E30 (1982 - 1993)
Old 03-02-2013, 09:27 PM
Spmarshall325i Spmarshall325i is offline
Mein Auto: 93 BMW 325i m package
93 325i blower motor not working
Hello guys so I've got a 93 325i I just purchased with a blown headgasket so I had the head rebuilt and got the engine running good again now I have the issue of no blower motor and I figured before I dig in I'd put something up here and see if anyone else is having the same issue. Just a little background I'm a veteran mechanic GM CERTIFIED and Ford certified almost master of both very fond and lightly certified in Subaru but this is the first German I've ever had the "pleasure" of working on I think it will be a great car in the end. Another side note the drivers door latch won't catch any suggestions?
Old 03-02-2013, 09:33 PM
The Tick's Avatar
The Tick The Tick is offline
Mein Auto: E36 325i
Holy cow! I have the exact same problem (on my 93 325i)! Is yours intermittent? Because sometimes my blower motor works, and sometimes it doesn't. But now, it just started Randomly working when I didn't do anything.
Cars
  • 2001 Dodge Ram 2500 Cummins Diesel running 411hp and 932ft/lbs (Current Daily Driver and Workhorse)
  • 3 BMW's (1 E30 325 and 2 E36 325's), 2 Audi's (B5 S4 and B8 A4), and 1 VW (MKV GTI) (All Sold)
Old 03-02-2013, 09:41 PM
Nope mine just flat out doesn't work it lights up on the dash and if I change where I want the air I can hear the blend doors opening and closing but no air :/
Old 03-02-2013, 10:03 PM
The Tick's Avatar
Mein Auto: E36 325i
Your problem sounds exactly like mine, just mine works sometimes and doesn't others.
Cars
Old 03-02-2013, 10:11 PM
I don't want I just throw a blower motor at it but with this German wiring my heads spinning
Old 03-03-2013, 12:54 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Check the resistor block that feeds the blower motor...they are known to blow.
Also check the blower motor has not seized...can be released with some lubrication....a seized motor will blow the resistor block.
Old 03-03-2013, 01:05 AM
Okay ill pull it out in the morning that might be it the car sat in a field for over a year so it really wouldn't surprise me! Thanks for the input!
