E90/E91/E92/E93 (2006 - 2013)
Old 03-06-2013, 04:27 PM
Mein Auto: 2007-335 HTC
335I Replacing front Struts
well I started to replace the front struts on my 335I, and started the job today, and the struts on my 335 have the pinch type connector, the tube slides down thru the wheel assembly and I got to the point that I figured I would have to take all the linkage loose and drop the wheel assembly so I had enough room to pull the strut up and out, So bolted it back together and to the BMW place I will go. I guess I have lost my patience for stuff like this and seems I always break something during the process
I admire the young guys that keep at it till they are done, not that i am that old
now if I have a manual that told me how to do it, maybe I would keep going
its good I have a sales job that I work hard at and it pays well so I can pay someone else to do it
Hondo
know you limitations and dont be ashamed to admit you cant do it
Old 03-06-2013, 04:34 PM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
Sorry you gave up so quickly
With the right tools*, this is a relatively easy job.
*newer cars increasingly require special tools for seemingly routine repairs.
Old 03-06-2013, 04:43 PM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Hondo
Don't give up yet! Here's how I did it, and that pinch clamp was no prob at all once I saw how it was easily opened.
Old 03-07-2013, 05:08 PM
rubberismoney rubberismoney is offline
ADJUSTABLE BOOST
Mein Auto: '07 335i coupe
Hondo
If you're doing it on a rack of sorts (alignment, 4 post, or 2 post) I recommend putting a come-along into the lower ball joint hole, where you removed it prior, and removing all other bolts prior to this, just pulling the steering knuckle down with everything else. It works great and will hold everything in place until you put it all back together. Also struts are so general go to a local indie shop and have them do it at a fraction of the cost if you do not succeed, as they will not screw it up (or at least I really hope so) But hey at least you gave it a shot man. Way better than 99% of people out there. Kudos to those who actually attempt to put in a little effort
