E30 (1982 - 1993)
Old 03-09-2013, 04:26 PM
skinzochud skinzochud is offline
Mein Auto: 1984 BMW 318i
318i m10 shuts off after starting and when you give it gas
I have a 84 bmw 318i with a m10. i have replaced the battery, MAF sensor, idle air control valve, distributor, but i still have the same problems. It will start idle for a moment then shut off. if you give it any gas it will flood itself out spit and sputter. also when you turn it off and pull the key out the car will stay running for about 10 seconds then shut off. I REALLY NEED HELP! if anyone one can give me answers i really need them. the bmw is in the shop right now but the mechanic is also struggling. he is checking the fuel lines out monday. Thanks everyone.
Old 03-09-2013, 06:15 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
thats VERY strange that it keeps running if you car is a fuel injected car. not uncommon for carby engines in poor tune to do that, but pretty much impossible for efi engines.
your car does not have a MAF sensor.
is your car EFI or carby?
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 03-09-2013, 06:40 PM
downhiller's Avatar
livin large
must be afm. i would do a fuel pressure test.
then off to checking spark plug wires, cap, rotor, and coil
Old 03-10-2013, 04:03 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
If EFI, consider replacing the blue coolant temp sensor.
Also check all hoses associated with the intake sensor for cracks which self seal when the engine is off or at idle, but are pulled open when the engine torque makes the engine roll on its mounts with throttle application.
m
Old 03-10-2013, 08:54 AM
romeomike's Avatar
romeomike romeomike is offline
Running life's race...
Mein Auto: 91 318i
Haven't had to work on an M10 in about 20 years, so I'm generalizing from my M42 experience. In the near term, I'd be looking at the fuel system (filter, pump, pressure).
Over the last two years, I've been able to clean up a lot under the hood. As you get the funds and time, consider doing the following in addition to what you've already wrote about
Attend to all air leaks (vacuum hoses, intake manifold gasket).
Replace any old coolant hoses.
New fuel injection-rated hoses and clamps if required.
Test the throttle position switch, replace if needed.
Check alternator output, and replace the voltage regulator/brush assembly.
I just swapped in a used fuel pump, and that corrected rather severe drivability problems. Adding in a better used ICV and refurbished AFM, and my 216K+ M42 is back to its customary reliable self.
On Christ the solid Rock I stand, all other ground is sinking sand. (Edward Mote 1797-1874)
Old 03-10-2013, 12:38 PM
I have checked vaccum hoses. and fuel pressure is 48 psi. both fuel pumps are good. its a fuel injected bmw. no carb. injectors are shooting fuel. thanks everyone for the info. but its everything we have already done to the car. but its still going about with the same problems.
Old 03-10-2013, 01:14 PM
downhiller's Avatar
livin large
how about engine ground? ill start pushing to electrical more than mechanical.
Old 03-10-2013, 11:49 PM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Stupid question but after replacing the distributor do you have the plug leads in the correct sockets ie. is the firing order correct?
Old 03-11-2013, 09:10 AM
Yes. fire oder is correct.
Old 04-28-2013, 03:24 PM
scharf1 scharf1 is offline
Mein Auto: 84 318i
my car is doing the same thing 84 3181 m10. i haven't figured it out yet. soon as i do i will let you know. i was told to check FPR. seems logical that it could be that and vacuum leaks.
Old 11-27-2014, 01:42 AM
ScubScubly ScubScubly is offline
Mein Auto:
Mine was doing the same. I removed the air filter unit and cleaned the mass airflow sensor with a toothbrush.
It kicked over and ran for a while but kept spluttering and dying when I'd reconnect the connector. Which is leading me to think that there's a fault somewhere else. Give it a try, it might work for you!
