E46 (1999 - 2006)
Old 03-05-2013, 03:01 AM
clydesdale clydesdale is offline
Mein Auto: 87 325is
Thermostat seems stuck open - good time for coolant overhaul - questions- radiator?
When driving around the temp drops right down to just above the blue zone. If I let it sit, it will climb back up to almost the 12 o'clock position. If I drive, it then drops down again. I think the stat may be stuck open. The car has 75k, so it may be time to do the whole coolant overhaul. Is it necessary to replace the radiator? I saw a kit at bavauto. Is that who you suggest for this kit or anyone else? Any other tips? Thanks.
e30 325is
Old 03-05-2013, 03:17 AM
heztheone heztheone is offline
Mein Auto: ///M
preventive maintenance would be:
- changing expansion tank
- water temperature sensor (or even the o-ring would be enough)
- t-stat
- radiator flushing/cleaning
other than that would be throwing your money away.
while u'r there, check for any leak
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
Old 03-05-2013, 03:59 AM
Mein Auto: 87 325is
What about the hoses? It is a 2004 330i zhp. Thanks.
e30 325is
Old 03-05-2013, 04:12 AM
Mein Auto: ///M
nope no need...
Old 03-05-2013, 04:46 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
Don't forget to change the water pump and get a good look at your pulleys and belts. Most of us do it all at the same time since you're there anyway.
A failing thermostat usually throws a code. Is your SES light on and if so, have you read the codes yet ?
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 03-05-2013, 04:55 AM
Mein Auto: 87 325is
No ses. Just the cool water temp. One cold morning I just hopped right onto the interstate for about 15-20 minutes and the water temp was right at the edge of blue. Once I got off the interstate, it started to rise.
e30 325is
Old 03-05-2013, 12:37 PM
Fishful Thinking Fishful Thinking is offline
Mein Auto: '04 325ci
Y'know, you can just change the thermostat, bleed the system, and call it good. But while you're in there, do a thorough visual check for leaks, belt problems, etc.
Changing the thermostat is such a quick and easy DIY, there's no need to couple it to other DIYs. Good luck.
Old 03-06-2013, 04:23 AM
Mein Auto: 87 325is
The thought is crossing my mind to just do the thermostat. What percentage of coolant do you think I will lose? The thermostat seems to be up pretty high. Maybe I can just replace the stat and go a little longer.
e30 325is
Old 03-06-2013, 05:28 AM
Mein Auto: ///M
sure u can do that, just keep a bottle of water of 2L with u for emergency, u never know what might happen. i keep one in my trunk even after i did a complete cooling system overhaul.
Old 03-06-2013, 05:48 AM
jdauria jdauria is offline
Mein Auto: E39 ///M5
+1 I keep a gallon of distilled water and a quart of motor oil in my trunk at all times. Never know, and better to be safe than sorry. Never had to rely on them though.
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2011 X5 35d | Alpine White | Beige | Sports Pkg | Premium Pkg | Cold Weather Pkg | 3rd Row
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport | DINAN Software | FOR SALE!
Old 03-06-2013, 12:56 PM
You'll lose a little bit, enough to put a pan under the car to catch it. Just be sure to go through the bleed process to purge out all air, and you'll be fine.
I keep a gallon of pre-mixed BMW coolant and a quart of oil in my drug bin at all times - good habit to get into.
Old 03-06-2013, 03:29 PM
Mein Auto: 87 325is
Well, I thik I am going to do just the stat. I ordered one today and we will go that route until life warms up here in the northeast. What is the estimated time on this job? I have changed stats before, but never on an e46. I have done them on a taurus, powerstoke diesel and my e30. It didn't look like I had to take anything else off to get to it. Or do I?
e30 325is
Old 03-06-2013, 09:56 PM
Mein Auto: ///M
shouldn't take u more than half an hour if it's a manual (being a ZHP, please tell me it IS a manual ... off topic ) if it's an auto, it's gonna be a bit of a PITA, since u'd have to removed the fan to get to the t-stat.
Old 03-07-2013, 04:11 AM
Mein Auto: 87 325is
Yeah, I have a manual. But looking in the book it says remove the fan shroud and fan, then remove the stat. On a manual, you can just go right for the stat? I apologize, it is my wife's car and I have not had to pop the hood much yet. All I repaired was a torn intake boot. For all I know it doesn't even have a viscous fan.
e30 325is
Old 03-07-2013, 04:39 AM
Gryphon's Avatar
Gryphon Gryphon is offline
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
I've always removed the fan to work on the cooling system, it's a few expanding rivets and torx fasteners to remove it. Get yourself a new t-stat gasket too if that's all you're going to replace. When I did my cooling system I did the t-stat, hoses, thermostat, and upgraded the wp to the stewart model. As others have said as well, evaluate your belts and pulleys. Failure of the belts and pulleys usually has catastrophic results on the cooling system components.
