E60 (2004 - 2010)
Old 03-05-2013, 03:01 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z3 2.8L, 545i
Oil Pan Removal on the 545
OK the newest oil leak on the 545i is the oil pan. Looks like there is a weld hair line crack where the oil plug screws into. Looks like it is best just to put a new pan in rather than remove and have welded.
Anyone remove the oil pan on the 545i. Looks straight forward I am just hoping that there is no motor mount removal or any subframe hardware. Should I just be able to remove the support pan to gain access and just unbolt the oil pan section.
http://www.realoem.com/bmw/thumbs/r/p/128.png
Old 03-06-2013, 01:20 PM
mrgrumpy mrgrumpy is offline
Mein Auto: 2005 545i Sport
Sounds like the bolt was over-torqued causing the hairline crack.
I believe that the engine has to be lifted to remove/replace the pan. Big job.
Remember that oil leaks from above the pan will spread over the oil pan and collect near the drain plug so make sure it's not coming from areas above the pan.
The N62 is guaranteed to leak from key areas above the pan.
Old 03-06-2013, 01:27 PM
pjinca pjinca is online now
USAF Pararescue Veteran
Mein Auto: 2008 550i
This was a "feature" of the N62, it was designed to encourage people to get a 550 and then an F10 550
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers
Previous 3 cars (the 550 is my 38th car):
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-06-2013, 01:41 PM
schpenxel schpenxel is offline
Mein Auto: E60 - 545i
I've seen pictures of this being done on a 7 series where they used an engine hoist to hold the engine (BMW has a special tool that mounts to the shock towers that does the same thing), then dropping all of the front suspension/cradle to get at the oil pan.
Doesn't sound like a fun one
Old 03-06-2013, 06:53 PM
cadillacbart cadillacbart is offline
Mein Auto: BMW 545i
If I was faced with this, and did not have the desire to pay to have the motor pulled, I would try to fill the crack with JB Weld. Let the flaming begin!
Current cars:
'05 545i
'06 MB R350
'03 allroad (for sale!)
'68 Deville Convertible
Old 03-06-2013, 07:03 PM
No flaming, if you don't have the time/skill/money to do it properly this could be a quick, albeit temporary solution. Eventually it would need a more permanent remedy.
2006 Jeep SRT-8
Hogie's Avatar
Consider yourself flamed
OK - The results are in...
Easy.... The 545i oil pan is in different sections. 1 cast and 1 steel. The drain plug is in the steel section and can be removed by:
1. Put the front on jack stands
2. Remove both forward and rear carriage covers
3. Remove the reinforcement plate - Shiny metal plate that covers oil pan
4. Drain oil - duh
5. Disconnect the oil level sending connection
6. Remove the bolts and leave two in-place to catch the pan as it drops
7. That is it - This was well designed (except for my plug insert
Wow I have 182K miles and the inside of this pan was CLEAN!!. Wiped it out and it was shiny metal clean, wow.
I am having the plug thread insert rewelded. Guy has a nice mig and states it will be straight forward.
I'll post the outcome tomorrow.
Old 03-06-2013, 07:05 PM
Cool, good deal, glad it worked out that easy (so far).
2006 Jeep SRT-8
