Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series / 2 Series > E82 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by either an inline 6 in the 128 or the twin turbo rocket sled 135.
Old 03-04-2013, 06:54 PM
MRjayr MRjayr is offline
Mein Auto: E46 323i
Servicing an 06 118i
Hi all,
Just purchased myself a used 118i that needs quiet abit of TLC (hence the really cheap price)
Heres a list of things that i think need attention. Since this is my first 1 series im open to suggestions on to what could be done to get the car in A1 condition.
1) I want to service the 6 speed auto. I believe the car uses a ZF 6HP19Z gearbox found in many other bmw variants (is this correct?)
And can i use this DIY as a guide even though its for a 5 series? http://forums.5series.net/diy-do-you...-refill-88129/
2) DTC light & park brake light both on orange, the seller took it to bmw and was told it was an internal failure and believes that the DTC unit needs to be replaced and reprogrammed. Told me i could do it myself and reprogram it manually? Is this true?
3) Car is leaking power steering fluid, as an agreement of our deal he said he would get it fixed. I suppose ill just have to wait and see if its fixed or just "patched up"
I am barely able to turn the steering wheel with 1 finger if the car is parked and idling. Is this normal?
Please let me know if theirs anything else i need to add to the service list as this car will be for my wife so it will have to be reliable.
Car has 69,xxx kilometers
Thanks everyone,
Regards.
Old 03-04-2013, 06:59 PM
mr29 mr29 is offline
Mein Auto: bmw
there is a reason he is getting rid of it with only 69k on it.unless the price on this is amazingly great I'd run from this car
Old 03-04-2013, 07:03 PM
Mein Auto: E46 323i
69k is high for here in the Philippines cause of the traffic, cars barely get to see more then 70kmp/h. My mother in laws mazda 3 has 59k and is 07. I almost bought an 2008 Sti with 16k.
Car was sold for 665,000 php. 2005 116i selling for 800k+ if i spend 100k thats still ok with me. (1 USD = 40.5 PHP)
And the sellers side line is buying and selling cars...
Old 03-06-2013, 02:08 AM
Mein Auto: E46 323i
Anyway back to topic.. Can anyone else please comment on the top post? Thanks
Old 03-19-2013, 04:41 PM
Estorilblu Estorilblu is offline
Mein Auto: Smart car Brabus
Autodata notes
No oil change necessary.
in case of repair only fill with lifetime oil
GM transmission
GA6L45R Dexron vi Bmw part no 83 220 397 114
Green plate Dexron vi Bmw part no 83 220 397 114
ZF transmission
GA6HP19Z/TU shell M 1375 4 Bmw part no 83 220 142 516
carry out fluid level check using diagnostic equipment
regarding dtc same problem im having common fault on the 1 series dsc abs pump fault yes it can be repaired and put back with brakes bled fault codes cleared but if you get a complete new or used pump it will need coding to the cars ecu which you cant manually do unless you have the equipment to code ecu's
your power steering leak probably wont help with air in the system probably why its stiff but they arnt that light usually anyway good luck
Old 03-19-2013, 06:19 PM
Mein Auto: E46 323i
Hi,
Thanks for your post. Since my last post im pleased to report everything is fixed. I changed engine oil with shell helix ultra 5w40 and has bmw long life approval.
Rear diff was done with Royal Purple 75w90. As for the leaking power steering turned out to be a loose hose on the reservoir.
And finally i got rid of the DTC light and orange park brake light by cleaning out the steering angle sensor. The optical disc was extremely dirty. Code went away after a short drive of cleaning.
Regards
Old 03-20-2013, 08:18 AM
Just out of interest how did you clean the steering angle sensor i remember changing one on a e46 was a nightmare steering column out can you get inside the unit? its around the shaft in its own casing how? good work tho
Old 03-20-2013, 09:16 AM
Mein Auto: E46 323i
I took out the airbag and steering wheel and inside it there is a cd like part that was dusty. Basically the optical sensor could no longer read it.
I also followed this diy found on e90 forum. It was very helpful!
www.e90post.com/forums/showthread.php?t=520467
Old 03-20-2013, 09:41 AM
Ok i see totally different to the e46 but mine turned out to be a faulty dsc unit thanks for that
