E60 (2004 - 2010)
Old 03-05-2013, 10:46 AM
dakest dakest is offline
Mein Auto: 2006 530i
Adaptive headlights error
My headlights won't move when I start the car, won't move when I turn the wheel and I got this message on idrive, led by light switch blinks.
All I have done recently was move the electronics from the bottom of the spare tire well to the driver's side of the trunk.
I did search but did not find much, help is appreciated.
Old 03-05-2013, 12:30 PM
German Steel German Steel is offline
Mein Auto: 2008 535xi
This might seem simple but consider if the light switch is in the proper position for the directional lights to function. I did not know about this until I read the manual.
Old 03-05-2013, 12:41 PM
OK if the switch is at the automatic position, and the LED on the headlamp switch is flashing, and the AHL still not functioning.
See if you can get the system scanned for faults stored related to the AHL system. If no faults are stored and LED is flashing, the problem may be cause by stucked stepper motor in the headlamp.
Someone with a scanner could also put the AHL through its paces to determine which component was faulty.
Old 03-05-2013, 01:33 PM
The switch is on auto, neither side is moving what are the chances the both head lights have stuck motors?
If they are bad I have to replace the headlights, if so is there a way to override the error messages until I can fix them?
Thanks for your replies guys
Old 03-05-2013, 04:10 PM
Just to let the car have a say about things here, what were the error code #s? I'll try to look them up for you (key word "try")
Old 03-05-2013, 08:12 PM
Haven't pulled any codes yet, just getting the idrive message, just a while ago I started the car and the lights moved to self adjust the later got the message on I drive again.
I am baffled....
Old 03-06-2013, 09:54 AM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
I am baffled....
Remove the headlights and check the wiring inside, it is known to crumble over time. This might be causing your issue, if there are exposed wires cover them and reinstall and see if the error returns. You may need new SMC modules (located on the underside of the headlight assembly), these can be found on eBay fairly cheap.
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers
Previous 3 cars (the 550 is my 38th car):
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-06-2013, 11:48 AM
There is crumbling insulation, I saw it when I replaced my angel eyes, that was a while back, I brushed liquid tape on them.
this issue started a couple of days ago.
The headlights move up and down when I start the car but I don't see any side to side movement when I move the steering wheel.
Old 03-06-2013, 04:01 PM
peachykonan peachykonan is offline
Mein Auto: 2004 525i
@ GermanSteel - can you please help look up the following fault codes for me? I'm also having AHL issues and would like to know the repair procedure (and parts). I ran over a bump pretty fast which resulted in the following:
Autologic diagnostics quick test report for e60 525i 4 door m54
ADAPTIVE DIRECTIONAL HEADLIGHTS (AHL)
Contains 1 fault
A589 Communication with stepper motor box 1 impaired
LIGHT MODULE (LM)
Contains 1 faults
932E ALC-System defect
Old 03-09-2013, 09:39 AM
Contains 1 fault
LIGHT MODULE (LM)
Contains 1 faults
Hi. I tried but using the Bently Publishers Service Manual I could not fiqure anything out. I believe as mentioned in previous posts that you have crumbled insulation on your electrical wires in the headlight assembly and going over the bump cracked them open. You will need to remove the headlight assembly from car and inspect the wiring and repair if that is the problem.
Do you need pics of the service manual to help you remove the headlight assembly?
