E34 (1989 - 1995)
Old 03-11-2013, 06:51 AM
z33max z33max is offline
Mein Auto: BMW E34 520i V24
Exclamation 520i V24 strange RPM problem - SOLVED!
Hey again guys! After few days of researching and testing finally we found the solution of my strange RPM shaking (the car do the harlem shake ) so the problem is Lambda sensor!
We disconnect it and ...... nothing change! Same F@$%@#$%ing problem. The Lambda sensor "bring" information to the MAF sensor of the CO2 level, so the MAF knows if the car need more air or more gasoline. When the Lambda not working them MAF didn't know what to do...and start's to make bull$#@$ts .... So ... here is the moment when I need some help! In my country there is no original Lambda sensor for that car! Only some Chinese fakes. Can anyone help me with that!?
Old 03-19-2013, 07:12 AM
So guys! Today I was at full computer diagnostic. In BMW. They check everything that technologies allow. And ... what's the BIG deal with my lambda sensor ... In fact the sensor work fine. (we check it with oscilloscope) but some smart guy move it in the middle of the car!!!!!!! (When they removed the catalyst) and the senor CAN'T reach the necessary temperature for working properly! Here is the picture that I make.
Old 10-27-2013, 03:46 AM
takis takis is offline
Mein Auto: E36
I have the same problem and not blame the lambda or the MAF.
Old 10-27-2013, 08:31 AM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
Ahahahah.. Getto section of exhaust.. Lol..
Thats your problem!
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
