P2187 and P2189 : System too lean at idle - Bimmerfest - BMW Forums
Old 03-07-2013, 11:48 AM
SS102310 SS102310 is offline
Mein Auto: 2006 750LI
I'm a bit confused on what this meant on my reader, and what's the repair cost or does anyone know the solution for this problem?
Old 03-07-2013, 11:26 PM
02x745Li 02x745Li is offline
Mein Auto: E63 TT S-model
Deleted
Old 03-08-2013, 10:05 AM
FLEXAMILLION FLEXAMILLION is offline
Account Under Review
Mein Auto: 2003 745LI
Underneath the plastic (bmw) valve cover, you will see a round cap. One one the left valve cover and one on the right. They are called pressure regulator valves... The black caps can be removed, and underneath, you will see a orange disc. This is the part that needs to be replaced. You can go pick it up from BMW for $22. Per disc. The disc act like a rubber "heart".... They pulse up and down ... They regulate the idling. Very easy job... About 40 mins of work..
Old 03-08-2013, 10:10 AM
When you take the old ones out, you will see that the disc are filthy and cracks have developed in the rubber ring... The extra air goes into those crack and causes the car to idle funny...
Old 03-08-2013, 11:27 AM
Firecatdriverf7 Firecatdriverf7 is offline
Mein Auto: 745li ,Rx8 & 7
So EGR valve I take it? That's great that their Serviceable
Old 03-08-2013, 02:36 PM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
They are not EGR valves, they are crankcase vent valves
Old 03-08-2013, 02:47 PM
Ok sound good
Old 03-11-2013, 05:48 PM
My car does idle funny and it sometimes shuts down by itself wen I stop
Old 03-11-2013, 05:54 PM
pedro2u pedro2u is offline
Mein Auto: 745i
when the CCV's completely fail, a test for them is to pull out the dipstick with the engine running. If you can't, or it stalls the CCV's are usually the cause
Old 03-11-2013, 06:39 PM
Mein Auto: 745i
correction (since this was a while ago) it was the oil filler cap that I couldn't remove, not the dipstick. Sorry
