E36 (1991 - 1999)
Old 03-07-2013, 04:01 PM
Airborne95m3 Airborne95m3 is offline
Mein Auto: 95 m3
Hard start
So I just get my rebuilt motor put in. I was Able,
to Add about 100hp through it. Catch is my car doesn't like to start reliably. I've checked Nd replaced the fuel pump. Replaced the cam and crank sensor. I bought the TMS chip for 3.5 hme and 24# injectors.. Still nothing even tried differant computer and nothing... I tried my computer in Nother m3 and started right up.. Now the guy is think the wiring harness.i haven't been able to find a 95 harness. But I've been told I could use a 94-95 harness but would have to manually disable/by pass the EWS. Am I on the right track??
Old 03-07-2013, 04:11 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Originally Posted by Airborne95m3 View Post
So I just get my rebuilt motor put in. I was Able, to Add about 100hp through it.
Just curious, how did you add 100hp to your engine? Also, who is Able, and when did you stop being him?
Otherwise, you already have a thread regarding your wiring harness. Please refrain from creating multiple threads about the same thing.
1998 BMW 328is
1966 Pontiac GTO
Old 03-07-2013, 04:22 PM
Mein Auto: 95 m3
If you had read the other post you would see the information is COMPLETELY differant..
Old 03-07-2013, 04:37 PM
ZeGerman's Avatar
Warm Leatherette
Your other thread is about wiring harnesses, and this thread is about wiring harnesses & EWS. What am I missing?
1998 BMW 328is
1966 Pontiac GTO
Old 03-07-2013, 04:40 PM
Mein Auto: 95 m3
In the other thread I was directly asking if a particular harness would work. The second thread is implying for opinions and advice against the hard start issue. Forgive if its I te wrong spot I haven't been on the forum much
Old 03-07-2013, 04:46 PM
ZeGerman's Avatar
Warm Leatherette
Okay, it is somewhat hard to understand what you're writing. So you have the TMS chip for a 3.5 MAF and 24lb injectors. Do you actually have a 3.5" MAF and 24lb injectors? Also, check for vacuum leaks, and verify that your fuel pump is working correctly, and confirm your fuel pressure at the rail.
I'm also still curious to learn how you got 100hp over stock without a turbo or supercharger.
1998 BMW 328is
1966 Pontiac GTO
Old 03-07-2013, 04:55 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
With Nawwwss, yo.
Duh.
Any errors in this post are purely Swype's fault, not mine.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 03-07-2013, 05:14 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
and dual ram airs, yo...
df
