Old 03-05-2013, 01:10 PM
newyorker0426 newyorker0426 is offline
Mein Auto: 2004 745li
Hard shift into 1st gear 2004 745li
Sent from my SPH-L900 using Bimmer App
Old 03-05-2013, 01:12 PM
Just took it to transmission place that took a quick drive acted like I should return it just bought it a week ago should I ve concerned
Also already tried trans reset
Old 03-05-2013, 01:19 PM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
What exactly did they tell you??
Fun Doesnt Come Cheap!
Old 03-05-2013, 01:56 PM
I work at dealership we have a account with this transmission place they drove it said either needs valebody or reman transmission but they didnt realky look into it it hard shift into 1st when coming to a stop it seems I have read other people saying the have had same issue just trying to get advice really had them look at state that there is somthing going on so I could bring to dealership I bought from while I am under the one month warranty just trying to get advice from people who have owned them
Old 03-05-2013, 02:05 PM
Ultimate745i
Try reprogramming and/or upgrading tranny.
Old 03-05-2013, 02:06 PM
How do I do that
Old 03-05-2013, 02:07 PM
Ultimate745i
You have to have somebody with the Coding programming Software do it. Either the dealer or someone who has it.
Old 03-05-2013, 02:18 PM
K
Old 03-05-2013, 02:20 PM
Ultimate745i
From other posts in here, it doesnt really sound mechanical, since it's only doing it in 1st gear, which is the complaint most have had. Just sounds like a programming issue.
Mine was doing that, but the manual reset took care of my issue.
Old 03-05-2013, 02:28 PM
Old 03-05-2013, 02:38 PM
Ultimate745i
Good Luck and be sure to come back and update us on your solution, no matter what it ends up being.
Old 03-05-2013, 02:53 PM
I will
Old 03-05-2013, 03:37 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
The guibo or flex disc also is known to cause slams. Alot of people including myself also did the tranny service which is new pan/filter along with new fluid and seeling sleeve and mechtronic adapter.
Old 03-05-2013, 06:18 PM
Perfect Gent Perfect Gent is offline
Mein Auto: 745Li
I just purchased a 2003 745Li and had the same problem. It was just diagnosed as being the Giubo/Flex Disc. The car only has 39k miles on it. that being said I find it hard to believe that its a trans issue with so few miles. I looked up the part and it runs about $60. It'll be next week before its fixed but will be very inexpensaive. Hope this helps... I'll post once completed
Old 03-06-2013, 05:45 AM
Thanks!! Talked to the dealership last night.I bought it from them last week they want me to bring it in I believe they plan on sending it to a bmw dealership to be checked out.. will update it has 80000 miles on it
Old 03-06-2013, 10:39 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
If you are getting a clunk sound when you put it into drive or reverse then most likely it your guibo aka flex disk. The guibo is a round rubber, almost bushing like part that connects the driveshaft to the transmission output shaft. It is there to help reduce vibration in the drivetrain. There are holes in it for the bolts to go through to secure it to the driveshaft and transmission output shaft. As the guibo wears out the holes start to have some "play" in them which cause they clunking sound as the bolts slam again the metal lining of the holes in the guibo when coming to a stop.
Since your problem is only happening in first gear that is probably the best place to start. The part should be under 150 and you should not pay more than 3 hours of labor to put it in. The exhaust will need to be dropped to change it so there is some amount of work involved.
Search under "guibo" or flex disk and you will find some other threads with information. You can usually find some good info search as much of these topics have been covered on here.
Old 03-06-2013, 02:59 PM
So the dealership I bought it from called me and said that was normal they real quickly realized I wasnt some smuck who was going to hear some bs like that so now they are talking it to bmw dealership tomorrow to be checked out...will update.
Old 03-06-2013, 03:01 PM
Oops taking
Old 03-07-2013, 02:04 PM
Latest update dealership called me said bmw looked at it said just needed some sort of computer update for tranny have not got it back yet so we will see if this solved problem
Old 03-07-2013, 02:45 PM
Ultimate745i
Damn I'm GOOD! Can we get some high 5's!!
Sent from my SCH-I535 using Bimmer App
Old 03-08-2013, 07:34 AM
You are the man... and got it back last night shifts great now no more hard shifts fron 2nd to 1st hopefully it will stay this way..
Old 03-08-2013, 07:36 AM
Ultimate745i
Just glad they didnt screw you around with all that other stuff that they said earlier.
Old 03-08-2013, 08:14 AM
Yeah I think they thought i would just say oh ok. When they said thats normal once they realized I work at dealership and have been selling cars for the last 10 years and know our state laws on the 30 day warranty they quickly said we are going to send it to bmw which is who I really wanted to look at it anyway so it worked out but thanks again for your help and advice
Old 03-22-2013, 11:26 AM
Mein Auto: 745Li
Does anyone know the cost for the Tranny software update ?
