E36 (1991 - 1999)
Old 03-06-2013, 05:23 AM
darren325 darren325 is offline
Mein Auto: 325i
warm air
i have a 325i and it seems to blow cool air when the engine is hot through the vents untill i rev the engine up or drive like a looon,,,, is this normal... thanx 4 ur help with my worries,,, i should add its when i want hot air as its still cold here in london
Old 03-06-2013, 06:19 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Search google for "pelican + bleeding e36".
You have air trapped in your cooling system. Even if you've bled it you still missed some. Yes, do it again. Now that it has been done AT LEAST twice, do it again.
Yes I am serious. Yes, many others here will confirm this.
Note that I didn't bother to say to check your coolant level ass doing this will top it off regardless of the coolant level initially.
Sent from my U8651T using Bimmer App
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-06-2013, 03:47 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
this sounds like air in the system, and, as ed mentioned, refilling the system should bring you back to normal operation of the heater. however, if you find that the cooling system is full and there are no other indicators of a leak somewhere, you may have a restricted heater core.
checking the operating temp is also a factor should the cooling system as an improperly operating thermostat could cause issues as well. the temp guage should read 1/2 when at operating temp.
and welcome to the fest!!
df
