E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
coolant
Do we need specific BMW coolant? I bought a Prestone 50/50 antifreeze and it said "all make" "all models"
I have 2003 e46 sedan. |
Ya it's fine. Some would disagree.
"50/50 Mix" antifreeze is for suckers....you`re paying top dollar for about 20 cents worth of distilled water....you could buy the full-strength stuff, mix it yourself, and have twice as much for the same money.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
That's what I've been using. No problems so far.
I guess suckers are lazy people...
I use the pure Preston's and mix in my own distilled water. I am not a fan of 50/50 outside of freezing temp. I do more like 60/40 with some good brand water wetter. I'm running fine still.
Sent from my PantechP9060 using Bimmer App
Thanks guys. Do you know what the Prestone "GM approved" mix is? Its a bit more expensive than the standard ones.
(it's all about surface tension my boys) |
Do the same with a drop of water that`s had a tiny amount of dishwashing liquid added to it, and observe the difference.
![]() for those of you who are pre-30's......this one might make more sense....
What coolant you use is more dependent on your personality than on anything else.
- How personality plays a role in BMW coolant decisions (1), Plus, this question has been asked, oh, only about fifty thousand times already, so, you're not likely to get the real answer without a few well deserved jokes for not just looking it up. If you type /coolant F3 into the bestlinks, for example, this pops up: - Coolant: Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1) & bleeding (1) (2) (3) or refilling DIYs (1) This was written for the E39, but it applies equally well to the E46: Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
i had to use prestone to top up once or twice, no big deal.. if i were to flush the coolant completely and add new id pay the extra couple of bucks and get the BMW Coolant, i like to take that precaution
"You'll have nothing and like it!" |
I Love the headgear Bob!
Don't be gormless; get some gorm! ![/I][/FONT] |
I run the full strength Prestone cut with distilled water. |
Nothing wrong with distilled; just that tap water is fine in the two localities we arbitrarily tested (because the figures were available).
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
