Old 01-27-2013, 07:18 AM
Zkanaan Zkanaan is offline
zeyad
Mein Auto: 2006 530xi
Oil level sensor malfunction
I have 06 530xi , i had my oil change done week ago , i only drove 200 miles and now i have msg says oil level sensor malfunction. Help
Old 01-27-2013, 10:50 AM
toga94m toga94m is offline
Mein Auto: 2006 530xiT
I don't know where in "USA" you live, but if it's somewhere cold and your car doesn't regularly get warmed up with a long drive, you might read this thread...
http://www.bimmerfest.com/forums/sho...d.php?t=419633
My car claimed I was below minimum on oil, but it turned out the sensor was confused and wanted a vacation somewhere warm.
2006 530xiT 6MT - 141k miles - 3rd owner - sport & cold packages
Old 01-27-2013, 11:19 AM
zeyad
oil level sensor
Thanks for your reply, I live in Boston, MA. Here it is below freezing, I dont drive much just to work which is five minutes away. Your message helped a lot you are rite. I shouldnt worry then? I love my car, so I panic with any message thats not good.
Ziad
Old 01-28-2013, 08:51 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
Error message says "Oil level sensor malfunction"? Buy a new oil level sensor, take a CLEAN oil pan, let all oil drain in to pan, replace the the oil level sensor and then pour the oil back in to the engine. Be glad oil level sensor is mounted OUTSIDE the pan (unlike some MB cars) and it's accessible from below the car. It's mounted on the lower oil pan.
Since your car doesn't have dip stick to check oil level, you MUST rely on the integrity of the oil level sensor. Hence, my recommendation to go ahead and replace that sensor without much debate.
Old 01-28-2013, 02:56 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
Yeah, you should change the oil sensor with a new one ASAP.
Since you are going to drain the oil anyways, i would suggest you to change the oil also (So you save time and skip the next oil change) but that's just an extra that might not really be necessary, check when was your last oil change.
Old 01-28-2013, 04:53 PM
pcy pcy is offline
OP says he had the oil changed 200 miles/ 1 week ago. Hence, it should be ok to pour the oil back in there.
Old 01-28-2013, 10:50 PM
Mein Auto: A Car
Ooops, you are right.
Old 03-06-2013, 09:05 AM
zeyad
Thank u
