How important is replacing the nut grommets when replacing the valve cover gasket? - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 03-10-2013, 05:11 PM
CCA323 CCA323 is offline
Mein Auto: 323
I replaced the valve cover gasket today and didn't realize that I forgot to replace the 15 rubber nut grommets. I bought the parts, just forgot about it until the job was done.
I did inspect all the old ones when I took them off and they appeared to be in good shape unlike the old gasket which all hard and nonpliable.
What do you think? Is it worth the 1-2 hours to replace the grommets?
Old 03-10-2013, 06:50 PM
elhombre's Avatar
elhombre elhombre is offline
Mein Auto: 2003 325i, '99 e36 328is
If you have no leaks, forget about it. But realize you may not get the mileage out of the VCG Job you had intended.
Old 03-10-2013, 06:56 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
e46 jail is waiting for you
Old 03-10-2013, 06:57 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
No, not worth the time. You'll be fine, I never replaced mine and I have replaced VCG twice, in 217K, on my 323.
Old 03-10-2013, 08:23 PM
Mein Auto: 323
ok, thanks. I got 165k out of the original VCG and the grommets looked to be in good shape. I think I'll leave them alone.
Old 03-11-2013, 06:32 AM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
You'll be sorry. They have to be hard as a rock by now. Replace them, they're cheap....and soft.
BMW CCA #132981 Tarheel Chapter,
Old 03-11-2013, 09:25 AM
OfTheLost's Avatar
OfTheLost OfTheLost is offline
Mein Auto: 2000 328i
If you do decide to replace them, it wont take as long to get the valve cover back off since youve already done it once. I had mine off 3 times tracking down a leak that turned out to be a cracked valve cover, my first attempt took 2 hrs, third attempt was about 40 minutes
Old 03-11-2013, 09:27 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
They cost what, $8? Bad idea to skip such an easy and cheap thing. It MAY not cause leaks, but if it did wouldn't you feel foolish?
Old 03-11-2013, 02:34 PM
Mein Auto: 323
As I said, I bought the grommets but just forgot to install them. If I replace them, can I just do it one by one without taking them all out and then installing the new ones in a criss crosspattern? What I mean is, I didn't tighten each bolt one at a time but did each one a little at a time so the valve cover would seat properly. If I could bypass this the second time around it would be a lot faster.
Old 03-12-2013, 05:33 PM
helphos helphos is offline
Mein Auto: 2004 325xi
Danger, Will Robinson!
That sounds like a good strategy. I didnt replace mine, and it's been fine for the past 6 months. If I think about it I might pick some up at the dealer, just for fun, and do what you're planning to do. On the other hand, I have no leaks...and I have other projects.
Good Luck!
Old 03-12-2013, 05:37 PM
540i6spd 540i6spd is offline
Mein Auto: 540i
Its better to change them but if you didnt nothing really to worry about just keep an eye here and there that there is a slight leak.
Old 03-19-2013, 03:34 PM
Mein Auto: 323
Ok, so I replaced all 15 grommets this weekend. I replaced each one at a time rather than taking them all out and replacing them.
Today after a couple days of normal driving, I noticed a very small leak at one of the vanos dips where the rtv sealant was. I was afraid this might happen. It was about the size of a small droplet. I cleaned it up and drove a few miles to see if it would leak again. No signs of a leak.
What should I do? Keep an eye on it or is it eventually going to leak in the future? I torqued to about 7.5 to 8 ft lbs if that matters.
Old 03-20-2013, 05:35 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
The sealant bond may have been disturbed. More importantly, did you torque down the cover in a criss-cross pattern after all grommet replacement? if not you're looking at warping/cracking the valve cover and leaking for sure. Since the gasket is still new, if you still have a leak after a while, you can always take it off, clean it and redo the sealant.
Was the gasket a victor reinz brand?
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 03-20-2013, 02:29 PM
Mein Auto: 323
I replaced each grommet one by one individually rather than taking each one out and starting over again. As each grommet was replaced I tightened it to final torque.
Old 03-20-2013, 09:26 PM
You didn't answer this question.
If you have a VR, you're doomed.
Old 03-21-2013, 04:09 AM
Mein Auto: 323
It was elring Klingon.
Old 03-21-2013, 04:59 AM
ahull's Avatar
He also replaced the grommets and retorqued the nuts one by one, vs. torquing all at the end in a criss-cross. He still may end up in e46 jail.
