E90/E91/E92/E93 (2006 - 2013)
Oil Change Interval vs. Need for Valve Blasting
As most of us are well aware by now, Direct Injection engines are prone to developing crud accumulations on the backs of the intake valves and the surrounding area in the head. Unfortunately many of us have had to have our engines partially disassembled and 'walnut shell blasted' or used other abrasive means to remove the deposits.
Several causes for this problem have been extensively discussed. It seems the deposits are the result of condensed crankcase blow-by gasses which are not dissolved by gasoline. Gasoline no longer runs through the intake area of a direct injected engine. I have a theory that those with longer oil change intervals may be more likely to develop deposits than those with shorter intervals. This poll will help me further explore that possibility. It is decidedly unscientific, and overly broad, but will help me decide if further research is warranted. Probably its biggest faults are that it doesn't control for driving style and mileage. Regardless, it's a start. If you have been using Techron or any other fuel system additive respond as if you did not. Please select one condition most applicable to you: EDIT: SORRY, WHEN I WENT TO POST THE POLL I GOT A MESSAGE SAYING I HAD ONLY TEN MINUTES TO MAKE UP THE POLL. BY THE TIME I GOT IT DONE I WAS OVER THE LIMIT. WILL TRY AGAIN LATER!
Poll fail.
Voice of that experience - prepare the poll in a Word document ahead of time, then cut and past.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! |
DSX - good concept. Better luck setting up the poll.
mine only had it done once at 137,000 miles. I change oil like i change my undies. When they can walk to the basket...
Just kidding every 8,000 miles
If you like customer service. Don't look beyond a BMW. |
Mine is mixed-mode. For the first 3 years I went full factory intervals, then I switched to 7500 miles (or sometimes less) between changes afterward. My valve problems likely showed up around 60k miles.
Don't resent growing old. Many are denied the privilege. -- Irish Proverb |
I bought the car with 15k miles on in, right after the original owner had the oil changed according to the BMW maintenance schedule. Since then I've changed the oil every 5k miles, 3 times now. At the moment my car has 32k miles. I am planning to keep changing the oil every 5k miles. As far as valve cleaning goes, it will be done at 50k miles or when I begin to feel the usual symptoms of carbon buildup, whichever comes first.
Carlson The Flyer | BMW CCA # 423862 The problem with common sense is that it's not very common. 2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course! Heated Seats | USB & iPod | Le Mans Blue | Black Dakota Leather | BMW Performance Kit Stage 1 ![]() Previous BMWs: 2001 330i ZSP ZPP 5-speed - sold, but not forgotten. |
================================================= ================================================= ================================================= "To suffer the penalty of too much haste, which is too little speed." - Plato |
I'll expect this poll as soon as I see DSX's pictures from CTC4
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
it would be nice to see pics of what they look like at 30K miles
I plan on changing oil every 7500 miles or 6 months, I got my 07 335 HTC in nov last year and put 1000 miles on it to date, its my weekend car, my 4runner is my travel vehicle when I call on customers Hondo |
7500k for me bro and you saw mine
I also didn't start mods till right before WB. So 99% of those deposits were probably stock
What about boosted vs stock? I can't believe that this wouldn't be a factor as well.
Could be, I know with higher PSI you want to change plugs @ 25-30K intervals to prevent misfires. Don't have enough mileage for poll.
Kevin 2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO 2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star 2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash |
So maybe DSX's (eventual) poll should be limited to people who are completely stock. This to help eliminate extra variables. Either that or perform Statistical DoE (Design of Experiments).
Don't resent growing old. Many are denied the privilege. -- Irish Proverb Last edited by galahad05; 03-05-2013 at 01:25 PM. |
I think if there is a poll a better reflection of users would be those that:
drive the car hard all the time drive the car hard part of the time don't drive the car hard oil changes per CBS oil changes approximately 7500 miles modded car stock car It is known that you get blow by under vacuum but how much is unknown (BMWs PVC valve don't seal completely) and blow by under boost. For me my answers would be don't drive the car hard change oil every 7500 miles slight mod (JB+) I am sure we can work this out but do think a more comprehensive poll would help since there are more variables than just one or so. That would give us all a lot more information to see if there is a trend... |
So, the question is, how will I know if I need this? What are the symptoms of carbon build-up? As far as I can tell, the car is running the same as it was when I got it three years and 40k miles ago. Could be a gradual thing that I haven't noticed or just not a problem. |
![]() http://www.bimmerfest.com/forums/sho...d.php?t=678670 http://www.bimmerfest.com/forums/sho...530&highlight= |
He must have been walking around with a fake camera, fooling us all into thinking that he was taking pictures. I do remember him springing up the rock, above the Mt Washington parking area, not unlike his favorite barn yard animal, to take said pictures.
2011 328xi 2011 535xi GT BMW CCA Last edited by Bemo; 03-06-2013 at 03:32 PM. |
My post makes 19 replies and 470 views for a failed "poll" thread. Not bad.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
The comparison for me is engine oil sludge from which my E39 540 suffered. The dealer and one indy wanted to thoroughly clean it out (for some outrageous amount of money). My trusted indy said not to worry about it unless I actually noticed some performance decrement. I didn't and the car worked wonderfully for 100k+ miles after the dealer's diagnosis. |
You don't have to do anything unless you see symptoms--hesitation, misfires, noticeable performance degradation (typically high load low rpm), or progressively worsening gas mileage.
People have different priorities and we've seen plenty of cars go 100K without it, I just wouldn't add undo stress for that small amount of money.
Thanks - that is helpful. I'll ask my indy about it next time I need service. My car will go out of the CPO warranty and extended service in a few weeks so that's it for the dealer!
#25
I may try this in a couple of years, perhaps at the same time as spark plugs, and I'll keep an eye out for any developments in OCC designs in the meanwhile. I'll also cross my fingers in hopes that more indys will acquire walnut shell blasting capability by that time.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
