E36 (1991 - 1999)
Old 03-03-2013, 06:53 PM
i523 i523 is offline
Mein Auto: 325i
e36 Front suspension help
hi all,
theres alot of info on this already but its been confusing for me.
i'm looking to replace the front shocks on my e36 325i.
i'm told some bushings should be replaced, my question is if i'm going
to do this job right what parts should i order to do so.
part numbers would help.
i'd like to replace anything that wears out while i'm in there.
Old 03-05-2013, 12:35 PM
Mein Auto: 325i
bump?
Old 03-05-2013, 12:39 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
It depends on what parts your car needs, but if you want to just overhaul everything and not worry about it (and only pay for one alignment), just get a front end overhaul kit:
http://www.fcpeuro.com/products/bmw-...e36-e36cakit8l
1998 BMW 328is
1966 Pontiac GTO
Old 03-05-2013, 05:04 PM
Mein Auto: 325i
i feel thats more than i need. also i read that i should use m3 bushings for the job instead of urethane
Old 03-05-2013, 05:10 PM
ZeGerman's Avatar
Warm Leatherette
It's not a matter of M3 vs. urethane bushings. You have four choices: Non-M3, M3, urethane, or solid. For most people I'd recommend using M3 bushings.
But if you feel like the comprehensive kit is too much for you, you'll just have to inspect your car (or have it inspected), determine what needs to be replaced, and then replace only those items. All of those items in the kit wear out at around 100k miles, so it makes the most sense in many cases to replace all of it and only pay for one alignment, rather than replacing one item and paying for an alignment, only to have another item needing to be replaced in 6 months, and then have to pay for additional alignments.
1998 BMW 328is
1966 Pontiac GTO
