Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 03-10-2013, 10:56 AM
dalejohnson2000 dalejohnson2000 is offline
Mein Auto: 325i Convertible
Poor Idle
1990 325i convertible
Short History
Broke timing belt, bent valves.
Repaired.
Now it is difficult to crank, spins over fast but just won't catch fire. After a few tries it will fire and rev up fine.
Very weak idle.
But it will idle when cold.
Low power at take off.
At speed it has good power.
After driving a bit it will usually die when I stop at a red light.
A strange thing I found, when idleling cold, if I pull off the oil fill cap, it will go dead.
I figured I got the timing off by one tooth, but I just pulled the front of the motor off and it is dead on.
I have one other thought, but before I pulled the motor apart I didn't hear a vacuum leak.
Any thoughts before I put it back together will be helpful?
Old 03-10-2013, 01:18 PM
downhiller's Avatar
livin large
check the fuel pressure when running cold and let it warm up with the gauge on.
things im thinking of, fpr or stuck injector, although the oil cap thing is throwing me off
Old 03-10-2013, 01:31 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Poor idle/dying when the oil filler cap removed is normal. The crankcase is a closed system. Taking the cap off creates a huge vacuum leak. It would be ABnormal if it didn't affect the idle.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 03-11-2013, 03:51 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
lets me believe that your valves are not sealing properly.
Either another mucked-up cylinder repair or your valve adjustment is far too tight
Don't take life too seriously; no one gets out alive !
Old 03-13-2013, 05:40 PM
I checked the valve job with the cam out. Head upside down and poured kerosene into the combustion chamber and let it sit. No leaks into exhaust or intake runners.
I'll check the valve lash again this weekend.
My compression tester won't go down into these spark plug cavities, they are way too deep.
But pulling it around with the wrench to get to TDC I can feel each cylinder pumping up.
I'll pass along findings.
