E36 (1991 - 1999)
Old 03-04-2013, 05:02 PM
JackDuggan JackDuggan is offline
Mein Auto: 2001 Z3 3.0 Roadster
Jerky acceleration after strut/shock change; guibo?
I recently changed my front struts and rear shocks on my '95 318ti and since I have had a weird pogo stick bouncy kind of feeling when accelerating from a stop. The shocks in the back are really stiff, it's hard to push down on the back of the car, so at first I thought it was that.
Now I'm starting to wonder if jacking it up stressed out the bushings in the back, or maybe the guibo. I jacked the rear up from under the diff, not the subframe. Could that stress out the guibo or something? I haven't had time to get back under there and look. It's got 232,000 miles so all the bushings and guibo should probably be changed anyway.
Anyone else had this experience, or care to suggest a cause?
Old 03-04-2013, 05:16 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Probably not the flex disc, since when those go bad, they cause a lot of vibration which you would feel.
I am doubtful that the jerkiness has anything to do with your strut/shock replacement. Does the engine stumble? Do the RPMs shoot up?
1998 BMW 328is
1966 Pontiac GTO
Old 03-04-2013, 05:34 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
What brand/model struts and shocks did you install as the replacements?
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 03-04-2013, 05:38 PM
They're Sensen; I went cheap because the car has so many miles on it. I got them from APX Auto parts online. The handling seems fine, just kind of a jerky bouncy feeling from the back when I start off.
Old 03-04-2013, 06:01 PM
dc_wright's Avatar
If you're getting any knocking noise from the back you might want to take a look at the upper shock mounts. They tend to be a bit fragile and after many miles of use a new set of shocks can be enough to do them in. If they've failed it will be almost like you have no shocks in the rear, very bouncy, etc.
Old 03-05-2013, 10:34 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
It's giubo.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 03-05-2013, 10:54 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
Originally Posted by petriej View Post
It's giubo.
It is? Who knew?
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
So let it be written, so let it be done.
