E46 (1999 - 2006)
Old 03-10-2013, 01:49 PM
darrenarnold darrenarnold is offline
Mein Auto: e46 323i
Clicking when trying to turn over
Really hoping someone can help me with this.
I own an E46 318i coupe 2000 and recently it has developed a starting problem.
It will sometimes start but then when I turn it off and try to restart it again all I get is 'click click click' and the headlights flash
Ive changed the battery and its still the same.
Has anyone had this before??
Sent from my GT-I8190 using Bimmer App
Old 03-10-2013, 02:16 PM
GoForthFast GoForthFast is online now
Mein Auto: '04 330Ci 6-speed
Changed the battery and did not work any better right from the start?
Click, click is coming from starter area?
If problem never improved with new battery at all, suspect an erratic starter.
Old 03-10-2013, 02:56 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Another possibility:
If you continued to drive on the old battery, you might have damaged the alternator (not unheard of in cases like this). Have the output checked on yours....
Check all ground wires, make sure they`re clean & tight.
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 03-10-2013, 11:21 PM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
The alternator won't affect starting. OP I think you need a new starter.
Old 03-10-2013, 11:40 PM
Fast Bob's Avatar
Keeping it surreal
You`re missing the point, Zippy. If the alternator was cooked due to driving on the old battery for too long, the *new* battery wouldn`t last very long either....
(R.I.P. Jever)
Old 03-10-2013, 11:47 PM
Yes, agreed. But OP mentioned that he was unable to start his car even with the brand new battery installed.
Old 03-11-2013, 07:28 AM
Jat007 Jat007 is offline
Mein Auto: 325i
Is this a 5-speed manual or auto box? If it's a manual transmission, put the car in 3rd gear and rock the car a little... This will free the starter gear being stuck to the flywheel. I suspect the little gear at the end of the starter is probably stuck and not moving back and forth like it should because due to age of the starter.
I would still jump start the car while cranking over the motor with the new battery. I just helped my next door neighbor with the exact starting problem on his 325i last week.
Old 03-11-2013, 09:25 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2004 ZHP Sedan
I'd suspect either a bad starter or bad connections.
Check out my BMWBLOG!
Old 03-11-2013, 01:12 PM
Mein Auto: e46 323i
Thankyou very much for the replys
Ive bought a starter so will fit that over the weekend n see what I have. Its a frustrating problem because it doesn't do it at all now with the new battery. Yet it did still have the problem when I first fit the new battery.
Old 03-11-2013, 02:00 PM
Fast Bob's Avatar
Keeping it surreal
Better brush up on your curse words before attempting to install that starter....
(R.I.P. Jever)
Old 03-11-2013, 02:10 PM
smolck's Avatar
ROLL TIDE!
It'd help if the OP needed a new clutch. When I get around to doing mine I am replacing my starter with a BRAND new one. Easy to do when the trans is missing.
Old 03-11-2013, 04:16 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
You bought a new battery and a new starter, and there's no mention of use of a $20 DMM?
Tell me that's not true.
- Common tools needed for your BMW & an obdii DTC scanner & an SRS reset tool & accurate measurement tools & specialty cooling system tools
See also:
- How much does personality type play a role in how people approach an unexpected BMW repair (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 03-11-2013, 04:30 PM
Mein Auto: e46 323i
A dmm?
Old 03-11-2013, 04:33 PM
Mein Auto: e46 323i
Oh of course. . A multi meter lol.
I actually have 1, but didn't really think to use it
