Old 03-22-2013, 11:54 AM
newyorker0426 newyorker0426 is offline
Mein Auto: 2004 745li
Just had it done at bmw was like 360 $
Sent from my SPH-L900 using Bimmer App
Old 03-22-2013, 12:05 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
Wow thats crazy the dealer i used said they charge 125 to go through the car aNd update everything. They told me all they do is hook the car up, go to the computer and it goes through all the modules and updates them to the latest version if necessary. Meanwhile they walk away and do other things while your car sits there on a charger getting updated.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 03-22-2013, 01:26 PM
Well dealer I bought it from sent it to bmw and paid for it there invoice said thats what they paid...so that may not be right.
Old 03-22-2013, 02:43 PM
Punisher745Li's Avatar
Punisher745Li Punisher745Li is offline
BMW Enthusiast
Mein Auto: 2004 745LI
So I'm having that problem because when I release the gas pedal I feel that kick of the gear....any ideas? transmission? or guibo or flex disc?
Bayerische Motoren Werke
Old 03-22-2013, 05:07 PM
540i6spd 540i6spd is offline
Mein Auto: 540i
think this needs progaming
hey guys i got a 06 bmw 750li with a trans issue. i cant seem to drive nor reverse if i put the shifter down to D for drive it shoots back automatically to park and if i put the shifter up to R for reverse it shoots back to park i cant move at all i got to put it on neutral threw the key slot on the bottom of the steering colum. i droped the trans pan and then the valve body and changed the gasket that looks like two squares togther and also changed the sleve for the conecteor on the top. Closed it all up and put bmw trans fluid in and still has the same problem. not moving at all. please any replys can help thanks
Old 03-22-2013, 06:48 PM
Punisher mine was when I came to stop it would hard down shift from 2nd to 1st slight bang just needed software update not sure what your problem is but ultimate help me and seemed to get right on spot with the few issues I have had so he may know
Old 03-24-2013, 03:29 AM
JUBMW JUBMW is offline
Mein Auto: 2003 BMW 745LI
Originally Posted by Ultimate745i View Post
Just glad they didnt screw you around with all that other stuff that they said earlier.
High Five Ultimate 745i
Old 03-24-2013, 06:06 PM
BMW Enthusiast
Ultimate745i is the best! Imma check my flex disc to see if I can get over that problem...
Sent from my Galaxy S3 using bimmer app
Old 03-26-2013, 06:47 AM
Firecatdriverf7 Firecatdriverf7 is offline
Mein Auto: 745li ,Rx8 & 7
230 hear to update all software in the car , 2 hrs labour . Even if its longer max time is 2hrs @ 115.00 per hr
Old 03-26-2013, 07:55 AM
ArtL's Avatar
ArtL ArtL is offline
Mein Auto: 2006 750Li
Just had my flex disc replaced by an Indy with BMW mechanics. Seems to be much better but more driving will tell. I was told that the condition is common and that the new flex disc should help a great deal but not necessarily totally eliminate the issue. My 750 is a a 2006. $630 with labor.
Old 03-26-2013, 07:58 AM
ArtL's Avatar
Also flex disc showed sign of excessive wear at 56K miles.
Old 10-11-2013, 07:18 AM
ArtL's Avatar
Hard shift into 1st gear 2004 745li
I replaced the flex disc but the condition persists. Maybe not to same extent but this is still a problem. Sometimes I feel like I am being rear ended. By a car that is.
Old 10-11-2013, 08:21 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
Try transmission filter and fluid change along with the mechtronics sleeve and adaptor. How many miles does your car have?
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 10-11-2013, 08:30 AM
ArtL's Avatar
62K miles. Original owner car purchased in 2005.
Old 10-11-2013, 08:32 AM
ArtL's Avatar
Thanks. I'll look into that.
Old 10-11-2013, 03:30 PM
brettsg brettsg is offline
Mein Auto: 5 series
this is a known problem first you need to verify if this is a software problem or a trans problem. if you know someone with a scanner that can clear trans adaptation values do so. if problem goes away after it is a software problem. This is a short term fix and problem will come back soon but now you know where the root of the problem is. if it is a software problem there is a fox called 2-1 tip in. find someone that can program your trans for this. if not a valve body wont help you need a reman trans
