E60 (2004 - 2010)
Old 03-11-2013, 02:40 PM
Alex Ford Alex Ford is offline
Mein Auto: BMW 530D SE
E60 gear stick knob removal?
Hi. The chrome plate on my 6 speed manual gear stick knob is come off and leaving sharp edges, so I need to replace it but I see no obvious way to remove the knob from the shaft.
Does anybody know how its attached please?
E60 350 D manual 56 UK reg.
Thanks,
Alex Ford.
Old 03-11-2013, 02:45 PM
etnav382 etnav382 is online now
Mein Auto: 06 550i
The knob is just shoved on basically, pull up on the leather thats connected to the trim and then pull up firmly, at least thats how it is on an auto.
eBay Stuff http://myworld.ebay.com/etnav382
Sport Steering Wheel w/Paddles, M5 cluster
Old 03-11-2013, 02:49 PM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: E60 545i
Have you tried turning it counter-clockwise? The one on my 370Z was a real pain to get off. I used a pair of vice grips and a towel to hold the shaft while turning the knob with a pipe wrench. It worked. You don't want to put too much strain on where the shaft connects to the transmission.
2004 545iA, Titansilber Metallic/Black Dakota, Sport, Premium & Cold Weather Packages, Navigation, Premium Sound, Logic 7, HL Washers, Active Steering/Suspension, PDC, Adaptive Bi-Xenon,Voice Command, Beltronics STiR +, 58% Full Tint, Smoked Side Markers, 19" Hyper Silver Avant Garde M359/Michelin PSS, M5 Trunk Finisher & iDrive Controller, Dinan Performance Mods: High Flow Intake & Throttle Body, S3 Engine Software, S1 Suspension, CF Front Strut Brace and High Flow Exhaust
Old 03-11-2013, 02:50 PM
Thanks. It's a leather and chrome knob and has a leather gaiter that goes down to the centre console. Are you saying to pull the knob off at the Joint of the bottom of the knob and the top of the leather gaiter? Really don't want brake the stick. Was worried incase it had a concealed alllen screw, or was screwed one etc. PS these knobs are expensive!
Old 03-11-2013, 02:52 PM
Thanks. Not tried anything yet. I too don't want to break anything so that's why I am asking the experience here before I try :-)
Old 03-11-2013, 02:54 PM
Mein Auto: 06 550i
Pull the leather away from the center console, I usually start with one side and bend it slightly to pull it up. Then once the leather is only connected to the knob pull up on it til it comes free. Some have suggested opening the sunroof because the knob will kinda fly off when it comes off.
Old 03-11-2013, 02:56 PM
Ok thanks very much for your assistance.
Old 03-11-2013, 03:40 PM
mrgrumpy mrgrumpy is offline
Mein Auto: 2005 545i Sport
I replaced mine recently.
Pull up on it pretty hard in a sharp jerk.
That's it!
Fastest known repair on a BMW
Old 03-11-2013, 03:44 PM
Ok thanks, but you have to undo the leather gaiter from where it joins the centre console at the bottom square area or does the knob come off and leave the leather gaiter in place attached to the top area of the stick please?
Old 03-11-2013, 03:57 PM
To the best of my knowledge all E60's have a push-on / pull-off gear shift knob.
The leather gaiter reaches to the bottom of the knob but is not connected to it.
I don't believe you stated the year of your vehicle; only model.
Inspect closely, but I am quite certain that is your setup as well.
Old 03-11-2013, 04:02 PM
Thanks very much. It's a 2006/56 plate UK reg 350D E60 6 speed manual.
Old 03-12-2013, 10:18 PM
AlterZgo AlterZgo is offline
Mein Auto: 2010 535i 6MT M-Sport
I just removed mine following the instructions from turnermotorsport.com. The knob pushes on and pulls off. It clips to a ridge at the very bottom of the shift knob. The key is to place the shifter into 2nd gear. This gives you the best leverage and prevents you from pulling up against the windshield or other things that might get damaged. Once you have it in 2nd gear, just pull directly up (at the same angle as the shift lever is in while in 2nd gear) and it should come right off with no trouble. At least mine did.
To install, just push the shift knob down hard until it clicks in. Very easy, no tool affair. You don't need pipe wrenches or anything else. In fact, using tools may increase the chance of damaging something in the car when the shift knob pops loose.
Old 03-13-2013, 12:50 AM
Thanks very much. I have ordered a replacement knob and await its arrival.
Old 03-14-2013, 05:39 PM
gmnmsclM540i's Avatar
gmnmsclM540i gmnmsclM540i is online now
545i pilot
Mein Auto: e60 545i e34 540 e32 740
Followed these instructions, & surprise! worked perfectlyClick image for larger version
Sent from my DROID RAZR using Bimmer App
Old 03-15-2013, 12:34 AM
Good news then! Thanks.
Old 03-15-2013, 10:43 AM
Job done. Ordered new one from Ebay (BMW Direct) £50.00 :-( but arrived this morning 2 days after ordering. 60 seconds old off, new on. Thanks to everybody's help.
Old 03-15-2013, 05:47 PM
myates3 myates3 is offline
Mein Auto: 2006 550i
Greatest advice I've read on this forum!
2006 550i
