Old 03-09-2013, 06:40 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Oil Leak!
Today, I started up my car for the first time after not starting it up for 1 week in the garage due to a busy schedule. What I found scared me right away.
Name:	650i Oil Leak.jpg
Any ideas as to where the leak may be from? I just had the upper right timing cover gasket re-sealed about 2,200 miles ago.
FYI: I have about 57,800 miles on the car right now.
Once a 6'er, always a 6'er.
Old 03-09-2013, 06:48 PM
HerbP HerbP is offline
It could be valve cover related, sensor related, or alternator o-ring bracket related. I suggest to spray the engine down with some engine gunk, & start trying to locate the leak. Oil has funny ways of going all directions, when it starts to leak. You might have to remove the lower covers to get a better look.
Good Luck!
Old 03-09-2013, 06:53 PM
07 E63650i's Avatar
Freude am Fahren
Good Luck!
Thanks HerbP. Right now, I have scheduled an appointment for the dealer on Monday. Luckily, I still have about 4 months of CPO warranty left. Would a leak like this be covered under CPO?
Old 03-09-2013, 06:54 PM
It should be covered!
Old 03-09-2013, 06:55 PM
07 E63650i's Avatar
Freude am Fahren
Thank you!
Old 03-10-2013, 01:27 AM
reytran's Avatar
reytran reytran is offline
Nothing quite like a 6
Mein Auto: 09' 650i Cabrio
I just have one extra question according to oil leak:
If the car is lowered and slammed on a bump, will that cause oil leak and will that oil leak problem will be covered by CPO ?
2009 BMW 650i Cabrio (daily drive)
2011 Audi A4 (groceries, bully, road trip, winter beater, family car)
BMW CCA ID: 473647
Old 03-10-2013, 05:48 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
You will have a hard time trying to get that one covered. If the car is taken out of spec its an excuse for the dealer not to cover the work but will charge for it. This is one of the reasons why I have not done any mods to my cars until the warranty is up.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 03-10-2013, 05:51 AM
pablo645's Avatar
In regards to the leak, are you sure it's oil? could be a possible coolant leak. The coolant will also leave an oily feel to the touch. Was it on the passenger side? It could be the common O-ring faliure for the Temp sensor issue.
Previous Cars:
Old 03-10-2013, 09:37 AM
07 E63650i's Avatar
Freude am Fahren
I'm fairly positive that it is oil. Would the coolant color be blue? The leak did come from the passenger side and I found out that it is the vacuum pump leaking oil.
Old 03-10-2013, 10:52 AM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
This might sound strange but I had a one-time oil spot in my garage. Someone suggested it might be weather/temperature related.
While this made little sense to me ,there was some serious temperature changes then and it never happened again.
Might want to wait a day or so to see if you see it again.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 03-10-2013, 12:53 PM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2014 BMW ///M6 vert
I had an oil leak in/around the vacuum pump last month - they replaced the pump and seals under CPO. There is also a sending unit right below the vacuum pump that can be the source of the leak. Good luck.
Regards, Greg
'14 M6 vert, san marino blue on amaro brown full merino leather, drivers' assistance, exec package, B&O sound system, CCB package, akra exhaust, tint, windscreen, etc.
'07 650i vert, beige/jet black, sports & cold weather pkgs, comfort access, etc.
'11 Acura MDX Advance with Entertainment pkg for wife - no mod's '04 Acura TSX (daughter) and '12 VW GTI - Autobahn (son)
Old 03-10-2013, 03:30 PM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
That is great news! Mine just crapped out 4 months after my CPO ended. I did it myself and it wasn't terribly hard, but dealer option is way better. Thankfully an aftermarket company has put together a gasket rebuild kit for us non-warranty victims.
This is one of those cases where BMW's "replace the entire part" is a huge help. If BMW had this as a part that they could just replace the seals you would be out of luck. But since the Vacuum Pump is a non-repairable in BMW's eyes then the CPO kicks in to replace the part.
Old 03-10-2013, 08:30 PM
The BMW coolant is blue. I have never seen blue oil before?
Old 03-11-2013, 11:30 AM
07 E63650i's Avatar
Freude am Fahren
Even though the dealer is not allowed to deny you coverage even if your car is modified, they will do so in order to charge you. They automatically assume that modified cars have problems on the owner's behalf.
Old 03-11-2013, 12:04 PM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
Remember underneath your car at the front is a plastic pan cover, so if your sump was damaged you would have to break this cover first, it is easy to check just look underneath!!!!
If this is okay then no slamming has occurred.
Always said I would go back to a 6 series
Old 03-14-2013, 05:38 PM
07 E63650i's Avatar
Freude am Fahren
Update
According to the SA and service technician, my vacuum pump is ok, but the oil leak came from a worn Mechatronics sleeve. They re-sealed the transmission oil pan with a new gasket and bolt. Total cost with CPO: $50
Old 03-14-2013, 07:41 PM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
I'm dreading the day this happens. But you gotta pay to play.
Old 03-15-2013, 06:18 AM
gregb's Avatar
fortunately my mechatronics already happened a few months ago and was covered under CPO (around 80K miles).
Regards, Greg
Old 03-15-2013, 07:28 AM
I was fortunate also that they replaced mine while still under factory warranty. But it is leaking again 2.5 years later, of course right after my CPO expired!!!
Stupid crappy non-longlasting junkie parts that cheap-ass-bmw uses!!!
ha, no worries, will eventually have an indie get it fixed.
Old 03-15-2013, 08:39 AM
07 E63650i's Avatar
Freude am Fahren
I hear you Mark. It's always the seals that are causing problems along with plastic tranny pans. Maybe BMW planned it to be that way, or these engines run really hot and take a toll on the seals?
Old 03-15-2013, 10:19 AM
True-that. All internal combustion engines run hot! I refuse to let BMW off the hook by blaming anything but what I think it is, making more money by using inexpensive parts.
Old 03-15-2013, 01:57 PM
07 E63650i's Avatar
Freude am Fahren
What a shame. Even the seals on my dad's 2006 Toyota Tacoma with 164,000 miles hasn't even leaked yet(knock on wood).
Old 03-15-2013, 01:58 PM
07 E63650i's Avatar
Freude am Fahren
Very true. Many can afford to buy, but can they afford to own?
Old 03-15-2013, 05:33 PM
roseng's Avatar
Got that right. I have a 99 expedition 5.6L that I bought new. It has 256K miles and no leaks and you can't kill the thing.
Old 03-15-2013, 06:44 PM
Exactly!!! My 2000 Jeep Wrangler that I have put through some 4-wheelin' hell doesn't have a leak. 107k miles.