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 03-07-2013, 07:15 AM
Mein Auto: 87 325is
Hmmm, stewart model. That is the first I have heard of that. I will look into that. Thanks. It looks like it is just electric fans for the manual trans. I will look in the book to see what it will take to remove the fan. I kind of just want to do the stat at the moment until I can research the system, such as the suggestion you just gave about the WP, and wait for the weather to warm. I can see the top bolts of the stat, but the bottom bolts are hidden by the fan. Are they reachable with the fan in place?
e30 325is
Old 03-07-2013, 12:28 PM
Pulling the fan assembly takes removing a couple of expanding rivets and one torx bolt. Disconnect the electrical connection, then just lift it out. 3 minutes, tops. If you have big 'ole gorilla hands like me, you'll really appreciate the extra room.
The hoses disconnect with clips, IIRC. Not traditional hose clamps. A little fiddly, but once you figure them out, they're easy.
Your new thermostat should come with a new gasket.
I suggest picking up some replacement plastic rivets, as they're real easy to break.
Good luck.
Old 03-07-2013, 12:50 PM
petemo94 petemo94 is offline
Mein Auto: 325Cic
If you want the full Monty go here:
http://forum.e46fanatics.com/showthread.php?t=914109
Anything less will put doubts in the back of your mind. But within the next 1-2 years you will be doing most of this.
This is your definitive guide for the E46 cooling system. Good luck.
PeteMo94
2004 325Cic w/ ZSP, ZCW, ZPP,
Bought on 12/1/2012. 1st time BMW owner
E46 Merit Badges: OFHG, WP, ET, AT-T, ICV, CCV, Fluids (5)
Old 03-07-2013, 03:52 PM
Mein Auto: 87 325is
Yeah, I saw Mango's list and he has answered a few of my other questions regarding this. I realize the full job is coming, but from what I understand, the stat is so easy that I may be able to just do that now, while it is still cold outside. Then, while in there, I can get a look at everything and order the parts and plan for a warmer time of year.
e30 325is
Old 03-07-2013, 05:20 PM
Mein Auto: 325Cic
Sure. Cold temps would keep me from doing the overhaul too. Removing the thermostat you stand to lose about 1/3 of your radiator coolant IF you are careful with the bottom hose (not let it drop). The other thing you risk is damaging the hose o-rings. These d@mn things are what keep you from having leaks. Take care prying them off and putting on. Also take pics of the hose connections and make sure they are put back in the same depth as before.
Good luck and report results.
PeteMo94
Old 03-08-2013, 03:32 PM
Mein Auto: 87 325is
I am not familiar with these o-rings. Thanks for the warning. I do see that the clamps appear to get pryed out and then pushed back in. When I pull the hose off, where will the o-ring be?
BTW, what is the system capacity? I have one gallon of BMW concentrate coolant.
e30 325is
Old 03-08-2013, 04:44 PM
Mein Auto: 325Cic
The clamps keep the hoses from flying off. However the key to no leaks is proper insertion, no distortion of the o-rings and the clamp pushed down. The o-ring for the hoses will be embedded in the hose. It is a non-serviceable part. If it damaged, the hose is toast. Clean and lube the oring after removal.
1 gallon of concentrate is plenty. Mix only with distilled water. Others may disagree but this guarantees no problems (in terms of fluid and longevity).
PeteMo94
Old 03-08-2013, 04:46 PM
Mein Auto: 325Cic
I shoulda said clean and lube after removal of the "hose" and not the oring. The o ring cannot be removed.
Good luck and report back results.
PeteMo94
Old 03-09-2013, 05:55 AM
Mein Auto: 87 325is
What are you lubing the o-rings with? Just putting a little coolant on them to help them slide on the stat housing? I imagine this will all make more sense when I dig into it. But, I now know to be very careful with these hoses. Thank you.
e30 325is
Old 03-10-2013, 06:41 AM
Mein Auto: 87 325is
I read up a little on the stewart pump. It seems pretty bulletproof. But, isn't the rest of the system such crap that you have to tear into it anyway? Is it better to just replace an oem one every 75k? Thoughts on that?
e30 325is
