Old 05-07-2015, 10:07 AM
Pcklentz Pcklentz is offline
Mein Auto: 2003 530i
No sound
I got my car back from the shop today and the radio has no sound. All the radio functions work but no sound. Had the struts/shocks changed, passenger seat repaired, MAF sensor cleaned, and the regular service. It doesn't seem like anything was done that would affect the radio. Any ideas?
Old 05-07-2015, 10:27 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Does the CD player work?
In order to replace the rear shocks, the rear seat must be removed, as well as the C-pillar covers, and the package shelf cover. The antenna amp is behind the left C-pillar cover. Take it back; they've done something.
Old 05-07-2015, 10:34 AM
That's what I am thinking as well. CD player works but no sound.
Old 05-07-2015, 10:58 AM
computiNATEor's Avatar
computiNATEor computiNATEor is offline
(oOO\(|||) (|||)/OOo)
Mein Auto: 03 530iA Sport
Hmm. Check to see that the cables around the radio unit in the back are properly seated. I'd go with the rear deck being the source as well.
Nate J.
Seabiscuit: 03-11-03 e39 530i Sport, Steptronic, Black/Black
Totaled (by me!) & Rebuilt in Fall 2014
Completed Work: Maintenance; Silver gauge rings; ECS Tuning SS Brake Hoses; Koni FSD "Golds"; Meyle rotors, Akebono Euro Ceramic pads (no dust, no bite); BMW blue-painted calipers; Aux retrofit; Canholder delete; Ultimate Cup Holders; Custom IKE coding; "BMW" valve stem dust caps; Euro lower dash; GAS DISA rebuild + coolant cap.
Bold text is best mod!
Old 05-07-2015, 01:46 PM
oli_e39 oli_e39 is offline
euro euro euro !!!! (:
Mein Auto: bmw 540i 1999
Do you have the dsp or non dsp?
Old 05-07-2015, 01:55 PM
Don't know. How can I tell?
Old 05-07-2015, 02:02 PM
If you have dsp it will have a dsp button right neXT to the audio button . I attached to pics one with dsp and one without .
ID:	508086   Click image for larger version
Too*
Old 05-07-2015, 02:17 PM
Non-dsp
Old 05-07-2015, 02:24 PM
Check these fuses under the glove compartment 56,58, and 43. If those are good. Check if your amp is getting power in the trunk where your cd player is located . You Can Also Try This , Turn Your ignition switch to the last position before turning it on and bring down the sun visor and open the vanity mirror the light should go on , also there might be sobe funny stuff going on when you do this if you get sound after that its gunna be your ignition switch .
Old 05-07-2015, 02:26 PM
Some * . For example my ignition switch was bad and when I had no sound or even the radio won't start I tried that and it would turn on give me sound it be good. Thx to the forum I was able to get it diagnosed and fixed
Old 05-07-2015, 03:27 PM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
Your amp could be fried. My radio stopped working out of the blue one day, it turned on and off but no sound at all. Replaced the amp with a spare one and everything worked. I did not do diagnostics on the old amp I figured I might as well try the swap and it worked.
Old 05-07-2015, 03:37 PM
I still suspect that the problem is a result of the shock replacement.
Old 05-07-2015, 03:40 PM
Edjack I'm with him double check alle your connections are tight , and or connected
Old 05-12-2015, 10:09 AM
Bad amp. Coincidence? Maybe.
Old 05-12-2015, 10:23 AM
Probably. Unless you can find evidence of tampering. The only thing they could have done was create some static charge while working, but I find that unlikely.
Nate J.
Old 05-14-2015, 03:54 PM
Well, it turns out that their used amp was no good. So I am removing my old amp and looking for a good used one. I have the amp unbolted but I can't gigure out how to remove the plugs. Ideas?
