Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 03-08-2013, 09:32 PM
Wu! Wraps's Avatar
Mein Auto: 07 335i 91 325i
vinyl wrap your a/b/c pillars & chrome window trim
finally worked on an e30 other than mine. so the B/C pillars were completely oxidized and turning chalky, wrapped them up with Oracal 970ra matte black (more of a satin black) and now they look brand new! also did the chrome strip along the top of the door panel on the inside, they were pretty chipped up and stuff too. great easy cheap fix to make your e30 look more up to date. total job time was 1.5hrs, owner is diggin it! Wu! Wraps
Wu! Wraps
Custom Automotive Wraps
wuwraps@gmail.com
Old 03-09-2013, 04:02 AM
Wolfy Wolfy is offline
Mein Auto: 1988 BMW 325i
How much does something like that cost because my convertible could use that done to it.
Old 03-19-2013, 06:25 PM
Wu! Wraps's Avatar
i assume your talking about the chrome trim around the windows right? if so, i usually charge around $150-$200ish for that stuff here in seattle wa. iono what guys in your area would charge. look for a highend tint/clear bra shop to do the work. typically your neighborhood sign and graphics shop will not do this type of job.
Wu! Wraps
wuwraps@gmail.com
Old 03-19-2013, 07:26 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
or $15 for paint and tape to mask the parts off and have them looking new.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 03-19-2013, 11:34 PM
Wu! Wraps's Avatar
yes that's also 1 way of doing it. works great for non chrome surfaces like the door pillars on a coupe/sedan. paint is not so great for chrome window trim on the vert like Wolfy is referring to.
Wu! Wraps
wuwraps@gmail.com
Old 03-20-2013, 02:38 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Lifted Jeep,240z
If you sand it, prime it, and paint it then it sticks just fine
(1986 BMW325es -MSD ignition coil/ebach springs/bilstein sport shocks/Ireland Engineering sway bars/K&N air filter/"high flow" cat/dodge shadow radiator/ANSA resonator/3.46 LSD/CERAMIC brakes/Dinan chip/Shaved Head/Ported Intake manifold) = sex on wheels
Old 03-24-2013, 09:26 AM
adjmcloon's Avatar
adjmcloon adjmcloon is offline
Mein Auto: '99 528iT sport
What's your technique for cutting the vinyl after you stretch it? I have done this and it always looks great until I cut it. No matter how hard I try I always end up with a couple of weird sections
2001 530i tiAg sport (sold)
2002 540iA sport (sold)
2006 330i sport (sold)
2008 535i-6 sport (sold)
1999 528iT sport (sold)
2002 525iT alpine sport
1990 325i sedan
1990 325is coupe
Old 03-25-2013, 06:46 PM
Wu! Wraps's Avatar
sounds like tape, sanding, and paint is def another option for this look. good to know that it will stick well to chrome after some light sanding!
adjmcloon: the key is not to stretch it too much, and when you do stretch it u must heat it up real good so the vinyl looses its memory (ability to shrink back). you just gotta kinda know how much to heat it, hard to explain... but then you let it cool a bit so its not all soft before you cut it. maybe wait like 1min or so. cut your material, then go over the exposed edge again with the heat gun (called post heating).
for the window trim parts on the e30 you should not be really stretching the vinyl at all. its such a flat surface that you just soften it up and work it around the edges.
Wu! Wraps
wuwraps@gmail.com
