Old 03-02-2013, 09:53 PM
tgbennett tgbennett is offline
Mein Auto: 2007 BMW 328I
Radio display Issue
I purchased my first BMW Friday night, I love it best vehicle I've ever driven! Today while driving around my radio display messed up, found on here where other people have had issue but never saw the fix, Im attaching picture of the display The vehicle is a 2007 BMW 328I Sedan
Old 03-02-2013, 10:27 PM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
Join the club.
Here is a company that will either have you send them your radio and repair it ($169.00 + shipping) or send you a new display if you are handy for 149.00.
http://myworld.ebay.com/germanaudiotech/
http://www.ebay.com/itm/BMW-CD73-PRO...item27c6833db7
Old 03-02-2013, 11:11 PM
Originally Posted by BashedBarrique View Post
Join the club.
Thanks! I am taking it to the dealership I purchased from on monday morning to get a rear window fixed that doesnt like to roll up and the car has a 99 Day warrenty an I believe that the radio should be covered so Im going to see if they'll replace it.
Old 03-02-2013, 11:51 PM
It is a very common problem and you can find plenty of other people on this and other BMW websites that have the same issue.
Old 03-03-2013, 06:53 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Some horiz lines out - a common problem w/dot matrix LCD displays. Could be a connector, controller, or very often the LCD display.
Old 03-03-2013, 01:40 PM
The LCD display on my radio/cd player works great for the first 30 minutes or so, then it begins to fade out in vertical lines.
You can still read it but it is very annoying and gives the car a junky feeling.
As soon as I get an extra 150 bucks and the time to mess with it I'm going to send it to German Audiotech to swap it out for a good one.
Old 03-03-2013, 02:14 PM
I'm going to do the same, the dealership i purchased from gave me a 99 day warranty I believe it covers the radio, my question is would the new radio they put in do the same thing sould I bother with the dealer? or should I just send it away. I have to take it in because I need a window switched replaced too so I'l going to try.
Old 03-03-2013, 05:06 PM
I'm going to do the same, the dealership i purchased from gave me a 99 day warranty I believe it covers the radio, my question is would the new radio they put in do the same thing should I bother with the dealer? or should I just send it away. I have to take it in because I need a window switched replaced too so I'l going to try.
That's a good question. I guess if you don't mind taking it out yourself the dealer would probably agree to pay the 169 bucks and that way you'd be certain that you had a new LCD display instead of one that was going to do the same thing a year or so later.
Old 03-03-2013, 06:19 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
This is a long time problem with BMW Radio's
A dealer will only replace the whole unit I am pretty sure.
They have been using this same display type since before the
turn of the century. So if you get another BMW Radio it probably will
happen again especially if you live in an extreme temperature climate.
Old 03-03-2013, 06:50 PM
Like I said, mine only does it after 30 minutes or so and based on what I have read from other posters I think it is due to heat. The radio area is noticeably warm to the touch when the failure occurs.
I wonder if I could rig a little cooling fan behind the dash pointed at the radio to alleviate the problem?
Old 03-03-2013, 06:53 PM
That might work, mine does it all the time doesn't go and come. Im going to see wheat the used car lot says tomorrow when I got get my window fixed.
Old 03-03-2013, 07:07 PM
Last Sight's Avatar
Last Sight Last Sight is offline
Mein Auto: BLT335xi, e92 6MT
My Saab 9-3 had the same display....same problem. Good thing it's an easy fix.
BMWCCA #489063
The BLT335xi - '11 BMW 335xi, M-Sport, Convenience, Premium, H/K sound, iDrive
1974 Corvette - blue, 4spd, fully loaded
Previous Rides:
'13 Cadillac ATS - Fired
'09 BMW 328xi - KIA by Bambi, reincarnated in Michigan
'01 Saab 9-3 2.0T
Old 03-12-2013, 09:50 PM
BestPixelRepair BestPixelRepair is offline
Mein Auto: E70
This require new LCD screen to be installed. No other remedy
You can just replace the ribbon cable (what connect board to the LCD). Most likely LCD doesn't need to be replaced (unless it is cracked). Pretty easy fix.
