E90/E91/E92/E93 (2006 - 2013)
symptoms of thermostat failure
Can anybody tell me what the symptoms are of a thermostat failure? Curious to know as there seems to be some talk about the thermostat eveyr now and again. What I mostly read is that it fails open/closed. Can someone explain exactly what they means?
'08 Montego Blue 335i, grey leather, aluminum trim, auto, 50% Llumar ceramic tint all around except windshield - all options except active steering, active cruise control and HD radio ![]() '01 Lexus IS300 - gone but not forgotten ![]() |
If your thermostat fails, the Service Engine Soon light will come on.
They're designed to fail open; this keeps coolant flowing. If they failed shut the engine would almost immediately overheat. In addition to the SES, if it does fail open, you won't have much heat from the heater. |
Failure of that circuit wil usually set a thermostat specific code.
Hi all.
I replaced the thermostat yesterday after the temp guage on the dashboard was at about 30%, running cold, Suggesting the thermo was stuck open, Also the heating inside the car wasnt great, further suggesting the same problem. The temp guage went back to 50%, (12 o clock) which is normal and the heating returned to normal. Quite hot. However, this only lasted for a while and now the problem of low heat inside the car and temp guage has returned to about 30%. Does anyone have any experience of this oir any advice? Note I only changed the main thermo. Thanks in advance |
What codes are in memory? |
two codes showed up in memory. But Im told they were to do with a sensor for the air bag. I think one of them was a code 51? does this make any sense?
No....ask for a complete readout including hidden & shadow codes. Alternatively |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
