both do the same thing, releasing boost...its just a matter of it being recycled or not. I am sure it's all about emissions.
I upgraded the one on my wifes Saab when I upped the boost using a Forge BPV. Very good quality.
Old 03-02-2013, 03:57 PM
A visual to explain above...
First is a BOV or blow off valve. The blue ring, is kind of a a horn where the boost is released to the atmospehere.
http://www.ebay.com/itm/Greddy-Type-...f94334&vxp=mtr
Next is a BPV or bypass valve. Note there is no horn. This is fed through vacuum lines and has no release to the atmosphere as it would cause a VAC leak and check engine light. Most cars from the past few years run BPVs.
http://www.ebay.com/itm/Forge-Motors...3df074&vxp=mtr
Upgrading the BPV will increase the sound very slightly. The intake dials up the BPV and induction sounds. My wifes Saab intake, its a bit overboard, but so far ones for the 335 are fairly subtle.
Old 03-02-2013, 05:09 PM
beden1's Avatar
I learn something everyday. Thanks.
Old 03-02-2013, 05:47 PM
jfox335i jfox335i is offline
Send a message via Skype™ to jfox335i
Mein Auto: 2010 E90 M3
Our 07 STi limited has this, the HPAI and catback. (all spt upgrades) the swooshing sound coming from the engine compartment is awesome during every shift.
Current: 2010 E90 M3 - JBM PP,TP,ES,CW,Beast
Retired: 2012 F30 335i Sedan - Sport Line
BMWCCA #471315
Old 03-02-2013, 05:49 PM
Yeah, I drove my friends'05 Legacy GT with the works. Its quite fun.
Old 03-02-2013, 06:20 PM
Elk Elk is offline
Mein Auto: ~
+1
Nice job, Jamesonsviggen
Old 03-02-2013, 08:14 PM
Frzdrdhppy Frzdrdhppy is offline
Mein Auto: 2011 Blue Water 335i
Occasionally when I am traveling and cruising at about 82 mph, I have a "necessity" to kick in the turbo in my E90. Usually hit well over 100 before backing off. But the sound, oh yeah, the sound! Takes about an hour to get the big SEG off my face.
I hope that doesn't change with my newly ordered F30!
Old 03-02-2013, 08:38 PM
The Tick's Avatar
The Annoying One
Mein Auto: 2 E36's
And OF COURSE you don't do it on public roads Haha lol
  • Cars
Old 03-05-2013, 02:37 PM
FreddyG FreddyG is offline
Mein Auto: 335i ....soon
They both do the same job, just different ways. One is atmospherically vented and the other is put back into the exhaust.
The actual job is to relieve pressure off of the turbo.
If we didn't have these, the reversion could bend and/or break the turbine vanes in the turbo. This is called compressor surge.
It's similar to water hammering in a pipe. That is the clunk that you sometimes hear when you quickly turn off a faucet and the water suddenly stops. It pretty much stops and then goes the other way and runs into itself.
Old 03-05-2013, 03:37 PM
Dingers 335i Dingers 335i is offline
Mein Auto: F30 335i
I suppose, this is the reason my right side exhaust tip is black and sooty after driving for a week.
By the way isn't this BPV a "waste gate"?
F30 335i
Old 03-05-2013, 03:54 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
actually the reason for the dirtier exhaust pipe is that there's a valve in the left tip that closes at low rpm to reduce noise.
the bypass valve does not dump air into the exhaust, it dumps it back into the air intake system.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 03-09-2013, 05:39 AM
K-A's Avatar
K-A K-A is offline
OG Mack Daddy
Mein Auto: '13 BMW 535i M Sport
Does the Injen intake also add extra HP? I love those subtle turbo sounds and of course the I6 sound in itself is a unique work of auditory art, so I wouldn't mind opening up mine a little bit on the engine side.
'13 F10 BMW 535i ///M Sport : Jet Black/Black-Anthracite : Premium & Technology Packages/Sport Auto Trans/Camera/Park Distance Control/Heated Seats/Tinted Windows/Blacked Out Markers/Performance Spoiler.
Ex M-B's: '11/'10/'06 E350's w/ AMG Sport Package, '02 S500 w/ Every Option.
Old 03-09-2013, 06:09 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
I'll second all that.
OP, I hear no noise w/stock valves. Issue?
Aftermarkeet valves'll give ya a rice rocket booosh....
Old 03-09-2013, 09:09 AM
The intake makers claim gains, but most tuners and reputable shops claim it's inflated and intakes are more for sound. They sometimes help revs and throttle response, but not so much increase hp.
Old 03-10-2013, 01:23 PM
LvdB's Avatar
LvdB LvdB is offline
Mein Auto: F30 328i Modern Line
I got 335i and not sure if 328 makes the same sound or not. I think it's my turbo...
Is it a noticeable sound on the 328i ?
I cannot recall that I have heard it from my 328i...
F30 328i Modern Line 8-Speed Sport A/T, 18" Turbine
Drive Comfort Package, Parking Package, Zenon, HiFi
Retired: '07 X3 3.0d M-Sport - '04 X3 2.5i Sportpack - '99 328i E46 - '93 325i E36
Old 03-10-2013, 01:25 PM
Windows down, on and off the throttle quick you can hear it.
Old 03-11-2013, 11:28 AM
LvdB's Avatar
Aha, now I have another reason to "play" around tomorrow on my way to work. Come to think of it, I've never driven my F30 with an open window (apart from the sunroof), ever
Old 03-11-2013, 12:36 PM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Re-Badged
Mein Auto: 2013 BMW M3
BPV releasing extra boost. Drive an X5 and go past 3k rpm. Back off the throttle and you'll hear it as well. It's normal.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
Old 03-12-2013, 11:56 AM
LvdB's Avatar
Windows were down, were on and off the throttle quick (more than once ), and I agree with Taeksoo, it's an addictive sound.
I cannot recall that I have noticed this sound from my turbo diesel vehicles (3.0 diesel X3 and 3.0 diesel C320cdi). I would have guessed that the turbo concept would be the same on both petrol and diesel variations, including the blow of system ...? Or maybe it's just not noticeable with the noisier diesel engines.