Old 03-13-2013, 07:41 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
...Or just wear polarized sun glasses and you won't even be able to see the screen. Problem solved.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, backline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 03-13-2013, 07:46 AM
Mein Auto: E70
Not necesseraly right. Depends on the polarization direction
Old 03-13-2013, 07:58 AM
Shanequa657 Shanequa657 is offline
Mein Auto: 02 745i
I need help I just brought a02 745 I and I can't get my radio to work somebody if u can help please
Old 03-13-2013, 08:39 AM
jbyron jbyron is offline
Mein Auto: 08 335ix Sport
That was the first thing I noticed after I bought my car - I put on my ray-ban's to drive away, and thought the radio display had gone dark, until I cocked my head looking at it.
I wondered if it had been installed with a wonky screen, but apparently not...
jbyron
St. Louis, MO
2008 335xi Sport
50,xxx mi
1999 540i Sport - Retired w/202,xxx
1997 540i - Retired w/162,xxx
Old 01-20-2016, 01:55 PM
rrobinson001 rrobinson001 is offline
Mein Auto: BMW 330I
Wanted to ask this since this seems to be a issue with the radio. I have a extra radio but it is logic 7 while the current one is just hifi. Can I take the face plate off the logic 7 and put it in the hifi radio. Seems you can do that as it's just the display. Going to look tonight but if anyone can answer that would be great.
Old 01-20-2016, 03:27 PM
tgyberg tgyberg is offline
Mein Auto: E90 328 6MT / E36 M3
E36 forums have the same threads. Had to fix mine twice in the last 15 years
Old 01-29-2016, 05:59 PM
Apone911 Apone911 is offline
Mein Auto: E90 330i
Faceplate swap
I'm also interested to know if removing the board the lcd is soldered to and swapping with another that is working will work. (picture/step 9 & 10 on this DIY http://www.e90post.com/forums/showthread.php?t=635672
I have a 06 330i with Logic 7 and am wondering: if the swap is possible, does the replacement need to come from an 06 with logic 7, or will any cd73 head unit work?
Lastly, could the issue be a heat sink problem? I notice in the link above the step which refers to removing and reapplying thermal paste--my display fades after about 30 min as well, more when it's cold out, and on cold mornings it looks perfect.
Thanks in advance!
Ps--if I decide to send my whole radio out to get the lcd replaced, can I drive the car withou it?
Old 01-29-2016, 08:10 PM
You can buy the LCD kit or send the radio in
Repair resources
http://cgi.ebay.com/ebaymotors/BMW-C...ioQ5fVideo#ht_
http://www.e90post.com/forums/showth...hlight=airplay
http://www.e90post.com/forums/showth...ighlight=pixel
http://www.diyparadise.net/bmw_cd73_repair.html
http://www.bimmerfest.com/forums/sho...d.php?t=761513
Repair
http://www.bmwradiorepair.com/?gclid...FccbQgodIEn0Cg
http://beckerautosound.com/
http://www.bmwgm5.com/Logic7_6941681.htm
On the old radio's its possible to code and old radio after 09 it became a problem
unless you use a icom cable. (which is a rather expensive cable)
BMW inisists on this LCD assembly it has been a problem since the last century.
You must use your original radio or reprogram the new radio
if you don't happen to get one that is programmed for your sound
system if may not work for some or all of your options.
http://www.e90post.com/forums/showthread.php?t=687463
Old 01-29-2016, 10:09 PM
I find this baffling from a company that embraces almost every novel technology that comes down the pike, from self-driving cruise control to solar powered air conditioning. Why they would cling to this 1980's display technology is beyond comprehension. Do they have controlling interest in a Liquid Crystal Display company?
Old 02-01-2016, 09:35 AM
Mein Auto: BMW 330I
Well I tried the switch and it did work but I did mess up the little white cable that attaches to the radio to the display so it stopped working. Lucky for me I was able to find another radio cheap 5 min later after receiving it I was able to install and all is good. Next project is to try the CIC Retrofit in my 6 series, wish me luck.
Old 02-01-2016, 07:32 PM
sohor1 sohor1 is offline
Mein Auto: 2007 328i
Radio display Issue
I bought the LCD off of eBay...all I needed was a solder gun, flat head screwdriver and patience....voila I replaced LCD the myself. The thought of mailing my radio away and not having music in my car for two weeks was unbearable.
Old 02-02-2016, 12:22 PM
Mein Auto: E90 330i
How tough was the soldering? All of the DIYs I've seen don't really explain that part except to say don't screw up!
