Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 03-03-2013, 12:12 PM
MPresto MPresto is offline
Looking for answers...
Mein Auto: 1988 325 E30
Question Power Steering Pump Only?
on my 1988 325 e30.
On a cold start after a cold night she is extremely noisy. Playing with the wheel a bit for a few minutes while she warms up eases the chatter slightly. After about 10-15 mins when the engine has warmed the chatter seems to die, however, still gets noisy on some turns. Fluid seems to be leaking as well every 3-5 days reservoir is nearly empty.
Only has 126,000 on it so I'm wondering whether a pump and hose replacement should do the trick. I'm also a first time bmw owner and will be having a prior bmw mechanic friend do the work for me. Just looking for ideas, suggestions...
Old 03-03-2013, 12:25 PM
Jim Shoulders Jim Shoulders is offline
Mein Auto: 89i e30/87 spec30
Blown Rack, see rackdocktor.com. You can try to see if the rack will seal with a atf leakstopper. This band-aid is 90% futile though. Buy a rebuild Rack from Jim and go from there. Racks come with inner tie rod assemblies. Reuse your old outer tierods unless they are crap. If crap by some Lemforders/Meyle's and replace. The pump might quieten down with a non leaking rack. Two different P/S pumps are installed. Vickers and ZF. ZF is common, Vickers PITA. Check the PnP for a pump. The stealership or rebuilds will require a visit to rape crises center. Rebuild kit to DIY is a simple process. Hose's usually last. Buy some P/S hose connection seals/washers. On the low side of P/S system, hose clamps and atf resistant hose works fine. Buy new filter/reservoir when r/r with rebuilt rack. Flush system before install of rebuilt rack and reservoir/filter.
http://shop.rackdoctor.net/1987-1991...5-638-325i.htm
"Participating in a gun buy back program because you believe that the criminals have too many guns is like having yourself castrated because you believe that the neighbors have too many kids."
