E60 (2004 - 2010)
Old 03-04-2013, 04:09 PM
pureappearance pureappearance is offline
Mein Auto: 530i
no oil pressure
Hello,
I have a 06' 530i with 146k miles with no oil pressure currently. I checked pressure with a manual guage and it showed no pressure. Can I replace the oil pump myself and if so how? I am currently in mechanic school. Or is it advisable to just take it to the dealership or other certified BMW mechanic?
Thank You
Old 03-05-2013, 08:53 AM
pjinca pjinca is online now
USAF Pararescue Veteran
Mein Auto: 2008 550i
If there truly is no oil pressure you would need to have it towed to a mechanic or dealer (I'd suggest mechanic since the dealer will just look at you and your situation and start planning his kids Harvard degree).
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers
Previous 3 cars (the 550 is my 38th car):
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-05-2013, 11:23 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
If I am not mistaken, oil pan needs to be dropped to access the oil pump. The remove the oil pan, you will need to remove the cradle/cross members or raise the engine. If I were you, I'd look for a competent independent mechanic.
Old 03-05-2013, 01:43 PM
DJtoad DJtoad is offline
Mein Auto: 2010 535i M Sport
If you really have no pressure (i.e, you're sure it's not just the sensor) it could be a number of things besides the pump itself, for instance, it could be sludge build-up or a blocked intake tube/screen. But if you drove for any distance in that state, you need to decide how much money you want to sink in to an 8-year old engine with 150K miles. The lack of oil may have done serious damage to the engine, especially the valve train. Just something to consider...
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
Premium, Value, Cold Weather, Sport Auto, Navigation, Satellite, Logic 7, Comfort Access, Park Distance, Fold Down Rear Seats, Heated Rear Seats, Rear Side Airbags, JB4 Stage 3, BMS DCIs, Proform Clear Bra, LUX H8 LED angel eyes
Old 03-09-2013, 04:32 PM
Mein Auto: 530i
thanks for the replys im pulling pan this weekend and replace the oil pump ! 412.00 not that bad plus bolts and gasket
thanks again .
Old 03-09-2013, 04:35 PM
pcy pcy is offline
take some pictures while you are replacing the oil pump.
Old 03-09-2013, 05:04 PM
Mein Auto: 530i
ok i will !
Old 03-09-2013, 05:37 PM
Good luck...hope it works out for you!
Old 04-19-2013, 02:33 PM
Mein Auto: 530i
sorry havnt up dated pulled cradell and oil pan found that previous owner only changed oil at 15000 it was all clogged up so took to bmw only they pulled motor and had dip to clean out ! waiting to get back ! but went ahead and replace all seals had head checked so all good ! thanks again for replys
