E34 (1989 - 1995)
Old 03-07-2013, 08:22 PM
Dionte Dionte is offline
Drive her like an ///M
Mein Auto: 1992 BMW 535i (manual)
AC only works on full blast
Could there be some kind of clogging? Is it a simple fix? Heater and Ac only work on full blast for some reason
Any comments appreciated!
1992 535i 5-Speed
Old 03-07-2013, 10:11 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I think Its your blower Resistor that failed .Search this site for blower resistor replacement . it controls the blower speeds.http://www.bimmerfest.com/forums/sho...d.php?t=546828
Old 03-11-2013, 08:07 AM
Thanks, i will check it out.
Old 03-11-2013, 09:01 AM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
its a failed resistor, but you have to find out which you have.
For there are two which are allegedly year dependant. (I found not to be true from 1989-1993.5)
You have either a final stage resistor sword or a resistor pack.
Both are completely different and are located on different sides of the center console.
The easiest to replace is the resistor pack.
It's located above and to the right of the accelerator pedal.
You'll have to remove the lower kick panel and carpet panel on the center console to see it.
The sword isn't so easy to replace but easier to check.
It's located behind the center console, behind the Hvac / heater core box on the passenger side.
You can remove the carpet from the center console to check. It will look like this.
To remove it you'll have to remove the glove box. For you don't have enough room down there to just pull it out.
_______________________________________
Content Writer - FCPEURO
95 e34 525 5 spd S52 Swap...Sold
01 e38 740i msport (under restoration )
Old 03-16-2013, 06:36 PM
So you think its more worth it to find the resistor I need, and replace it myself?
Sent from my SGH-T839 using Bimmer App
1992 535i 5-Speed
Douglasville, Georgia
Old 03-16-2013, 08:13 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
Unless you have a healthy trust fund, you need to learn how to fix this car. Look at your list already... You still haven't gotten to doing the suspension front and rear or a complete cooling system. You CAN do all of these things yourself. MSD even provided pictures, you really have no excuse for not fixing it now
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 03-17-2013, 06:00 AM
JayzBimmer JayzBimmer is offline
Mein Auto: 95 525i
thumbs up for helping snow and MSD.....Dionte we've all been there, first car, tight budget, etc......the first thing I always did with any used car purchase that I was planning on keeping was to buy the best manual you can, in the case of BMW's its called Bentley...new they're about $60, but might check ebay....between that book and the helpful guys here (yh Ive seen the burns on other forums, especially towards noobs) you should have your car running strong in no time.....
Old 03-21-2013, 07:36 AM
Ok, ill look into it. Thanks.
1992 535i 5-Speed
