E46 (1999 - 2006)
Old 03-08-2013, 10:50 AM
BertStevens BertStevens is offline
Mein Auto: 323i
Time for the cooling system
Just when I finally got all the grease out from under my nails from overhauling the VANOS, now I have to dig in again.
The thermostat appears to be stuck open. I've noticed the coolant temp gradually getting lower over the past couple of weeks. Today's drive to work barely got above the blue mark. And it was a cold driving in to work. Sooooo...rather than just replace the thermostat, I'm going to go ahead and do the water pump, thermostat, temp sensor, and hoses. Overflow, tensioners, pulleys and belts were replaced just 13k miles ago by previous owner.
Parts are on order and I guess I'll spend a few hours of my vacation next week getting it done.
Sent from my DROID RAZR using Bimmer App
Old 03-08-2013, 11:13 AM
OfTheLost's Avatar
OfTheLost OfTheLost is offline
Mein Auto: 2000 328i
I feel your pain, if its not one thing its usually another.... hence the love/hate relationship at least youre staying on top of things though
Old 03-08-2013, 02:35 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
You're doing all the right things.
But add to your knowledge that the dash temp gauge is not an accurate refection of the temperature, or certainly the stability of the temperature.
Therefore for more accurate readings, use the OBC hidden functions to get the realtime temperature reading with precision. I think you'll be surprised how much more revealing this is.
Old 03-08-2013, 04:29 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by GoForthFast View Post
the dash temp gauge is not an accurate refection of the temperature, or certainly the stability of the temperature..
This may help a bit ... (it's for the E39, but it's the same engine as on the E46):
- What is the temperature of the coolant when the M54 thermostat opens under normal conditions (1)
Old 03-09-2013, 04:52 AM
Mein Auto: 323i
... for more accurate readings, use the OBC hidden functions to get the realtime temperature reading with precision. I think you'll be surprised how much more revealing this is.
Actually, I did this last week when I suspected the thermostat was sticking. Only 66 degrees. That plus even lower dash readings now and lack of heat all point to a stuck thermostat.
But I appreciate your suggestion! The sharing of experiences and the DIYs are what makes this board great.
Old 03-10-2013, 07:50 PM
chet31 chet31 is offline
Mein Auto: 05 330i convertible
Replace the expansion tank while you're at it (unless it's already been done).
