Old 03-11-2013, 08:55 AM
maa2003 maa2003 is offline
Mein Auto: 325i
RPM Drop and engine bogging HELP!!!
I am having a problem with my 2003 325i bogging down.
Hi all, new to the site and new to the BMW owner's family. My car seems to make this deep roar out the muffler at about 40 - 45 mph and the rpm gauge drops as it does this. The noise is loudest at this speed, but does it at any speed as long as I have the gas pedal at a steady speed. This is usually in the small town I live in and on the highway. I am going to attempt to try and post a video of this happening. Note, I just had it in the shop for this and they could not tell me anything. Instead they told me my MAF sensor was bad and my fan clutch was locked up. I replaced both of these and still having the same issue.
Sent from my SAMSUNG-SGH-I747 using bimmer app
http://s54.beta.photobucket.com/user..._Drop.mp4.html
Old 03-11-2013, 08:59 AM
Mein Auto: 325i
Oops
Old 03-11-2013, 10:19 AM
jdauria jdauria is offline
Mein Auto: E39 ///M5
vacuum leak somewhere. When you replaced your MAF did you get OEM or chinese knock off
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 03-11-2013, 10:23 AM
Mein Auto: 325i
I guess it was Chinese knock off because I bought from local autoparts warehouse. It was doing the rpm drop before I replaced the mas air flow sensor.
Old 03-11-2013, 10:26 AM
Well you need to get OEM, or put your old one back on and clean it with CRC
Supersprint Headers
SuperSprint X-Pipe
Old 03-11-2013, 10:34 AM
Mein Auto: 325i
I understand that and with next check I will. But the problem still exist, even with the oem MAF. Do you think it might be a vacuum leak still? I'm grasping at straws so to speak. I don't want to pour a lot of money on changing parts to fix it unless the parts are the problem.
Old 03-11-2013, 10:36 AM
It could be multiple issues. Are you throwing codes? Do a quick search
Check your lower intake boot, you can check with your hand. The lower part of the tube would have a tear in it.
Supersprint Headers
SuperSprint X-Pipe
Old 03-11-2013, 10:37 AM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
Is that a manual?
You're lugging the engine - rpms are too low. Shift down a gear or two.
Two other things:
1) VANOS
2) Fair number of miles (118K ?), if the catalytic converter is plugged, it screws up the vacuum and can cause similar problems.
Old 03-11-2013, 10:39 AM
Mein Auto: 325i
No codes, but I will check that part at my lunch break.
Old 03-11-2013, 10:43 AM
Mein Auto: 325i
I have a lot to learn about German cars. I've seen other people talk about VANOS but I will have to research what that is and does. CAT could be going out. I didn't think about that.
Old 03-11-2013, 10:46 AM
Mein Auto: 325i
Originally Posted by floydarogers View Post
Is that a manual?
Two other things:
1) VANOS
That's what kinda frightens me. It my be tranny problems because it doesn't do it nearly as much when I have it in sport drive. It's an automatic
